10-22-2008, 01:51 PM
Member #5601
Hi,
I am new to this board. I have been lurking for a while and just picked up a new leftover 08 Outlander Max XT. It is Camo and I don't like all the stickers on the machine.
Have any of you had experience with removing the stickers from a Camo Outty? I was tempted to try the hair dryer and peel it carefully trick, but I am unsure as to how durable the camo is. Anybody tried it?
08 800 Max XT Camo
10-22-2008, 02:44 PM
Member #504
i removed all the horrible looking warning stickers with my pressure washer. what the pressure washer didnt take off, i peeled of while cold. i found if i warmed the sticker up first, the adhesive would stay on the atv and not come of with the sticker. It made for messy clean up.
When removing the stickers cold, remember to peel fast like a bandaide .. faster the better.
Good luck.
Why tiptoe thru life, only to arrive safely at death ?
Team Member #112
10-22-2008, 02:49 PM
Member #1348
I took all mine off with a hair dryer just don't get too hot. Some left a little glue but just used a cleaner and off it comes.
2010 Canam Outlander 800R XT
10-22-2008, 03:18 PM
Member #4699
WD40 works pretty good for removing the adhesive also. I removed all of mine with a blow dryer and peeled them off. Then sprayed the area with WD40, let it soak and cleaned off the remaining adhesive.
06 Outty Max XT
HMF Utility w/pentland insert
Works Pro G Series
Precision Stabilizer
PC III
25\' Horns on ITP C6 Black
27\' Mudgears on Climaxes
2008 Yamaha Raptor 700R Special Edition
Barker in frame duel exhaust
Power commander III
Trinity intake and K&N
CRJ Performance front and rear lowering kit
10-22-2008, 07:04 PM
Member #5218
I removed all of my warning stickers by just peeling them off...............no residue or nothing left behind............try that first before you decide to buy some miracle goo remover that does not even work....:2cent:
\'08 800XT .RICHOCHET SKIDS. .RENE FOOT-RESTS.
CAMO .JUST GETTIN STARTED.
10-22-2008, 07:37 PM
Member #3961
mine came off with just peeling the sides up and pulling gently, 2 years after it was made
07 800 max , xt front and rear brush guards added , xt 30 winch ,ricochet skid plates and ITP 26"XTR on ss108 (black)
10-22-2008, 08:03 PM
Member #4210
Camo on mine. Took my stickers off with a heat gun - just stayed careful with not getting too close. It left a slight glue residue that I remived with goof-off. No damage to the camo finish at all.
Jaybee
