08-13-2008, 03:49 PM
Member #888
I lubed my one way bearing and found that part #12 the Thrust Washer is split. It has a split like a lock washer is my best description but no separation. It also is flat on one side and has a slight ridge on the other. You have to look very close to see that it is split. I only know it is split because I was cleaning it to re-lube itand the paper towel hung up on it when I was cleaning it. The Thrust Washer sits on top of the spring cap on the drive pulley ( aka primary) and rests against the one way bearing and primary clutch spring.Wish I could post a picture!!
Can anyone confirm for me that it should be one solid piece with no split in it?? I am planing a ride and don't want to go without the new part installed but what do you thinkwill it be OK.. This will be a ten day ride with maybe 200-300 miles.. Oh well,it seems to run great with theThrust Washer installed, but I don't know how long it will last. I may throw in my tow rope.I should have just left it be and ridden it, that way I wouldn't think about it.
Thanks, WB
2006 Outy 800 EFI HO Green,
2003 Yamaha Grizzly 25" Maxxis Bighorns,
1982 Honda ATC 110 & 185S
08-13-2008, 04:03 PM
Member #888
Part #12 is called the Friction Washer not the Thrust Washer as I refered to it above. Sorry for any confusion.
WB
08-13-2008, 05:05 PM
Member #2217
Bill, I don't believe that is supposed to be split as you have described. It just doesn't sound right to me, but its been a while since I had mine apart so I can't say so for sure. Better safe than sorry though.. might order one just in case and keep an ear and eye open for any weird noises or operation.
PRP Steering Stabilizer
08-13-2008, 05:12 PM
Member #999
I don't think that mine is split either, but I have heard of people taking their washer out and it was cracked.
06 Can Am 800
Stealth Snorkel
Dalton Clutch
Frame Mod
HMF Penland
Extreme Winch
EBC SV Brake Pads
08-13-2008, 05:20 PM
Member #888
10-4 cracked is a better description. I spoke to the parts man at Parker Yamaha and he said it definitely is not split so I need a new one. I ordered it from him.Thanks for the reply.
WB
08-13-2008, 10:50 PM
Member #4004
Mine was split upon a cleaning too. I needed to ride the next day so I superglued the ends back together to get by. No change in clutch action since but I'll be pulling it apart to do a dalton install - I'm curious to know if it's still in one piece or laying in the bottom of the belt cover.
I'll confirm it's supposed to be one piece as my replacement is out on the shelf in the garage awaiting installation. If the superglued one is still in tact, I'll keep it as a spare.
08-13-2008, 11:46 PM
Member #4276
Seems like mine was cracked at one time. I think I just trashed it altogether, I don't ride mud though.
Home of the 975cc 90RWHP N/A bolt-on big bore kit!
-High perf cams available!
-51 MM Throttle Body Boring,
-Custom head work
-Billet Heads
-Billet Jugs
-'07 260RWHP Alky Renegade Turbo, ViPec ecu, Billet STM clutches
www.mrrpmcycle.com
08-14-2008, 12:50 PM
First Name: Small town guy
Member #4499
Its broken. Part # 420460430.
Ride it like you stole it!
2008 Renegade 800 - 14" SS106 /w XTRs - Full exhaust wrap with HMF pipe - A-Arm guards - Skid plate - Rear rack - Handguards /w aluminum handlebar end caps - Stealth snorkeled - Carbon fibre heat shield - Overfenders - X team seat - stickers (+5 MPH)
08-14-2008, 01:21 PM
Member #1104
Hears a easy way to clean the secondary clutch
08-14-2008, 01:22 PM
Member #1104
420460430 friction washer, can am brp 420460430, can-am cvt cleaning, can-am cvt clutch clean lube, canamforum how to clean clutch, canamforum what needs to be lubed, clean cvt, cvt clutch cleaning, cvt lube, cvt lubrication, how to clean a primary cvt on a yamaha grizzly, how to clean cvt, lubricating can am primary clutch, secondary clutch clean, yamaha atv cvt lube
