12-06-2008, 01:35 PM
Member #5168
Can you buy a lower temp thermostat for the the Rotax motor. I have this motor installed in my Rhino and it is running at 210 with out any problems but would like to lower the temps alittle sense it's now under a motor cover getting less air then it did when it's in the quad. :coff:
12-06-2008, 01:41 PM
Member #5587
The stock T-stat opens @ 65° Celcius. I doubt if you can find one that opens at lower temp. You can just try to remove the T-stat, and replace it with a washer/gasket like the one in Cyl# 2. Do a T-stat search overhere. It's been covered a few times.
Gade 800 X with stuff
09 Outy 400 for the wife
12-06-2008, 05:07 PM
Member #5168
Thanks, sounds like people just remove it and install a washer. Anyone know what size washer to try?
12-06-2008, 05:25 PM
order the gasket/washer that goes in the rear cylinder.
The Following User Says Thank You to got wake? For This Useful Post:
12-06-2008, 06:07 PM
There have been several threads about lowering the operating temps here.
Also, there is(or was) a guy on Ebay that sells temp sensors, that run about 30 degrees cooler.
07-650-MAX
Ricochete ~ Crutchfield 2+1
12-06-2008, 07:53 PM
Member #5168
got wake? wrote:
Perfect thanks I'll do that. :dan:
05-12-2009, 04:37 PM
Member #5920
thx for the info, bro
