04-23-2009, 04:04 PM
Member #6136
Where is the bearing installed?
Very interesting!
Rotax-Your-Rhino
Rotax engine mount kits, Through shafts, Wiring harness modification, and more! COMING SOON!
04-23-2009, 04:07 PM
the one way is on the primary clutch.
the comet doesn't have one, so i'll stick to humping my outy when i want to shift it :aniwh:
04-23-2009, 04:08 PM
Member #5145
Glad to see you've found a cure...would we still need to lube these new bearings with isoflex? Thanks!
2008 Can-Am 650
3P Tuned
04-23-2009, 04:16 PM
Member #6136
So lubing the stock bearing helps with the hard shifting issue?
Rotax-Your-Rhino
04-23-2009, 04:34 PM
Member #4904
I cant tell any difference after lubing the stock bearing.
Isoflex would still be needed to lube the inside of the bearing just like stock.
\'06 Outlander 800 Camo,Snorkeled,Crutchfield 1&2 Extreme's,27" 589's
\'07 Renegade 800,Snorkeled,27" Executioners
04-23-2009, 04:48 PM
Member #5145
Add me to the list...I've placed my order...any special install instructions for installing these?
2008 Can-Am 650
3P Tuned
04-23-2009, 05:12 PM
Member #5251
so are you saying these TWO bearings would replace the single one way bearing?? and would you still use the springs on the inner sheave shaft?
TEAM GORILLA POWERED BY CAN AM
RCH PERFORMANCE
LOONEY TUNED EXHAUST
SUBMARINE SNORKELS
AQUAPRINT GRAFIX
08 Can Am 999
09 Can Am 800R
07 Can Am 500ish
04-23-2009, 05:39 PM
Here's Johnny!
Member #3196
I did order the bearings last night and from what I gather you still use the springs and cups. There is a spring clip to remove to get the bearings out. Install the new bearings and reassemble. Put the clutch back together as normal, isoflex grease etc.
The two roller bearings are #22.
04-23-2009, 05:57 PM
Member #5145
looks like this is gonna be a fun upgrade...i'll be sure to drink heavily before beginning.
2008 Can-Am 650
3P Tuned
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
shifting problems
renegade 1382 |
Can-Am / BRP |
4 |
09-30-2008 04:40 PM |
rear bearings
cmepoo |
Can-Am / BRP |
0 |
08-15-2008 01:39 PM |
Over Easy
UNDRPSI |
Can-Am / BRP |
7 |
02-05-2008 10:26 PM |
rod bearings ?
mudmanmatt |
Can-Am / BRP |
0 |
05-08-2007 01:03 AM |
ATV wheel bearings
2007 CAN-AM OUTTY 800 |
ATV Tech Tips |
1 |
02-16-2007 04:34 PM |
