04-23-2009, 09:25 PM
Member #6136
I agree with trailrider! I have an 800 on the bench right now and it will not shift sometimes without turning the output on the tranny or the input on the tranny. When you're humping your quad you're essentially just turning the tranny output a bit allowing the selecter to fall into gear.
Rotax-Your-Rhino
Rotax engine mount kits, Through shafts, Wiring harness modification, and more! COMING SOON!
04-24-2009, 08:13 AM
Member #5587
Also ordered 2. Hope it will help.
Gade 800 X with stuff
09 Outy 400 for the wife
04-24-2009, 06:31 PM
Member #4784
After they are installed post some before/after results... :whs:
This Outty, in the words of Gunther from The Longest Yard, "She's fast, she's real fast!!!"
04-24-2009, 07:19 PM
Here's Johnny!
Member #3196
you got it rancher!
04-24-2009, 10:59 PM
Member #5730
keep in mind guys that this mod relies solely on the make of the bearings. stock bearings are ntn 6808 (crap)....i used a bearing made by RBL 61808. use what you want that fitts, but when you get it apart and find that the new bearings are as stiff as the stock ones, your not going to gain anything....make sure the new bearings are free'r then the stock ones. if anyone looked at the video above, that is what the new br=earings should be like....
good luck guys, it helped for me:ban:
My ride, the GOATSUCKER, AKA, 2012 XXC 1000 Renegade.
04-24-2009, 11:00 PM
Member #5920
ezyrider wrote:
Add me to the list...I've placed my order...any special install instructions for installing these?
yes, i've posted instructions here:
http://www.atvtorture.com/forums/can...fting-mod.html
04-24-2009, 11:11 PM
Here's Johnny!
Member #3196
Keeping my fingers crossed on this one...
04-24-2009, 11:12 PM
Member #5920
trailrider2 wrote:
I firmly believe this is a crock of  od:. I just got done greasing the one-way on the 500. Damn Dayco belt has a crack in it already BTW.  uke:
This is the second time I've tested this, did it first on my 800. With the belt off the machine I tried shifting it. No difference, still have to hump it. If it don't shift any better without the belt, how in the world is it going to shift better with new bearings?
I'd be happy to eat my words but this makes no freaking sense.
dude, why do you think i would post something if it hadn't worked wonders for me, as well as a few others? like i really want a bunch of guys to spend $30-$40 and an hour of their time and then be p%$#ed off at me? i don't understand what trying to shift without the belt has to do with anything.
i changed to a synthetic chaincase oil at 10 hrs.
nothing.
i drained a couple oz. and put in the schaeffers moly e.p.
nothing.
i tore down the primary, cleaned it and re-lubed with isoflex.
nothing.
2 new bearings and it shifts like butter. i don't understand why this bothers you? maybe it's time to start using an oem belt? i haven't heard anything good about the daycos - you get what you pay for. jury is still out on the epi severe duty, as far as i know. when these guys get their bearings and do the swap, then maybe you'll believe it.
Member #4396
i didnt read the spec on the manufacturers website, but is there any concern about heat with these bearings?
04-24-2009, 11:13 PM
Member #5920
biggbowls wrote:
they are only turning when you're in park or neutral.
bombardier 400 outlander one way bearing, can am 800 how to lube shifter, can am commander one way bearing, can am easy shift, can am easy shift mod, can am one way bearing, can am one way bearing replcement, can am outlander shift bearing, can am outlander shifter mod bearing, can am renegade easy shift, outlander 650 oneway bearing part, rbl 61808 2rs, rbl 61808 2rs bearings who sales, shift bearing for 2009 can am atv, vxb bearings for oneway canam
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
shifting problems
renegade 1382 |
Can-Am / BRP |
5 |
05-03-2010 08:43 PM |
rear bearings
cmepoo |
Can-Am / BRP |
0 |
08-15-2008 12:09 PM |
Over Easy
UNDRPSI |
Can-Am / BRP |
7 |
02-05-2008 08:56 PM |
rod bearings ?
mudmanmatt |
Can-Am / BRP |
0 |
05-07-2007 11:33 PM |
ATV wheel bearings
2007 CAN-AM OUTTY 800 |
ATV Tech Tips |
1 |
02-16-2007 03:04 PM |
