hard to shift / whining noise - Can-Am ATV Forum
post #1 of 9 Old 02-13-2015, 09:45 AM Thread Starter
my gearshift gets really sticky, and takes awhile to get into any gear. Ill have in it low gear, but still says im in high on my dash. i gotta play with the gearshift alot to get into gear... anybody else have this issue? its something gone in it or is it just new? lol ..
and when my bike is in park or neutral, it makes a whining noise.. but reverse, high and low, it doesnt make the noise anymore. is this normal for the outlanders? is it just the way it idles when in park or neutral
thanks guys
bradcanam is offline
post #2 of 9 Old 02-13-2015, 09:52 AM
CanAmRancher1's Avatar
It is normal for them to make a whining noise in park and neutral. Mine has done it from day one. Not sure about your shifting problem.
2005 Can Am Outlander 400xt 7000 miles(traded)
2007 Can Am Outlander 500xt 13000 miles (traded)
2010 Can am Outlander 400xt 3000 miles (burned up)
2011 Can am Outlander 400xt 7500 miles (traded)
2009 Can Am Outlander 500xt 5700 miles (traded)
2013 Can Am Outlander 500xt 6000 miles (traded)
2014 Yamaha Grizzly 550 5000 miles (traded)
2016 Can Am Outlander 570xt 6500 miles (traded)
2016 Can Am Defender HD10 5000 miles (traded)
2017 Can Am Outlander Max 650xt 500 miles(current)
2017 Can Am Defender Xt 1000 100 miles (current)
Patriotism is supporting your country all the time, and your government when it deserves it.-Mark Twain
Failing to plan is the same as planning to FAIL.
Men do not fail, they give up trying.
CanAmRancher1 is offline
post #3 of 9 Old 02-13-2015, 02:45 PM
Sounds like the bearing in the primary needs service. It's causing the secondary to spin in P and N and make it hard to shift. Also makes a whining noise. As far as it reading the wrong gear your linkage may need adjustment after all the hard shifting issues get fixed.
rvsperformance is offline
post #4 of 9 Old 02-13-2015, 02:50 PM
Mine did that and I ignored it. Oneway bearing seized up couple of rides later. It will shift better if you put quality sealed bearings in it.
If you take it off, be mindful of the two little springs.
Decomp is offline
post #5 of 9 Old 02-13-2015, 03:32 PM
hobbytrucker1966's Avatar
mine whistles when I back up fast
2017 570 xmr
kimpex queen seat
kimpex fender protectors and foot pegs
click and go 2 60 in snow plow
4000lb crappy tire winch
hobbytrucker1966 is offline
post #6 of 9 Old 02-13-2015, 04:35 PM
jimo's Avatar
thanks guys
Servicing the one way may help a little. Adding 2oz of Schaeffer EB Moly Lube to the gear box may help a little. Learn the Can Am "Hump". Works for me.
The whine is the secondary. Install an STM secondary and the whine goes away.
A small adjustment in the linkage, like suggested above, will help with the gear indicator. You have described my machine to a "T". Nature of the beast
2009 Outlander 800r XT
CVTech/STM - Elka stg 3
XMR Snorkel kit
BRP rad relocate kit
28" Zillas - Itp ss 112
SPI exhaust - EJK Tuner
Ricochet full skids
Cecco steering stem brace
ROX 2" anti-vib risers
BRP Alum rear diff protector
Flex a lite fan controller
XMR CVT cover - EBC brakes
Warn Provantage 3000
Amsteel blue rope - For now
jimo is offline
post #7 of 9 Old 02-13-2015, 06:40 PM
Quick check for shift linkage is to see if when shifted to neutral, the lever should fit right to the bottom of the neutral notch. If it binds up on either side of the notch, the linkage is mis-adjusted or bent. Sometimes you may need to rock the bike to get it tinto gear. The one way bearings when they start sticking makle that hard to do. There is a good thread on here describing the replacement procedure cpmplete with pictures. Check it out, lots of good info.
2013 Outlander 650 Max XT
BRP fairing, mirrors skid plates and rear box
SYMTEC hand/thumb warmers
Trapper front box
GARMIN Montana 600
styk is offline
post #8 of 9 Old 05-23-2016, 09:31 AM
i had the whining noise in park and neutral 4 hours later the plastic washer behind the secondary blew apart blowing the belt off. this was after i was told it was normal
2015 can am 500 max, zilla tires, boss sound system
paintblr is offline
post #9 of 9 Old 05-26-2016, 06:03 PM Thread Starter
I was told by my dealer, it whines cuz the clutch free rolls, same as the ski-doos. Lol never had problems with the clutch yet and its over a year old, with 7300 kms on it lol
Only major problems I've been having with it, has been my brakes. I'm always losing them.
Go Back   Can-Am ATV Forum > Can-Am ATV Discussion > Can-am 2015 Models
650XT Whining noise firetech1024 Can-Am Outlander 6 05-05-2014 07:40 PM
37 hrs on rene1000.. bad whining noise..?? help plz downsouthRENE1000 Can-Am Renegade 3 05-09-2012 08:12 PM
Belt Whining Noise jdlivewell Can-Am Outlander 10 08-02-2010 07:08 PM
Whining noise bcunning Can-Am Outlander 9 07-20-2010 02:14 PM
Whining noise RiverRat Can-Am / BRP 20 11-06-2006 09:15 PM
