Just installing a couple of 10 watt LED's in my fairing and I managed to get my hands on the install instructions for the BRP accessory LED's that are the same wattage and size. Turns out the accessory LED's would just connect through a switch to a pre-wired accessory connector already integrated in my bike from the factory, meaning they have already sized everything for this extra 20 watt load. Along with the accessory connector there is also a blue wire that is taped to it, that also gets connected. The harness that ships with the Canam accessory lights has a 3 position switch that lets you turn the lights on whenever you want independent of the stock headlights in position one. In the second position the lights operate in conjunction with the high beams. The third position the lights are always off. I'm only interested in having them work in conjunction with my high beams so if I had the wiring schematic I could figure this out without having to do trial and error. If I can get this figured out I will share my complete install. Total cost will be around $40 cdn for the setup.
Sent from my iPad using Tapatalk
