2016 Can-am Renegade X mr - Can-Am ATV Forum
post #1 of 11 Old 09-18-2015, 09:07 PM Thread Starter
ATV Junkie
dascrow's Avatar
The all-new, awe-inspiring Can-Am Renegade X mr 1000R further expands BRP’s specialized and dominating line of mud-specific ATVs and side-by-side vehicles. A pioneer in the mud-riding niche, Can-Am now offers the widest selection of dedicated mud vehicles for enthusiasts. The Renegade X mr 1000R perfectly blends its industry-leading performance with precision handling and unmatched sport 4x4 capabilities to create the new highpoint for those serious about mud riding. And its menacing appearance is unmatched in the industry.
The Renegade X mr 1000R uses the revamped 89-hp, 80o 976cc liquid-cooled V-twin DOHC, eight-valve Rotax engine from the Renegade 1000R, which has 9% more power and leads the ATV industry in performance for 2016. Based off of the SST G2 single-rider chassis, the newest X mr ATV wears 30-inch (76.2 cm) Gorilla Axle Silverback tires on 14-inch (35.6 cm) cast-aluminum wheels with integrated, color-matching beadlocks, FOX† Performance Series 1.5 PODIUM† RC2 piggyback shocks and receives a snorkeled CVT intake and exhaust as well as a snorkeled engine air intake for extreme mud performance. Tri-Mode Dynamic Power Steering and Visco-Lok QE front differential enhance handling and traction in crawls through the mud.
The Renegade X mr is also outfitted with X-package components (graphics, seat cover, handlebars with grip handle and bar pad, full-wrap wind deflectors and bumpers), giving a nod to its racing heritage. Additional standard equipment includes 3,000-pound winch, skid plate, quad projector lighting and D.E.S.S. Like its siblings, the Renegade X mr 1000R also has the revised one-year (1,500 km / 932 mile) break-in maintenance requirement. Add two striking color schemes (Hyper Silver / Can-Am Red or Hyper Silver / Octane Blue) to the mix, and the Renegade X mr 1000R will leave a lasting impression when it’s ruling over the competition.
PERFORMANCE
89-hp Rotax V-Twin engine
Renegade X mr 1000R
The new 89-hp, 80o 976cc liquid-cooled V-twin DOHC, eight-valve Rotax engine in the Renegade X mr 1000R has lead the ATV industry in performance. Shared with the Outlander X mr 1000R, the engine gained a 9% power increase via new piston designs, a new 54 mm throttle body and the new engine head from the Can-Am Maverick.TM EFI ensures optimal performance from the engine at all times.
Mud-ready CVT with lower “L” gear range
NEW Rotax 1000R
The CVT (Continuously Variable Transmission) means no shifting is required. The system includes standard engine braking with High, Low, Park, Neutral and Reverse gears. The CVT housing has 13 bolts to ensure a proper seal and also includes an integrated drain plug. The Can-Am X mr family includes an extra low range “L-gear” with a softer engagement and improved throttle control for low-speed riding and better traction in heavy mud.
Integrated CVT intake and exhaust system
Can-Am has made sure that critical components like the CVT intake and outlet, as well as the engine intake are located as high as possible on the ATV. We placed them in the pod directly in front of the handlebars and high above the muddy, wet conditions below.
Large radiator
The larger radiator, with its class-leading 27 kW of cooling capacity, on the Can-Am Renegade X mr 1000R ensures all-day rides in the deep mud.
Dual-room, no-tools air box
The X mr family of ATVs have their no-tools air box placed at a high and centralized location for filtering and processing air. A dual-room air filtration design captures dirty air in one portion of the box and clean air in another section before it sends the air to the engine. Specific to the X mr, the airbox also features an easy access drain. The mud enthusiasts will also appreciate the higher air intake ensuring performance in mud and water.
High-grade exhaust and silencer
The Renegade X mr 1000R has a performance-inspired exhaust system, including and a durable end cap/cover, that produces a throaty and impressive exhaust note, yet adheres to strict dB and emissions standards.
HANDLING
FOX PERFORMANCE SERIES 1.5 PODIUM† RC2 piggyback adjustable shocks
These high-performance shocks have high- and low-speed compression, rebound and preload adjustments to allow riders the flexibility of tuning the suspension to fit the terrain and riding style. The FOX PERFORMANCE SERIES 1.5 PODIUM RC2 piggyback shocks also enhance the 2016 Renegarde X mr 1000R ATV’s handling and performance in challenging conditions.
14-inch (35.6 cm) cast-aluminum beadlock wheels
The large cast-aluminum wheels give the Renegade X mr 1000R an aggressive look and wear color-matching and fully functional beadlocks to ensure performance in the deepest of mud holes.
30-inch (76.2 cm) Gorilla Axle Silver back tires
The proven 30-inch Gorilla Axle Silverback tires were chosen for their exceptional mud-riding characteristics. Developed by Gorilla Axle, these tires have been tested
in the challenging mud holes in the Southern U.S. They have tall lugs and an aggressive tread pattern for superb mud performance.
Torsional Trailing arm Independent (TTITM) rear suspension
Using far less moving parts than competitive systems, TTI was designed to eliminate scrub and camber changes when the suspension works up and down and keep the quad in straight line. Unique to Can-Am, the proven Torsional Trailing arm Independent rear suspension offers increased rigidity. This suspension setup also includes a removable external sway bar and lower pivot points for geometric squatting to improve traction and the transferring of power to the ground.
Double A-arm front suspension with dive-control geometry
The Renegade ATVs have a race-proven double A-arm configuration with motion-control shocks and five-way adjustable preload settings. Dive-control geometry tightly controls the roll-center, especially when entering corners.
Tri-Mode Dynamic Power Steering (DPSTM)
Calibrated specifically for aggressive trail riding and racing, the Tri-Mode DPS system features three modes (MIN, MED and MAX) allowing riders to select the desired amount of steering assist for the terrain and conditions.
Visco-Lok QE‡ front differential
The Renegade X mr 1000R model includes the Visco-Lok Quick Engagement calibration, giving the front differential an even shorter responding time.
SST G2 frame
The Renegade X mr 1000R uses the proven one-up Surrounding Spar Technology (SST) G2 frame and shorter wheelbase compared
to its sibling, the Outlander X mr 1000R. The welded-steel SST frame offers increased structural integrity and handling with fewer parts.
214 mm hydraulic disc brakes
Two large 214 mm disc brakes with twin-piston calipers up front and two, twin-piston caliper and 214 mm hydraulic rear disc brakes comprise the Renegade ATV braking system. It includes separate front and rear hand brake levers
RIDER-FOCUSED DESIGN
NEW Revised maintenance break-in
The early break-in maintenance requirement is no longer necessary on the Renegade, saving consumers time and money in the long run. The first maintenance required is after one year (or 1,500 km / 932 miles) from 10 hours (300 km / 186 miles).
Easy-to-use maintenance center
Easily accessible and out of the elements under the seat, a centralized maintenance area offers easier access and improved protection. The rear brake fluid reservoir, solenoid starter, battery and relays are also conveniently located under the seat.
3,000-pound WARN winch
A 3,000-pound (1,361kg) WARN winch could come in handy should the mud prove too troublesome for you or your riding partners.
Front bumper and rear push bar
The rugged front bumper and rear push bar protect this powerful mud machine in the toughest of conditions and also provide an unmistakable look.
NEW Handlebar wind deflectors with aluminum braces (full wrap) and grab handle Aggressive trail riders love the added protection from the color-matched wind deflectors. Coming from the BRP expertise in snowmobile, the unique grab handle offers more leverage and confidence in tricky maneuvers.
Aluminum taper-profile handlebar with square pad
High-grade 6061-T6 aluminum, taper-profile handlebars with a square racing pad are included on the X mr.
Mudguards
Mudguards run on the wheel wells to complete the premium look and give the rider further protection from the mud.
Standard skid plate
The high-strength skid plate is made from proven materials and is designed for supreme protection and has the ability to slide over certain obstacles.
625-W magneto
The X mr package provides a more-powerful magneto with a 625-W power output.
Powerful lighting
The Renegade family includes four stylish 60-W projector-type headlights (240 W) for improved nighttime clarity and trail visibility. The taillights offer a
seamless design that blends in with the rear plastic and offers increased visibility for trail riding.
Large fuel tank
The fuel tank is rated to hold 5.4 gallons (20.5 L) of fuel.
Full floorboards with raised pegs and kick-ups
The Renegade ATV family wears full floorboards for added protection and coverage from mud, water and debris. The aggressive foot pegs with kick-ups provide
solid footing in mud.
Digitally Encoded Security System (D.E.S.S.TM)
D.E.S.S., the lone factory-installed anti-theft device, comes standard. Two keys (normal and performance) are included.
NEW Colors & Renegade family styling
The Renegade X mr 1000R, with its highly recognizable and aggressive styling, is available in two striking color schemes: Hyper Silver, Black & Octane Blue or Hyper Silver, Black & Can-Am Red.
dascrow is offline
post #2 of 11 Old 09-18-2015, 09:15 PM Thread Starter
ATV Junkie
dascrow's Avatar
dascrow is offline
post #3 of 11 Old 09-18-2015, 09:17 PM
Premium Member
Poseidon's Avatar
You forgot the second color option!
2013 Can Am XMR 1000
4" Catvos with Turner Axles
32" Silverbacks on SS312's
QSC/STM with Maverick Belt
Muzzy Full Dual Exhaust with VFJ Digi-tuner
Max Rear Seat
Amsteel Blue Synthetic Winch Line
Billet Pistol Grip "Can-Am" Shifter
2013 Grizzly 700
28" Zillas on Black SS212's
JBS Hot Rod Sheave, 16g Weights, and Purple Spring
Warn 2500 Winch
GPSmap 62sc with RAM Mount
Yamaha Rear Cargo Box
Yamaha UHMWPE Glide Plate
Life's journey is not to arrive safely at the grave in a well preserved body,
But rather to skid in sideways totally worn out shouting...
What a Ride!
My YouTube page - Poseidon's Lair
Poseidon is offline
post #4 of 11 Old 09-18-2015, 09:40 PM
XTreme's Avatar
2016 Can Am Outlander XMR 1000R Digital Camo/Manta Green
- Yoshimura Pipe
- BRP Passenger Seat
- BRP Heated Grips & Thumb w/ MGRAM Fix
- BRP 60" Alpine Flex Plow
- BRP Skids (Nicest Skids Out There)
- MTI M21 LOK Wheels 15x7
- ITP Blackwater Evolution 30x10x15
- KFI Tiger Tail w/ MGRAM Mods
- Rigid Midnight Series LED Cube Low Beams w/ Bigunner1 Mounts
2015 Arctic Cat M8000 Ltd. Orange/Black/White
- HPS Can
- Mountain Addiction Cans & Packs
2012 Can Am Outlander XT 800R Black - SOLD
XTreme is offline
post #5 of 11 Old 09-19-2015, 07:46 AM
christisk's Avatar
Radiator Relocate.
15K+ machine $$$$$$$$$$$$$$$$$$
I will go buy a car for that.......too much $$$$$$$$$
christisk is offline
post #6 of 11 Old 09-19-2015, 09:51 AM
christisk's Avatar
Are those bead lock rims? I know the regular Rene has them but on the XMR why the Rene has them and not the Outy?
What does the front bumper do differently for mudding that they felt the need to add it? I love that in recent years Can-am decided to let us have other colors than god awful yellow so I like there is new colors. I like that they at least give us that choice too.
How deep are the lugs on those tires?!
Silver backs on Outy XMR 1000/850
Mudzilla's on Outy XMR 650
now a different tire on rene XMR....?? thoughts?
what makes it ugly? color scheme? It's still a renegade, not that much different than a rene with rad. relo. or aftermarket front bumper. What's ugly? the tall thing on front? the design of the bumper?
EDIT; they need to offer those colors without the accents.
post #7 of 11 Old 09-19-2015, 10:27 AM
XTreme's Avatar
Yes. Yes.
- Yoshimura Pipe
- HPS Can
XTreme is offline
The Following User Says Thank You to XTreme For This Useful Post:
christisk (09-19-2015)
post #8 of 11 Old 09-19-2015, 10:49 AM
Premium Member
Poseidon's Avatar
Standard 30" silverbacks just like the Outy XMR 1000. Lugs should be 2". Personally, the choice of "unicorn" snorkel design and front bumper take away from the looks.
Max Rear Seat
2013 Grizzly 700
Warn 2500 Winch
What a Ride!
Poseidon is offline
The Following User Says Thank You to Poseidon For This Useful Post:
post #9 of 11 Old 09-19-2015, 11:56 AM
christisk's Avatar
Oh. the picture makes the lugs look shallow. =/
post #10 of 11 Old 09-19-2015, 11:20 PM
Why you complain?
It is a nice new product
The ones hwo like to rebuild on their own
Great good looking plastic on footrest
And original snorkel from factory
I like it
Canamnew is offline
The Following User Says Thank You to Canamnew For This Useful Post:
BigBlock (09-20-2015)
Go Back   Can-Am ATV Forum > Can-AmForum.com > Can-Am ATV & Forum News
2016 maverick xc vs 2016 commander 800r dps SWAMP BOMB Can-Am Maverick 4 09-10-2015 10:03 PM
2016 Can-Am® Renegade® Family DrumsOfGrohl Can-Am 2016 Models 2 08-14-2015 10:40 PM
renegade 2016 Shotcaller660 Can-Am / BRP 7 06-16-2015 07:13 PM
2016 Renegade? jazzyj Can-Am 2016 Models 0 06-03-2015 11:24 PM
2016 Renegade westinbrad Can-Am Renegade 3 01-10-2015 09:55 AM
