Dash all flashing and not shifting - Can-Am ATV Forum
This is a discussion on Dash all flashing and not shifting within the BRP Traxter / Quest forums, part of the Can-Am ATV Discussion category; Hi, I was on a trip on the traxter and the whole dash started to flash, then the transmission was not auto shifting anymore, I ...
Go Back   Can-Am ATV Forum > Can-Am ATV Discussion > BRP Traxter / Quest
Old 01-16-2013, 06:46 PM
Member #25758
View rastok's Photo Gallery(0)
Hi, I was on a trip on the traxter and the whole dash started to flash, then the transmission was not auto shifting anymore, I had to to turn the button to manual to be able to change gear. Then after riding it a lil this way it woudnt change gear at all..
After letting it cool down I started it again and everything was back normal.?!?
Hope some one could help me. Thanks alot.
Old 01-18-2013, 05:49 AM
Member #25758
Bump!!
Old 01-18-2013, 07:20 AM
SmokeyMcBong's Avatar
First Name: i am the cooker of the foods
Member #17393
View SmokeyMcBong's Photo Gallery(0)
Sorry to hear about your problem bro. There's a lot of stuff going on when you change gears on the traxter.
When you changed outta "auto" to "manual", were all the dash lights still flashing? When changing with the button, did it take longer than normal to change or were there any weird noises? Once it cooled down and started to act normal, did the dash work properly? And lastly, have you experienced the symptoms since?
2013 Can-Am XMR 1000!!!
http://www.youtube.com/user/mcbongsmokey?feature=results_main
KawarthaATV director/chef - www.katva.ca
Old 01-18-2013, 05:09 PM
Member #25758
Well, when the lights starts to flash They are not stoping unless i stop the machine, and Like i told you the bike stops to shift on auto and yes it's not shifting normal l'y on manual eighter, the first Time it did that it was shifting only on manual and then after a few shot it was stock in whatever gear it was in.
Last anwser is no it didnt do it after but i only drove it off the trailer so i didnt change gear or really try it..
Hope it helps
Thanks alot
Old 01-19-2013, 12:42 AM
Member #24153
View Gregs04.5's Photo Gallery(0)
I posted about a similar problem a few months back. IIRC it was the trans position sensor,
On edit, It was the GBPS (gear box position sensor)
Old 01-22-2013, 01:42 PM
Member #26964
View jb333l's Photo Gallery(0)
I'm having the same problem. So far I think just recalibrate the TPS sensor should help.
I'm planning pickup the diagnotic jumper this week-end and proceed to the recalibration to see if it's help. I'll let you know...
Old 01-22-2013, 03:59 PM
Member #17393
i have the jumper and have done all the recalibrations that can be done with it and i don't know if it'll solve anyones problems but it did make a noticible difference in my bike.
make sure to clear all the codes after your done recalibrating. kill the ignition then re enter the calibration mode to check that the codes have cleared properly, then go for a nice little boogie and then recheck for codes again.
Old 01-24-2013, 05:40 PM
Member #26964
Maybe SmokeyMcBong could confirm, but that should be the jumper to replace by the diag. jumper (just left of the fan):
Here's the diagnostic codes:
Table 2: Abnormality-Diagnosis Components CODE NO. DIAGNOSIS COMPONENT LED “REVERSE” LED “HI-LO BEAM” 0 No abnormal components found LED ON for 3 seconds only LED OFF 1 Starter solenoid LED ON LED blinks 1 time 2 Clutching valve LED ON LED blinks 2 times 3 Clutch modulator valve LED ON LED blinks 3 times 4 Downshift solenoid LED ON LED blinks 4 times 5 Upshift solenoid LED ON LED blinks 5 times 6 MPEM memory LED ON LED blinks 6 times 7 Headlight supply LED ON LED blinks 7 times 8 Accessory/speedometer supply LED ON LED blinks 8 times 9 Reference supply output (GBPS, STPS and TPS (on AUTOMATIC model)) LED ON LED blinks 9 times
Old 01-24-2013, 06:12 PM
Member #17393
my jumper plugs in to the top left of the fan. its been awhile since i plugged it in but i don't think that anything was plugged into where the jumper goes. not 100% on that tho, like i said, its been awhile and my memory is not what it used to be lol. heres a couple of pics of the jumper that im talking about.
Old 03-25-2013, 04:52 PM
Member #25758
ok here are the latest, ive been on the traxter non stop for the last 3 days and here is the problem,
1- I cant use the bike on auto, as soon as the bike shift everything start to falsh.
2- On manual, if im really carefull on COMPLETLY releasing the trottle when shifting ill be allright, but if i shift while im giving any gaz it will start flashing all the lights.
then i simply have restart the bike and im fine..
any idea?? the bike shift great al the time all the gear works and theres no other problem..
2002 bombardier traxter instrument lights flashing
2002 traxter 500 dash lights keep blinking
2003 traxter instrument lights
2004 traxter panel lights flashing
bombardier 500 traxter dash lights nonstop blinking
bombardier traxter 500 flashing dash
bombardier traxter diagnostic jumper
bombardier traxter lights flashing
bombardier traxter panel lights flasing
ca am commander, transmission code? only reverse, no hi or lo?
dash all flashing and not shifting
traxter autolight flashing
traxter battery blinking lights
traxter mpem diagnostic jumper
4x4 light flashing. stitch Can-Am 2012 Models 2 01-12-2013 02:49 PM
engine light was flashing snobound Can-Am Outlander 2 05-31-2011 08:20 PM
Flashing Engine Light kb2112 Can-Am / BRP 17 12-29-2010 06:07 PM
4wd light flashing while in 2wd Fourfourmag Can-Am / BRP 5 12-27-2008 01:08 PM
Dash Lights Flashing on and off?? RaiderMike67 Can-Am / BRP 3 09-29-2007 02:25 PM
» Sponsored Links
