08-17-2008, 11:22 PM
Member #5103
One more question. If this is the same as having a clutch kit with different springs and different weights, what is the advantage of the helix mod vs the clutch kit? The helix mod does the exact thing as the dalton kit?
TEAM GORILLA POWERED BY CAN AM
2008 CMR MUD BOG NATIONAL CHAMPION
08 800 Max xt built for MUD RACING
REGAN #44
08-18-2008, 12:05 AM
Member #4276
It increases belt pinch, to help keep the belt from slipping. When larger tires are put on, the engine needs to rev to help pull those big tires. The only way a primary mod can let the motor rev is to install lighter weights, this lets the motor rev, but the belt has less tension (pinch) on it. This mod doesn't effect the stall speed like changing primary springs does, or effect what the motor does when it's wound out. Although all the clutch kits can be used with the helix mod, for even more tunability.
It's cheaper too!
-High perf cams available!
-50 MM Throttle Body Boring,
-Custom head work
-'07 200RWHP Alky Renegade Turbo, ViPec ecu, Billet STM clutches
08-18-2008, 01:45 AM
Member #1104
mrrpm wrote:
You probably could put your whole clutch back stock, except for the helix mod.
I would agree with you if I was at sea level but most of my ridding is at over 7000ft.I would like to try your helix though.
08-18-2008, 09:36 AM
Member #4276
The clutch mods work the same at any altitude, but they might have to be adjusted, depending on the altitude, for best performance.
-Custom head work
08-18-2008, 09:57 AM
Member #3840
Nice job Greg
Russell Coker
EFI TUNING AND CLUTCHING BY
PIT PROVEN PERFORMANCE
CMR SEASON FINAL POINTS STANDINGS
1st Open/Pro Class Swampcross
1st Class 1 Mud Bog
3rd Class 2 Swampcross
3rd Class 2 Mud Bog
PSR SEASON FINAL POINTS STANDINGS
2nd Lite Class
2nd Pro B
08-18-2008, 10:03 AM
Member #1300
Looks Great,As soon as I get mine back I will be testing, got a personal mud hole to go through. MRRPM did you try to call this weekend, I was up on a ladder and the wife calls out as says your phone is ringing and I didn't recognize the number so I didn't answer. If that was you sorry man.
Walter
2007 Outty 800
Vision Black Bruiser wheels with 26" ITP 589\'s
ITP with 29.5" Outlaws
Completely snorkled
HMF Slip On
Something, Something in my clutch
Team Outty #324
08-18-2008, 01:40 PM
Member #4276
Yes it was me, I got the helix's machined, just wanted a few specifics on the bike. It is going out today, just be sure and post the results on here when it is installed.
For those reading this, hemertwv is experienced with sled clutches, and we should get a real accurate review on this mod. I think the big tire/ mudder guys will love this!!
-Custom head work
08-18-2008, 06:11 PM
Member #5005
mrrpm i will be sending you two if thats ok i would like to try these soon at some up coming race events
Mat Price
Bitmore Performance Race team
08-18-2008, 06:25 PM
Member #4276
Sure, send them on, the machine is still set up. PM me for my contact info.
-Custom head work
08-19-2008, 06:30 PM
Member #1206
So would this mod help with pulling a loaded trailer slowly up and down tight wooded trails? I have been using my bike to pull cut lumber off the trails. Thought I smelled the belt smoke once. If it did, it wasn't much. My bike is pretty much vanilla except for I have done the CowTown clutch to help smooth out the takeoff. It lowered the takeoff RPM's some. But I was told it might let the belt slip. I would like to do something to help increase the belt pinch, and this seems to be the ticket. :ban:
2006 Outlander 800max XT
Cowtown clutch mod
Ricochet skids
Reciever hitch
| Visitors found this page by searching for these keywords: |
renegade 800 65 helx mod, canamtesting, can am testing, where to get a 650 helix
