Performance ATV Parts Though Shaft for Can-Am - Can-Am ATV Forum
This is a discussion on Performance ATV Parts Though Shaft for Can-Am within the ATV Tech Tips forums, part of the Can-Am Tech Area category; here is the Performance ATV Parts Though Shaft compared to the stock (broken) 2009 part DSC00333.jpg www.performanceatvparts.com/ the gorilla through shaft does not have the ...
Go Back   Can-Am ATV Forum > Can-Am Tech Area > ATV Tech Tips
Old 05-16-2011, 11:24 AM
cra815sh's Avatar
Member #15119
View cra815sh's Photo Gallery(0)
the gorilla through shaft does not have the groove for the c-clip to be installed (atleast the one my buddy bought last year), the c-clip is what the u-joint yoke butts up against when you tighten the bolt, if the c-clip isn't there the the yoke will be loose on the splines and splines will end up wearing out from the play
my buddy installed the gorilla in his bike last year, now he needs a new yoke for the front drive shaft
Old 05-16-2011, 11:58 AM
Man that thing looks well built.
Old 05-16-2011, 03:16 PM
VtecGSR95's Avatar
Member #4306
View VtecGSR95's Photo Gallery(0)
does this require grinding inside the engine case like the old desert dog shafts>?
Old 05-16-2011, 03:26 PM
roffler's Avatar
Member #8351
View roffler's Photo Gallery(0)
If I would have known about that performance atv had the shaft, I would have got it over the gorilla. The gorilla is more expensive and doesn't has the groove for the c-clip
2010 800 xt-p
--all black plastic, 31" outlaws on diesels, HL signature series lift, gorilla thru shaft, rhino axles. gorilla rad relocator, snorkelyouratv, QSC clutch kit, hmf pipe and optimizer, d2 fender flares, yellow LEDs in rad relocator and cat eyes.
2011 sportman 90
--completely stock and gonna stay that way
Old 05-16-2011, 08:49 PM
cra815sh's Avatar
Member #15119
they told me that all the ones they have put it did not need any clearancing inside the cases
mine did, but just bearly, i could get it installed but it rubbed, i wrapped and piece of 80 grit sand paper around it, installed it with only one bearing on the front drive shaft side and held it up against the cases while i turned it by hand, then it fit, it only removed very little material
i had a shop towel in the bottom of the cases while i was sanding it, then took it out and rinsed the bottom of the cases out real good with brake cleaner, the crank case needed cleaning any way because there were metal shavings laying the bottom because i rode it about 80 miles with the through shaft broke
Old 05-16-2011, 08:51 PM
cra815sh's Avatar
Member #15119
i will measure the diameters of them both tomorrow
i haven't put it together yet, waiting on one more bearing for the through shaft, the bearings didn't like the metal shavings in the bottom of the cases!
Old 05-17-2011, 07:51 AM
VtecGSR95's Avatar
Member #4306
I had to grind the shiet out of my old one years ago! I did not like that....and I thought there had to be a better way!
Old 05-18-2011, 07:49 AM
cra815sh's Avatar
Member #15119
the stock shaft is 0.626" OD
the performance ATV parts shaft is 0.740" OD
the diameter is not much bigger, but the torsional strength would be 65% greater for the performance ATV shaft if the two shafts were made from the same material
Old 09-14-2011, 08:33 AM
my07rhintax's Avatar
Member #10654
View my07rhintax's Photo Gallery(0)
do you know what the performace atv shaft is made of? how's it working for you?
See my Rotax swap http://www.flickr.com/photos/deanhoo...7624436193769/
Old 09-14-2011, 06:17 PM
cra815sh's Avatar
Member #15119
it has not broke yet, i have broke the outer cv joints on both front axles since the through shaft was replaced, the front axles were replaced with rhino axles, i will see what goes next the rhino axles or the through shaft
I ride my girl's bike! which is:
2009 Can-Am Outlander 800R XT
29.5" outlaws
snorkels (they don't work very good when the bike is upside down!)
Performance ATV through shaft
QSC Primary Clutch
STM Secondary Clutch
HMF Swamp Series muffler (Swamp Series my ass, this thing SUCKS!)
5000# Venom winch on front
5000# Venom winch on rear
Optima red top aux. battery
custom air shocks
custom CV joint rear drive shaft (F u-joints!!!)
custom stereo w/ 4 6x9s
atv aftermarketing parts in houston adrees
can am aftermarket rear driveshaft gorilla
can am atv parts
can am atv parts in houston texas
can am axles houston texas
can am parts houston
can am parts in houston
can am through shaft
can-am front through shaft
can-am thru shaft
desert dog through shaft
how to install through shaft on can am outlander
performance atv can am through shaft
perrformance atv prop shaft
rene1 performance
*Can AM Parts* Share Websites to find Can am Parts IcanamCanUU? Can-Am Outlander 2 09-14-2010 05:28 AM
Help Outlander 400 drive shaft/rear propeller parts and identification dragonkneez Can-Am Outlander 2 08-05-2009 01:21 PM
Any parts suppliers in US that stock parts Rene_Rider_NC Can-Am / BRP 4 03-12-2008 03:54 PM
800 Performance ktmhk53 Can-Am / BRP 54 10-08-2006 10:28 PM
Performance parts for 07 650 Circa2000 Can-Am / BRP 14 07-15-2006 10:36 PM
