CLeaning out muffler? - Can-Am ATV Forum
This is a discussion on CLeaning out muffler? within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; I have a little mud in my muffler and is affecting the idle. What is the best way to clean it out? Just take the ...
Old 12-13-2008, 11:08 AM
Member #5844
View 08canam's Photo Gallery(0)
I have a little mud in my muffler and is affecting the idle. What is the best way to clean it out? Just take the muffler off and rinse? Thanks in advance.
2008 Can Am Outlander XT
Bayou Snorkles
Radiator Relocated
29.5 outlaws
2" lift
HMF (on order)
PC III (on order)
2002 Honda Rancher
Supertrap exhaust
K&N air filer
Re-jetted
Snorkled
2" lift
Bored .75 over
Old 12-13-2008, 11:19 AM
Wyldlander's Avatar
Member #2451
View Wyldlander's Photo Gallery(0)
I'm wondering how to do that too. would it rust if you washed it? also is there any paint i can use to get rid of any rust( make it look a lot newer) on my stock muffler?
2008 Outlander 650 max XT in Yellow,Full Ricochet skidplates, Amsteel synthetic line, 26 inch Maxxis Bighorn 2.0s, HMF Performance Utility pipe( in Yellow), HMF fuel controller, BRP rear box, Tigertail w/1.25 reciever, Gade footpegs, Kolpin/Moose overfenders, (1) gallon Rotopax fuel pack( just in case)
Cumberland ATV Riders
Southernoffroadriders
My Youtube channel can be found here:
http://youtu.be/0h8WlovZRA4
Old 12-13-2008, 11:22 AM
Revicm's Avatar
Member #3196
View Revicm's Photo Gallery(3)
I forget...does the can am have a bung in the bottom of the muffler? If so you could try removing it and blocking the exhaust hole with a rag and rev the motor to remove crud first. This is normally done to remove carbon but it might work for mud.:2cent:
Old 12-13-2008, 12:09 PM
TorkMonster's Avatar
Member #4956
View TorkMonster's Photo Gallery(0)
I would just take it out and wash and clean it......
I wouldn't worry bout ny rust or anything, as they get water and as you see mud in there just from riding it.... Least mine does.....
I think the stock mufflers though dont open.... I cannot remember either revicm
08 800 Outty Yellow
#435 Team Outty
650 Helix
Dalton Kit
25 inch BigHorns
28 inch TITAN 589\'s-stock rims
2inch RubberDown Customs Lift(Bracket front-Spacers Rear)
HMF
Power Commander
Snorked to the POD
Custom Stereo
What Else Do You Need???
04.5 PoPo SP700
too many mods to list
Old 12-13-2008, 12:38 PM
Revicm's Avatar
Member #3196
I know the polaris I had did...I think the can am does too but prolly better to remove and throw some water at it anyway.
Old 12-13-2008, 05:36 PM
Yep, the have the blow-hole underneath. But it's only like 1/4" or so. I'd just take it off, fill it up, swish around and drain. :2cent:
Old 12-13-2008, 08:51 PM
Member #2217
View fmj40's Photo Gallery(7)
If you are worried about water in there after you clean it just plan on running it for a bit once you rinse it out. Exhaust temps should be enough to dry it out. That and make sure to leave the plug out of it for a bit to let excess water drain out.
PRP Steering Stabilizer
Old 12-13-2008, 11:29 PM
weewane's Avatar
Member #1556
View weewane's Photo Gallery(0)
Yes there is a drain hole on the rear on the bottom of the pipe. problem with doing what you are talking about is there are like 3 or 4 chambers inside the muffler making it very very dificult to get all the water out. I had the same problem with my exhaust cloging up as well. What the problem is the holes for the spark arrestor gets all clogged up. On mine I took the pipe and cut it apart and modified the arrestor. After doing mine I did my buddies as well but without cuting the pipe apart and then welding it back together. All I did on his was used a large flathead screwdriver and slid it into the exhaust pipe at the tail end untill it bottomed out in the pipe. Then with a hammer hit it a few times to spread the pipe back open from the way it was closed. after you get the screwdriver in then twist it a few times to open the pipe a little bit more . next remove the screwdriver and fire the bike up and enjoy your new power.
07 can-am outlander 650 ( blk ss108's with 27in laws, 26in MST's on stock rims, rico skids, HMF swamp series (homemade mods = stereo, front only 1.5in pipe lift, 1.5in bracket lift, frame mod, stock exhaust mod, snorkel}
06 yamaha raptor 700r
I build and ship frame mods,& snorkel kits PM if interested
atv exhaust clogged
can you blow air through a muffler to clean it out
can you clean out a rear exhaust muffler
clean carbon from atv exhaust
cleaning a 1990 polaris atv muffler
cutting out the inside of a fourwheeler muffler
honda muffler drain plug
how often clean air exhaust muffler
how to clean a honda quad exhausts
how to clean carbon out of atv muffler
how to clean out a clogged 4 wheeler muffler
how to clean out the carbon on my atv muffler
plugged mufflers on can am
what cleans out an oily four wheeler muffler
whats the best way to bvget ried of oil off the muffler n back platic
