snorkled the bike and still taken on water???
This is a discussion on snorkled the bike and still taken on water??? within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Mud and Dirt has a step by step to take it off and how to reseal everything. Works awsome!...
Old 06-18-2009, 05:23 PM
sgw78's Avatar
Member #2449
View sgw78's Photo Gallery(0)
BRP OUTLANDER 800
27" OUTLAW MST, VISON RIMS, DALTON CLUTCH KIT, POWERCOMMANDER, WOODS FULL EXHAUST
BRP OUTLANDER 400
2008 GMC DURAMAX SLT
LIVE IT LOVE IT RIDE IT
Old 06-19-2009, 01:50 AM
Member #185
View Revolution's Photo Gallery(0)
and what are the torque specs for the innear cover to the trans and motor?
07 Can am Outlander 800XT
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
04 Can am Outlander 400XT
EPI Clutch kit
26" Mudzillas
  #13
Old 06-19-2009, 09:12 AM
trailrider2's Avatar
First Name: Mike
Member #3555
View trailrider2's Photo Gallery(2)
10Nm or 89in-lbs. with loctite.
'07 800 XT mine
'07 500 XT hers
Frame mod by weewane
Come ride Southern WV
  #14
Old 06-23-2009, 01:59 AM
Member #185
well guys i filled it with water and i had a few leaks. at the o rings on the back and the bolt holes the hold it on and both rubber boots on the intake and exhaust. they seems to be tight but i guess not. i got it all tore down now and going to silicone everything up good tomorrow. hopefully itll fix my wet belt problem
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
EPI Clutch kit
26" Mudzillas
  #15
Old 06-23-2009, 06:05 AM
TorkMonster's Avatar
Member #4956
View TorkMonster's Photo Gallery(0)
Well, I had THOUGHT I COMPLETELY covered mine with HEAT tape... LOL.....
It DID last a few seasons and it is NOT cheap for these rolls of heat tape...
BUT...
I took on water in my CVT this last ride, and it was when I got in water deep enough to come to the A in the Can Am, I guess... I know I have rode in deeper this season already the way the creeks are, BUT......
I had to stop, and help my buddy on his GRIZZLY, that is NOT snorked, and as I sit there and IDLED, I must have took on water in my CVT, ...
I have always been FINE, with some throttle, and the REASON I snorked mine is to be rid of the little water that gets into the CVT, at LOW RPM...
HMMMMMM>>.....
This is with the HEAT TAPE pulled back a bit... WoW!!!
So... LESSON LEARNED again for ME...
CHECK YOU CVT EXHAUST every season of creek/mud/RIDE...........
I however, DID know it was slipping, so I did NOT get on it at all.. Just a tad....
And once again, I had HOT BLACK WATER come out of my drain, when I FINALLY got it outta the hole with my buddy on his GRIZZ, and drained it...
MAN....
08 800 Outty Yellow
#435 Team Outty
650 Helix
Dalton Kit
25 inch BigHorns
28 inch TITAN 589\'s-stock rims
2inch RubberDown Customs Lift(Bracket front-Spacers Rear)
HMF
Power Commander
Snorked to the POD
Custom Stereo
What Else Do You Need???
04.5 PoPo SP700
too many mods to list
  #16
Old 06-25-2009, 01:56 AM
Member #185
i havent tested it out yet, but it better not leak now. i wacked the silicone to it this time
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
EPI Clutch kit
26" Mudzillas
  #17
Old 07-01-2009, 09:48 PM
Member #185
well guys i tested it out and is tight as come be. i now need to know how to vent my coolant reseivor and the water pump weep hole. mine does not have a tube on it like the newer bikes
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
EPI Clutch kit
26" Mudzillas
  #18
Old 07-02-2009, 03:34 PM
Member #185
and also should i vent both gas tank vents up?
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
EPI Clutch kit
26" Mudzillas
  #19
Old 07-02-2009, 07:09 PM
Member #185
also how do you guys connect your vac hose to the pvc pipe?
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
EPI Clutch kit
26" Mudzillas
  #20
Old 07-04-2009, 06:37 AM
Member #4956
Yes on the vents, or you will end up with mud/debri insidete tank and on the pre filter of the fuel pump like mine did as well s a bunch of other people...
I used rubber couplers found at lowes or most any hardware or plumbing store to connect the hose to the pvc pipes and fittings....
08 800 Outty Yellow
#435 Team Outty
650 Helix
Dalton Kit
25 inch BigHorns
HMF
Power Commander
Snorked to the POD
Custom Stereo
04.5 PoPo SP700
HMF, Snorkled, PC3 Map Sterg Can-Am / BRP 2 08-13-2008 01:48 PM
08 Reny-X Snorkled Snarky Can-Am / BRP 6 11-10-2007 01:40 AM
Snorkled the Renegade RL Can-Am Renegade 8 06-28-2007 06:07 PM
Just Snorkled The 800 CivCord Can-Am / BRP 6 10-08-2006 05:23 PM
Our 2 800's in water and problems with water Traxterman Can-Am / BRP 8 06-05-2006 09:59 AM
