New Wheel specs
This is a discussion on New Wheel specs within the ATV Tires and Wheels forums, part of the Can-Am Tech Area category; How to select a new wheel for my Outlander Max Ltd 2010? What do I need to know before shopping around for a new wheel ...
Old 02-08-2010, 07:03 PM
Member #7923
View Sergio's Photo Gallery(0)
Default New Wheel specs
How to select a new wheel for my Outlander Max Ltd 2010? What do I need to know before shopping around for a new wheel understanding that my stock wheels are:
Front: 12X6 in
Back: 12X7.5 in
and I want ot stay in 12 in wheel
Do I need to worry about the Bolt Patern (4/137 I believe?)?
Thanks in advance
Old 02-08-2010, 08:35 PM
Voodoo's Avatar
Member #2820
View Voodoo's Photo Gallery(8)
Yes....you have to stay with the 137 bolt pattern for sure....
What are you worried about? The aftermarket Rims are a little wider, but that is about it.
Voodoo
Old 02-08-2010, 08:55 PM
Member #7923
If my stock are right now:
Front 12X6 in
Back 12X7.5
is it OK to get 12X7 in for all four wheel (front and back) or I have to respect the 6in and the 7.5in?
Old 02-09-2010, 10:39 AM
gtj's Avatar
gtj gtj is offline
Member #5841
View gtj's Photo Gallery(0)
The width of the actual tires you purchase will determine the desired rim width as well as a possible offset change to clear the front tie rod ends.
2008 Outlander Max XT in Yellow, Snorkeled, Frame Mod, Ricochet Skids, One-Way Bearing Mod, Reverse Mod, PRP Steering Stabilizer, Sylvania Silverstar Ultras, Crutchfield Stage I rear / Stage II frt, Maxxis 28 Zillas on ITP SS108, Renegade Foot Pegs, heated thumb & grips, 2 X 1gal. gasoline / 1 X 1gal. water RotoPax
Old 02-09-2010, 01:04 PM
Member #9087
View Travis Moseley's Photo Gallery(0)
If you get a 12X7 all the way around, you will not be able to run a 5+2 offset in the front. This is 5" to the inside of the wheel and 2" to the outside. The wheel will touch the tie rod end to your hub. You will need to get a 4+3 offset wheel. However, IMO this affects the handling of the atv. You will be EXTREMELY wide. If you talk to "Bones" at OMF Performance, (www.omfperformance.com) He might be able to fab up a nice beadlock or reinforced wheel with a 4.5+2.5 offset. I do not own a wheel like this but I race with somebody that does. This offset will clear your tie rod end just enough. Now if youre planning on getting an extremely wide tire, you will have to double check to make sure they will clear.
Travis Moseley
Front 12X6 in
Back 12X7.5
atv wheel specifications
Clutch specs Atver Can-Am / BRP 4 12-28-2008 07:52 PM
650 outty tq specs abnrngr1986 Can-Am / BRP 9 01-01-2007 05:58 PM
Can Am specs. ATV Rock climber This Just Pisses Me Off 7 12-19-2006 06:31 PM
Wheel Torque Specs CANADACOPPER Can-Am / BRP 4 04-15-2006 12:22 AM
Wheel specs, info and suggestions snoball Can-Am / BRP 15 12-03-2005 12:04 AM
