12-05-2011, 10:55 PM
Member #19737
fuel pump problems and throttle response
hello i was wondering if anyone else was having this problem i have a 09 800r outlander and my fuel pressure and idle is 34-38 wich is low and throttle response is slow motor boggs down sometimes some times after coming off high rpms it will back fire it just sounds slike it missing when idling i dunnno can some one help i have already drained out gas and cleaned tank there was dirt inside tank cleaned screen on fuel pump and tank add new gas still same problem....anyone got any ideas
12-05-2011, 11:04 PM
Hardcore Member
First Name: Sebastien
Member #14051
Your fuel pump is shot. Lol I went through three of them in my Outty and many of my friends got them replaced too so I'm sure It's a known problem. Check for loose battery connections because that will cause funny symptoms like that too. But I'm pretty sure its a fuel pump. Do you have any warranty left?
By the way welcome to the forum.
2012 Renegade X XC 1000
TUNE MONSTER with both expansions and Wideband O2 sensors, ///AIRDAM CVtech primary, STM Secondary, Dominator Dual Exhaust, MrRPM 51mm TB and Drop-in Cams
CLICK HERE FOR YOUTUBE VIDEOS: RenelanderTV
The Following User Says Thank You to Renelander For This Useful Post:
12-06-2011, 06:20 AM
Member #19737
no i dont i deffinetly appreciate it. I have heard there is awat to just replace the fuel pump its self instead of the whole piece. Its an acdelco fuel pump but i cant find the part number. How did u do urs?
12-06-2011, 08:23 AM
Member #16392
You did the right thing by trying to clean everything first. It sounds like your pump is shot, but did you check the in-line filter? There should be no resistance when you blow through it. The Airtex aftermarket pump # is E8213.
The Following 2 Users Say Thank You to Big Kid For This Useful Post:
12-06-2011, 09:27 AM
Member #13951
You can get just the pump on ebay cheap. There are plenty of write ups on how to change it out. Not a difficult job.
2008 Can Am Outlander 800ish, Custom Snorkels by Dicks Powersports, 2" pipe lift, Rox Pivoting Handlebar Risers, W.O.C's Custom Dry Tube, 29.5" Outlaws (skinnies), PCV-3P Tuned, RDC Custom Radiator Relocate, Ride & Rest, SafeGlo 6' LED Whip "Deep South Depth Finders"
The Following User Says Thank You to TxMudGurl For This Useful Post:
12-06-2011, 11:54 AM
Member #19737
there isnt a in-line filter its a screen filter, unless there is one somewhere else
12-06-2011, 12:45 PM
Hardcore Member
Member #14051
Yes there's one on the right hand side of your bike, on the frame under the seat above the gearbox. Just follow the fuel line from the tank, it's located just before the line splits to go to both injectors.
12-08-2011, 05:03 AM
Member #19737
hey i just wanted to say thanks for everyones info i changed the fuel pump out last night and it was the problem runs alot better and it the reason it was bad was because i got sand in my gas tank from riding in deep muddy water due to the gas cap i ordered a billet gas cap off ebay that supppose to wrk bettter well c
12-08-2011, 07:29 AM
Member #16392
Glad to hear you got it fixed
09 can am outlander 800 fuel pump, can am 650 fuel pressure, can am 650 fuel pump problems, can am 800 outlander throttle hard to push, can am fuel pump problems, can am renegade fuel pump, can am renegade fuel pump pressure, can am renegade fuel pump replacement, can am renegade not fuel pump, can-am outlander 800 throttle problems, changing fuel pump can am renegade, fuel pump problems, fuel pump problems on a can am 650, renegade fuel pump, what fuel pump will fit a can-am renegade
