My speedo is now healed... - Can-Am ATV Forum
This is a discussion on My speedo is now healed... within the ATV Tracks forums, part of the Can-Am Tech Area category; Ordered a speedohealer for when I run tracks. Don't care much about speedo accuracy, but don't want to rack up 2x the miles on the ...
Go Back   Can-Am ATV Forum > Can-Am Tech Area > ATV Tracks
Old 01-05-2014, 04:43 PM
fox128's Avatar
Member #6333
View fox128's Photo Gallery(0)
Ordered a speedohealer for when I run tracks. Don't care much about speedo accuracy, but don't want to rack up 2x the miles on the odo when tracking. Had an issue with the first unit (apparently extremely rare). Customer service was 10/10 and sent out a new one right away. Works perfect now! I highly recommend the product.
2013 Outlander 1000 XT.
26" Bighorns on STI Beadlocks
Tatou 4s Tracks for winter
Muzzy slipon and VFJ Tune
American star tie rods
SpeedoHealer
2013 Outlander 800 XT. (wife's)
Old 01-05-2014, 04:44 PM
fox128's Avatar
Member #6333
Just need more snow now!!!!
SpeedoHealer
Old 01-05-2014, 05:28 PM
outtyxmr800's Avatar
Member #31315
View outtyxmr800's Photo Gallery(0)
So with a speedo healer your km's racks up twice as fast or did I miss understood? I was going to order one but I don't want to rack up km's twice as much?
Old 01-05-2014, 05:40 PM
fox128's Avatar
Member #6333
If you have tracks and no speedohealer your odometer will show about twice as many km as you actually traveled, and you speed will read way to high.
The speedohealer can be programmed to correct both ways....faster or slower.
So yes, you want one and should go ahead and order it!
SpeedoHealer
Old 01-05-2014, 08:10 PM
Member #31315
I don't have tracks. So will the speedo healer read my km's correctly. I will order the rmt model.thanks
Old 01-07-2014, 06:59 PM
Member #4004
View OuttyUpfront's Photo Gallery(0)
The speedohealer doesn't care if your speedometer reads mph or kmph... it's doing a "percentage" function (addition or subtraction) to the signal coming from the speed sensor - that's just 12vdc pulses - on or off at a rapid rate.
Old 01-25-2014, 09:37 PM
Member #32138
View Crossbar's Photo Gallery(1)
How difficult is it to install the Spedohealer??
Old 01-25-2014, 09:50 PM
Member #4004
First one... 30 mins - most of that time is spent determining where to mount the included micro toggle switch, should you purchase that model. The rest of the time is removing / reinstalling panels, should you have a Gen 2 machine.
Second and subsequent installations can be done in 10 mins as you know what you are doing.
Boils down to gaining access to the speed sensor/main harness mating plugs - unplug. Then plugging the SpeedoHealer's harness in between the halves you just unplugged. Plug the Healer's harness into the control head. At this point, it's functional, just not tidied up.
Old 01-26-2014, 08:52 AM
Mopard's Avatar
Member #15040
View Mopard's Photo Gallery(0)
Why would you want a speedohealer if you don't have tracks? Bigger tires? heh heh, guess with an XMR you may have smaller tires?
Check out the site ... lots of info what it can do ... you have options.
SPEEDOHEALER - CANADA (ultimate speedometor re-calibrator)
2015 XT-P 800R / 27.5 Pitbull Rockers / BRP Heated Grips/Thumb / BRP Mud Guards / Dalton DBO800-Tan Spring (Awesome smooth!) / Tatou 4S tracks with BRP DPS module ... woohoo!
2013 Outlander XT-P 800R ... traded.
2011 Outlander XT-P 650 / Silver/Black ... traded.
Old 01-26-2014, 09:21 AM
Member #4004
That Canadian site isn't offering the same thing that Metric PowerSports is providing us.
Metric PowerSports offers the Remote Toggle units - with waterproof buttons.
They also offer the Top Speed Memory units - with waterproof buttons. - Everyone else just offers the Standard Top Speed Memory units - without waterproof buttons.
Metric PowerSports makes their own wiring harnesses - heavier gage wire, shrink tubed with epoxy - no worries about dragging them thru the mud. Everyone else carries the Standard offering of wiring harnesses - which are made for Motorcycles - on road - not even submerged applications. Nor are they long enough to place the Healer head anywhere remotely convenient.
Metric PowerSports kits include extremely detailed instructions with PICS on where the speed sensor plug is. Others just say "find the speed sensor plug".
Try calling or e-mailing any other vendor after hours or on Sundays and see if they answer. Try asking other vendors to help you with the calculations on making your speedometer read spot on. Metric PowerSports does all 3.
Last but not least, call up any other vendor and ask what the SpeedoHealer does for the ACS or speed limiter on an Xmr... or how it affects the timing retard as the speed limiter is approached on ANY Can-Am. You'll either get silence, an "Uhhhhh" or blatantly lied to.
Metric PowerSports got exclusivity on healers for the Can-Am line for North America because he knows what he's doing. I don't believe there is ANY other SpeedoHealer vendor that makes their own wiring harnesses or installation instructions - they just give what's included with the Healer (provided by the manufacture of the Healer (HealTech) but extremely generic) and sell whatever harness Healtech makes - which again, is made like every other harness - which are ALL for motorcycles.
I know, because over the years, I've bought from both "the typical vendor" as well as from "Metric PowerSports". Robert's not in it just to sell a healer - he's in it to make sure the healer is the solution you need - if it's not, he won't sell it to you. That and he offers an unconditional money back guarantee.
The Following 2 Users Say Thank You to OuttyUpfront For This Useful Post:
Mopard (01-28-2014), Snowlander (10-04-2014)
.speedohealer for can am outlander
can-am outlander 800 speedo
how to set up speedo healer for atv tracks
howhowto install speedohealer in a canam outlander
speedo healer for can am 1000
speedo healer for tracked atv
speedo healer outlander 800
speedo healer percentage for atv tracks
speedohealer can am
speedohealer can am 1000
speedohealer for can-am outlander 1000#gsc.tab
speedohealer for honda atv
speedohealer on can am outlander 800
were do i get a speedohealer for my 2014 renegade 1000
will outlander 800 run with speedo unplugged
new speedo vulcanrider Can-Am Outlander 3 09-15-2012 06:03 AM
08 speedo on 07? ytsouttymax Can-Am / BRP 23 02-02-2008 12:35 PM
speedo is way off benpsg Can-Am / BRP 15 12-17-2007 10:05 PM
Speedo WYOMAX Can-Am / BRP 2 12-06-2007 10:33 AM
speedo Kraker Can-Am / BRP 10 09-04-2006 06:37 PM
