Will any good quality lube work for lubing up the lube points on an outlander, or do you need a specific type?
Cam An 12133 posts · Joined 2007 Add to quote Only show this user #2 · Jul 6, 2008 I use http://samsgarage.com/green_grease.htm... It is a waterproof full synthetic....you can get it at autozone or oreilly..
QUADAHOLIC 9462 posts · Joined 2006 Add to quote Only show this user #3 · Jul 6, 2008 Synthetic water-wash-out resistant, is good for the u-joints and a-arms. It's been established that you want to stay away from moly-based stuff in the u-joints.:2cent:
K KINGFORCE-X 118 posts · Joined 2008 Add to quote Only show this user #4 · Jul 6, 2008 what about marine grease?
QUADAHOLIC 9462 posts · Joined 2006 Add to quote Only show this user #5 · Jul 6, 2008 Marine grease is good. Here is some more info on the subject(about halfway down), along with several other threads found by searching "grease".
M mattinthehat 164 posts · Joined 2007 Add to quote Only show this user #6 · Jul 7, 2008 I use the brp seadoo grease. seems to work well.
