Super Big Bore Kit!
This is a discussion on Super Big Bore Kit! within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; mrrpm wrote: Yes, the valves are being replaced with larger ones, along with a larger cam. They already flow better than a fairly good small ...
  #21
Old 09-12-2008, 05:36 AM
TorkMonster's Avatar
Member #4956
View TorkMonster's Photo Gallery(0)
mrrpm wrote:
Yes, the valves are being replaced with larger ones, along with a larger cam. They already flow better than a fairly good small block V-8 head, wich displaces more than this engine does.
For a n/a setup, if stock valves and cam are used, the usable rpm range will go down, which should work good with the rpm limited stock computer, if someone wanted to do such a thing.
Just WHAT are you trying to say here MR.RPM?????
In YOUR words from the LAST part of quote, will be ALOT of people interested.....
I will be awaiting results as well as VIDS AND PICS OF any progress you may or may not have... GOOD OR BAD.
08 800 Outty Yellow
#435 Team Outty
650 Helix
Dalton Kit
25 inch BigHorns
28 inch TITAN 589\'s-stock rims
2inch RubberDown Customs Lift(Bracket front-Spacers Rear)
HMF
Power Commander
Snorked to the POD
Custom Stereo
What Else Do You Need???
04.5 PoPo SP700
too many mods to list
  #22
Old 09-15-2008, 11:35 PM
mrrpm's Avatar
Member #4276
View mrrpm's Photo Gallery(0)
More pics of the jugs after the water jackets have been milled.
-High perf cams available!
-103HPQ Comet Clutches for Can Ams,
-50 MM Throttle Body Boring,
-Custom head work
-\'07 200RWHP Alky Renegade Turbo, ViPec ecu, Billet STM clutches
  #23
Old 09-15-2008, 11:46 PM
cc1999's Avatar
Member #682
View cc1999's Photo Gallery(307)
Nice.
Whenever you get to working on boring out the bottom end housing, would you mind posting a couple pics of that process. I am thinking your pretty much going tol have to split the case, just wondering what all is going to be involved with that part of the up fit. I have never seen that done before to an engine case, the boring it out part that is.
Current Quads:
2010 Sportman 850 XP EPS
Stealth Black
2009 Sportsman 850 XP EPS Stealth BLACK
with Bighorns on 14 inch Hipers, Handguards, storage boxes, backrest, Sport bumper, Pia lights, 35oo# Winch w/wireless remote, rear work lights.
2006 Outlander 840 Black,
with Woods pipe, Cowtown Clutch work, Diamond G/Chapman heads/ Diamond G Cams / Power Commander III, Renegade brakes, XT hand guards, Bighorn Radials on Black type 7 rims.
Recent Past Quads:
09' King Quad 750 W/PS,08' Polaris Sp800 X2 \ 09' Outlander 800R \ 08' ThunderCat 1000 \ 06' Diamond G Outy 800 \ 08' Honda Rincon 680 EFI \ 08' Polaris 800 RZR \ 07'Renegade 800 \ 06' Outlander 800 XT \ 06 Outlander MAX 800 \ 05' Polaris 800 Sportsman \ 04 Susuki Twin Peaks (Kawi prarrie) 700.
  #24
Old 09-16-2008, 01:20 AM
mrrpm's Avatar
Member #4276
'Course I ain't done it yet, but the plan is to run a round bar thru the main bore in the cases, (bolted together, obviously), sit the bar on vee blox, roll the motor around until the jug surface is flat, the center up on the existing bore, then, cyle start. It doesn't have to be perfect, as the hole is just that, not having any close fit or anything, the jug liner just hangs in there. If I were machining the jug surface, however, I'd indicate the surface in flat and true with the spindle, to get it dead nuts on, heck, might anyway. We do V-8's like this all the time. I have a fixture to indicate 90 degree V-8's with, which makes the setup time a lot better, but to just do this one block, I'll just indicate it in. If i were gonna do a few, I'd make a fixture for this also, then, just bolt it down, get the deck straight up, and go.
-Custom head work
  #25
Old 09-16-2008, 12:09 PM
Member #4626
View karistep's Photo Gallery(0)
mrrpm
What is the motec model that you use ?
2010 Renegade 800R EFI X xc
MUZZY Full Exhaust, Power Commander V Autotune, 912 MRRPM Kit, Dalton Kit aluminum rivets in
  #26
Old 09-16-2008, 01:13 PM
mrrpm's Avatar
Member #4276
karistep wrote:
mrrpm
M4
-Custom head work
  #27
Old 09-16-2008, 07:06 PM
mrrpm's Avatar
Member #4276
Jug with liner installed.
-Custom head work
  #28
Old 09-16-2008, 07:09 PM
looking good greg.
  #29
Old 09-16-2008, 07:11 PM
mrrpm's Avatar
Member #4276
Pic of stock piston in big bore jug.
-Custom head work
  #30
Old 09-16-2008, 09:55 PM
cc1999's Avatar
Member #682
Got to love that pic with the little piston setting in there. LOL GD thats looking good. I can't wait to see how it all turns out.
Current Quads:
Stealth Black
Recent Past Quads:
