2012 Can-Am Renegade 500 Overview - Can-Am ATV Forum
post #1 of 2 Old 07-11-2011, 10:59 AM Thread Starter
ATV Junkie
dascrow's Avatar
2012 CAN-AM RENEGADE 500 ATV
Offering the ultimate in value and trail performance, the 2012 Can-Am Renegade 500 has the crossover sport quad market covered. The 500-class model has class-leading power, integrated 4x4 versatility and the Can-Am DNA to please any trail rider looking for a stimulating ride. Its V-Twin Rotax engine, race-tested suspension package and Visco-Lok front differential makes mud and rocks a blast, not a chore.
CAN-AM RENEGADE 500 ATV HIGHLIGHTS
» Renegade-specific transmission calibration
» RS-Type double A-arm front suspension with dive-control geometry
» RS-Type Torsional Trailing arm Independent (TTI) rear suspension with no scrub, 75% fewer moving parts
» Get-on-and-go continuously variable transmission (CVT)
» ITP Holeshot ATR tires
» 50 pounds (23 kg) lighter than the Outlander 500 model
» Convenient, 1-gal. (3.7 L) storage compartment
» Full floorboards with aggressive foot pegs and kick-ups.
» Front and rear High-Pressure Gas (HPG) shocks with five-way preload adjustability
» Separate front and rear braking control
RENEGADE 500 FEATURES AND BENEFITS
ROTAX 500 V-TWIN ENGINE
The 80o SOHC V-twin engine supplies 40.4-horsepower, has four valves per cylinder and is fed by a 46mm throttle body and two VDO Siemens‡ fuel injectors. The intelligent electronic fuel injection system automatically maintains peak perfor- mance, regardless of temperature or altitude, and contributes to the liquid-cooled engine’s potent power and seamless delivery. And the progressive throttle system creates manageable power for slow-speed, technical climbs or high-speed sprints.
VISCO-LOK FRONT DIFFERENTIAL
Visco-Lok is a progressive, auto-locking front differential system that transfers power from one slipping front wheel to the one with more traction. Automatic means just that and requires no buttons, levers or switches for you to engage. Just focus on the terrain and let Visco-Lok take charge of supplying supreme traction when 4x4 is needed. The system was designed to be indistinguishable to you, which means no wheel hop or driveline wind-up or noticeable changes in steering effort. And it locks up to 100% without a rev or speed limiter.
RS-TYPE FRONT SUSPENSION
The double A-arm front suspension was the developed using feedback from Can-Am racing R&D and proven engineering. Strategic use of aluminum upper A-arms reduced weight and dive-control geometry maintains positive control and reduced roll in aggressive cornering. The end result is durable suspension that can handle severe riding conditions and provide a smooth ride on a casual trail adventure.
RS-TYPE TRAILING TORSIONAL INDEPENDENT (TTI) REAR SUSPENSION
The TTI system maintains unmatched control and stability when compared to competitive rear suspensions. It is designed to eliminate wheel scrub, wavering and, in turn, supply a smooth, supple ride. Trailing arm design provides excellent control and stability, especially in rough terrain, by eliminating scrub. Plus, TTI has up to 75% fewer parts than competitive designs and significantly decreases tire wear.
MOTION-CONTROL SHOCKS
The Renegade 500 ATV’s high-pressure gas (HPG) shocks offer a smooth ride for trail riders and racers.
SURROUNDING SPAR TECHNOLOGY (SST) FRAME
The single-spar SST frame is lighter and stronger than a traditional tube-style chassis found on competitive machines. Other benefits include a class-leading power-to-weight ratio and a reduced center of gravity.
FOUR 60W PROJECTOR BEAM HEADLIGHTS
Nighttime visibility is enhanced thanks to the 500’s 240-watt candlepower, which mimics lighting system found on luxury automobiles.
12-INCH (30.5CM) CAST-ALUMINUM WHEELS
Rolled edge rims with rolled aluminum are mated with sharply styled cast-aluminum centers are as durable as they are attractive.
25-INCH (66CM) ITP HOLESHOT ATR TIRES
Proven Holeshot ATR tires offer all-around trail performance and supreme traction.
INBOARD DISC BRAKES
Located inboard on the chassis, the disc brakes are better protected from mud and debris and centralize mass to boost handling.
DIGITALLY ENCODED SECURITY SYSTEM (D.E.S.S.)
The innovative D.E.S.S. is the industry’s first standard anti-theft device. Electronic code in key must match code in ECU to start.
dascrow is offline
post #2 of 2 Old 09-21-2011, 11:29 PM
This is sweet.
philp37 is offline
Go Back   Can-Am ATV Forum > Can-AmForum.com > Can-Am ATV & Forum News
Tags
2012-can-am-renegade, 2012-renegade-500
2012 outlander 1000 and renegade 1000 manos Can-Am / BRP 336 07-17-2015 04:53 PM
2012 Can-Am Renegade 800 Overview dascrow Can-Am ATV & Forum News 0 07-11-2011 11:16 AM
2012 Can-Am DS450 Model Overview dascrow Can-Am ATV & Forum News 0 07-11-2011 10:32 AM
2012 xmr Donna Can-Am Outlander 31 04-12-2011 06:48 AM
New! DBO800M Mudrunner kit / CVT overview helix Dalton Industries 11 10-26-2010 07:02 PM
