So, today, and also two days ago, my outty has been kinda spitting and sputtering. The other day, as I was a little over due service, I thought maybe spark plugs..
Well, it is NOT...
I changed the plugs, went for a ride today, and it did good for about 15 minutes... Then started the spitting and sputtering..... Play with the throttle a bit, and it would rev back up...
Then before I could get back to the truck, it died... started back and still continued to do the same. I bet it died 45 time if it died twice trying to get it out of the woods.... Long ways, and lotsa hills... Woulda been REALLY fun trying to pull it out.
Now, the other day, it seemed to do it only every so often and when I would corner or turn.. TOday, it did also, and more extreme and if I hit a bump or rut, it would do it so bad it would die....
There is no water in it, hasn't been in water or mud for a while now....it has good fuel, AND a lil bit of injector cleaner stuff, and fresh plugs on it.
I am thinkin fuel pump, or maybe dirty "SOCK" or filter in the tank...
Any thoughts or ideas???
Also, it overheated once, and ever since it has been missin, or sputtering like that, I have been trying to pull codes from it, and there have been none.. But when it overheated, it gave me P1116 code.....
I looked up in the table, but P1115 was the closest number to it, and it was just telling me it was hot.. lol I already knew that..
So, whatever is wrong, it is not showing on the on-board diagnostics....
One thing for sure, it ain't right, and it is NOT running right..... 20 MPH was doing VERY GOOD today...uke: And that would be going DOWN HILL..od:mg:
Well, it is NOT...
