07-10-2008, 10:06 PM
Member #4978
Ijust installed hid lights But when i turn them on it kills the motor but if i turn the lights on then start the motor its fine any ideas?
07-11-2008, 07:51 AM
There have been a few guys here that run, HIDS, I think I remember talk of that issue.
They got a "kit" off ebay and had to modify it a certain way to run correctly. Maybe if you search, you can find out who and PM them for help. :2cent:
07-650-MAX
Ricochete ~ Crutchfield 2+1
07-11-2008, 05:47 PM
Member #4978
my HID bulbs are a high and low set up. the high is HID and the low is a normal burning bulb. my kit came with two ballasts one for each bulb. If i only hook up one ballast everything works normal. But two kills the system and my display says no ECU communication. Then, i have to disconnect the battery before i can even get it to idle normal. Everything was hooked up as stated in the instructions.
1. disconnect the stock bulb.
2. remove and install HID
3. connect stock light plug to HID controller
4. connect positive and negative to HID bulb
I tried a couple different ways to run them, for example: I ran 12V straight from the battery through a switched relay and it still shocks the system and shuts down? The only way the engine will run is if you have ignition off, turn lights on and then start the engine it seems to be fine. but if you switch lights off and back on it will die IDK PLEASE HELP~!!
07-11-2008, 06:09 PM
First Name: Mike
Member #3555
Badazz, I think this is the thread Q is referring to.
clicky
'07 800 XT mine
'07 500 XT hers
Frame mod by weewane
Come ride Southern WV
07-11-2008, 07:44 PM
Member #4978
Thanks Trailrider.I found out if i hook up 2 batterys it works great
07-11-2008, 07:53 PM
trailrider2 wrote:
clicky
Thazzit.
07-650-MAX
07-12-2008, 07:59 PM
Member #4978
I just charged the battery to full charge and every thing works great now. Thanks for your help
