Tire & wheel advice - Can-Am ATV Forum
Tire & wheel advice
This is a discussion on Tire & wheel advice within the ATV Tires and Wheels forums, part of the Can-Am Tech Area category; Hi, Does anybody have an idiots guide to ATV tires and wheels? I fancy a new set of Diblo headlocks, but I don't understand the ...
Old 02-06-2011, 06:13 AM
Member #9357
View RobbOnTheRock's Photo Gallery(0)
Tire & wheel advice
Hi,
Does anybody have an idiots guide to ATV tires and wheels? I fancy a new set of Diblo headlocks, but I don't understand the whole offset thing! Anybody care to explain?
I was also considering a set of pit bull growlers? I mainly go on trails, some are groomed and some are very much just little more than walking tracks.
Every time I have gone out with my stock tires I've had a puncture so I was considering getting a 6ply tire to try and reduce the puncture frequency!!
I have an outty 800 (2008) and steering is heavy enough I don't want to make it any heavier!
Cheers
Andy
2008 800 Outlander XT (Viper Red);
Radiator Protector;
Locking Fuel Cap;
Mud Guard Extensions;
Ricochet Skid Plates;
New Winch Wire;
DWT Diablo Rims (12" {4+3]);
25.5" Growlers XOD (5psi);
1075 miles;
Old 02-06-2011, 07:46 AM
Bike1's Avatar
Member #14249
View Bike1's Photo Gallery(0)
Hey Robin.. needing new ones myself and have read what seems like hundreds of respected reviews and have visited/spoken to a lot of owners as well as looked at them personally. Sounds like your riding style similar to mine. Other than some groomed areas and snow, I have no intent to hit logs or put it sideways through soup holes. I firmly believe at this point either the pitbull growler (6 or 8 ply depending on sixe) or the gbc grim reaper ( 8ply) would be a perfect fit and plenty tough (IMO). Both radials great ride and plenty of bite for even the unintended rough terrain or moderate mud. Steering - I would stay with either an 8" or 9" if thats a concern. Offset - very simple.. the distance from the mounting surface to the back edge of rim and the distance from mounting surface to the front edge of rim. The 2 numbers equal the total width of rim. Example a 7 inch rim could haver an offest of 4-3. In essance it simply moves the wheel/tire in and out making the wheel base wider or narrow to clear things or change wheelbase preference. I am fairly new to atv'S but certainly not to motor sports. Hope this helps
The Following User Says Thank You to Bike1 For This Useful Post:
RobbOnTheRock (02-06-2011)
Old 02-06-2011, 07:48 AM
Bike1's Avatar
Member #14249
oh ya.. forgot to mention that the first number of the 2 is the inside one :-)
Old 02-06-2011, 10:18 AM
Member #9357
Cheers, for that. I'm fairly taken with the Diablo's and the 6ply growlers. I'm a wee bit concerned that the heavy ply will make it difficult to steer and / or make the handling a bit too stiff.........
I'll size up the wheels now. What sizes were you looking at? I was considering 25.5 as I don't really want to put too much strain on the bike, yeah I know it's an 800 but these wheels will be heavier!
PS do you know what internal coatings you can get for the tires to help seal puncture (apart from green slime that is).
Cheers
Andy
Radiator Protector;
Locking Fuel Cap;
New Winch Wire;
1075 miles;
Old 02-06-2011, 10:31 AM
Member #9357
Sorry stupid question time I guess.....
Whats the offset on teh std wheels on an 2008 XT?
Cheers
Andy
Radiator Protector;
Locking Fuel Cap;
New Winch Wire;
1075 miles;
Old 02-07-2011, 08:58 AM
Bike1's Avatar
Member #14249
You would have to measure yours but a quick measurement of mine "appears" to be a 7" wheel with a 5-2 offset on the front (25x8x12 tires) .. and the rears "appears" to be an 8" wheel with a 6-2 offset (25x11x12 tires). The rear could be a 1/2 inch wider wheel but could get an exact measurement with wheel on bike. These are the factory "XT" steel wheel package, not the optional aluminum wheels.
Old 02-07-2011, 06:59 PM
Member #9357
Ok, thanks (I think)........still not entirely clear on how to comfrotably spec a new set of tires and or wheels for my quad without having a potential tie-rod pinching moment!
Cheers
Andy
Radiator Protector;
Locking Fuel Cap;
New Winch Wire;
1075 miles;
Old 02-08-2011, 08:24 AM
outtyhere's Avatar
First Name: Ricochets- i dont leave home without them
Member #699
View outtyhere's Photo Gallery(0)
I'm confused - do u have the diablos already or no?
If u get a 4x3 offset you should be fine. And the diablos fit with my growlers no problem. Plenty of room! I had the dirt commanders on the stock wheels and I had to space the fronts out a quarter inch. They were touching the tierods.
The 4-3 offset will also make your wheels stick out a little further, no more than a inch. Probably less. If I were to advise you I'd say get a 4-3 offset by 7 wheel. Front and back and they will fit almost all the tire sizes out. Take a look at the Diablo beadlock with growlers on the way thread. You might have a good read.
Sent from my Droid using Tapatalk
07 camo 800- Ricochets, ATR Spine, 55w 5000k HIDS, Renegade pegs, Diablo Beadlocks, Growlers, Gorilla Lock Lugs, HPG Shock kit, Amsteel BLUE syn. rope in silver w/ steel thimble, UHMW rollers, Blitzkrueg Snatch Block, Symtec 4 zone heated controller, Kolpin cargo box, Quad Boss Plow
Old 02-08-2011, 10:35 AM
Bike1's Avatar
Member #14249
Andy.. I'm with Outty. 4-3 offset to be sure. You might gain a couple inches in your wheel base width but better than a bad date with a tie rod. Personally the slight add of width is not an issue and probably a good thing.. but each their own. Also it might seem a little pre-historic (and possibly embarrassing if friends see you doing it) but I actually took a few pieces of paper and cut some ruler size strips that were the the lendth of the tire or wheel width, marked the center point of the width and actually laid them beside the strip that represented the wheel/offset. they were marked in 1/2 inch segments and by using 1 piece for every wheel/tire option you were considering it gave a real good "visual" of clearance or positioning. Like I said.. a little prehistoric and being relatively mechanical somewhat embarassing but works when your brain gets tired :-)
Old 02-11-2011, 11:44 PM
Member #14430
View atv tires's Photo Gallery(0) Send a message via ICQ to atv tires
Post Diagram
I have a nice diagram of wheel offsets here if you want it for reference.
The Following User Says Thank You to atv tires For This Useful Post:
katherine (04-05-2011)
atv measuremen
atv offset wheels
atv tires and rims combo
atv wheel diagram
atv wheel offset
diagram of a tire and rim
gbc grim reaper vs pitbull growler
how to measure atv rim
how to measure atv wheels
measuring offset wheels
offset on atv rims
offset wheel diagram
wheel measurement
wheel offset diagram
Advice on Wheel/Bolt Pattern Burner ATV Tires and Wheels 0 05-22-2009 11:57 AM
28" tire advice needed rkc05 ATV Tires and Wheels 42 10-19-2008 12:15 AM
Tire/wheel dilemmas!!!!!!!!!!! fmj40 ATV Tires and Wheels 58 02-19-2008 06:33 PM
Tire & Wheel Offset turilla ATV Tires and Wheels 1 03-31-2007 09:37 AM
Tire/Wheel combo 800outtybounds ATV Tires and Wheels 3 08-25-2006 12:22 AM
