06-16-2009, 03:11 PM
First Name: Mike
Member #3555
Get out the garden hose and fill it up, see what/where it's leaking.
'07 800 XT mine
'07 500 XT hers
Frame mod by weewane
Come ride Southern WV
06-16-2009, 05:11 PM
Member #3840
if you still have the old backplate then the clutch cover will leak. BRP released an updated backplate for the CVT made of a much more durable plastic that doesn't warp under heat. Its very common for the old plastic backplate to warp enough that it will leak next to the shafts and even grind against the primary.
Russell Coker
EFI TUNING AND CLUTCHING BY
PIT PROVEN PERFORMANCE
CMR SEASON FINAL POINTS STANDINGS
1st Open/Pro Class Swampcross
1st Class 1 Mud Bog
3rd Class 2 Swampcross
3rd Class 2 Mud Bog
PSR SEASON FINAL POINTS STANDINGS
2nd Lite Class
2nd Pro B
The Following User Says Thank You to 007BF For This Useful Post:
06-16-2009, 07:16 PM
Member #5242
yes as russ said. you also have an 07' and may be leaking between the gearbox/crank and the cover itself. if the seal between the outer cover and main are leaking then fill it with water watch for where it penetrates the cvt case.
08' 800maxxt
07' 420
Powered by: Performance Enhanced Racing
06-17-2009, 02:00 AM
Member #185
im pretty sure it gots the new updated innear cover. they put a new one on a while back. i guess im just going to have to fill it and see where it is leaking
07 Can am Outlander 800XT
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
04 Can am Outlander 400XT
EPI Clutch kit
26" Mudzillas
06-17-2009, 06:08 AM
Member #5322
Double check the clamps attaching the snorkels to the belt housing.. It could be that its either loose or not seated on the pipe properly
Team Gorilla/CAN-AM
CROWDER #46
DAYCO/ ITP/ HMF/ EPI/ WARN/ MTA/ ODI/ RCH PERFORMANCE
3rd Place CMR CAW Open
3rd Place CMR Mudjam Open
3rd Place CMR Red Creek Super Pro
2nd Place CMR Rocks Bottom Open
1st Place Twincity Mud Drags SuperStock
2nd Place TwinCity Mud Drags SuperModified
1st Place MudStock Buddy Run
WWW.MYSPACE.COM/DAWAYNECROWDER
06-17-2009, 06:26 AM
Member #3045
I found my leak by filling it with water. I told some one on another forum to do this and got ripped for it. I dont see the problem when you ride and fill it with mud. Mine was leaking from the rear shaft
06 outty 800 snorkled full skids Aluma Tech CV Guards ITP 212 26" terra cross Piaa HIDs secondary radiator digital engine temp heated hand and thumb dalton clutch BRP fender extensions Fasst Flexx 14deg bars Rox Anti Vibe Risers Cycra Hand Guards and bark busters Moto Comm Camera stage two Crutchfields front and rear
07 Renegade 800 Rox anti vibe risers Aluma Tech external oil filter and cooler
06-17-2009, 12:35 PM
Member #185
yeah i thought of filling it. it not going to hurt anything. lot better then old muddy water in there
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
EPI Clutch kit
26" Mudzillas
06-17-2009, 02:25 PM
Member #185
what should i seal it with? rtv?
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
EPI Clutch kit
26" Mudzillas
06-17-2009, 07:04 PM
Member #3045
[QUOTE=Revolution;198291]what should i seal it with? rtv?[/QUO
I used a high heat rtv.
