12-22-2008, 06:10 PM
Member #3461
OK, took someone's advice and got a button kill switch, horn and I am ready to wire it up to be street legal. Tried wiring many ways, and either get nothing or on all the time... HELP!
Reason tells me a kill switch is normally open, and pushing the button closes the switch. Is there a way to reverse one? How should the system be wired? Buy a different switch?
Thanks for looking...
12-22-2008, 06:53 PM
Hmmm...
I think a killswitch might be normally closed, and when you push the button it opens the circuit, .........maybe?
I put a horn on mine along time ago and used a "push to make" momentery switch. I used a relay and a very loud horn, 154 decibels (I think).
12-22-2008, 06:56 PM
Member #4699
I would think a kill switch would be normally open, most are going to cut the ignition when it is pressed to shut the engine down and allow voltage to pass through it when the button is not pressed. You can buy aftermarket horn buttons for cars in several different sizes.
06 Outty Max XT
2008 Yamaha Raptor 700R Special Edition
12-22-2008, 07:08 PM
Member #3461
sorry, yes it is normally closed... meaning power flows through the switch.
Maybe I have the wrong switch... at least it was cheap ($3).
How'd you wire it, Quad?
Just tried what I thought would do it, but burned up a 20A fuse.
Maybe I'll hand a hand-held air horn on the bars
12-22-2008, 07:09 PM
I guess I worded mine incorrectly.
I would think a killswitch would normally complete the circuit and when you push the button it disconnects the circuit.
So is that called normally open?
12-22-2008, 07:14 PM
I used the accessory outlet (cig lighter)hot wirefor the "relay activator", and pulled the horn voltage from the battery.
Sorry if my terms are not correct, I am electrically challenged to say the least.
12-22-2008, 08:21 PM
Member #3461
Thanks! I am electrically challenged, too.
I just checked, and closed means completing the circuit. I think I just got the wrong switch. Kill switch is opposite of what I need, so it's off to Radio Shack for a normally open momentary switch.
12-24-2008, 06:08 AM
Member #240
horn have 1 wire(horn grounds through mounting bolt) or 2(grounds through a wire) ? switch have 1 wire(with 2 wire horn,connect ground wire from horn to switch,then push to complete the ground through horn bracket to handlebars where you would have scraped the paint off a little bit.....unuseable with 1 wire horn) or 2 wires(use for positive , between source and horn----push to close circuit(beep,beep,lol))?
12-24-2008, 08:23 AM
Member #5186
Hope this helps.
In all things...Be as good as the best and better than the rest!
06 Outty 800
Dual Batts
Audio Tube
30" Mudlites
ITP SS rims
Snorkles
Daulton kit coming soon!
12-24-2008, 08:30 AM
Member #5186
Sorry it's a lousy drawing.
Hope it helps.
06 Outty 800
Dual Batts
Audio Tube
30" Mudlites
ITP SS rims
Snorkles
atv horn install wiring, atv horn installation, atv horn wiring diagram, atv horn wiring instructions, can am atv install a horn, how do you install a aftermarket horn on a can am commander, how do you wire a horn and button into an atv, how to install aftermarket horn on can am commander, how to install horn in outlander can am, how to wire a atv horn, how to wire a horn on an atv, how to wire a push button horn to a atv, how to wire an atv horn, install horn 2007 650 can am outlander, where to mount horn can am max
