replacing front outer cv boot question - Can-Am ATV Forum
This is a discussion on replacing front outer cv boot question within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; i got a cut in my front outer cv boot, how do i get the cv joint to come off the shaft? do i have ...
Old 07-01-2009, 05:45 PM
Member #6375
View hofulstrof's Photo Gallery(0)
i got a cut in my front outer cv boot, how do i get the cv joint to come off the shaft? do i have to remove the whole axle from the outtie if so what do i have to remove, the brake caliper? then does it slide out? or can i just tap the cv joint off the shaft with a punch, while its still attached to the quad?
2009 outlander 800
Old 07-01-2009, 06:03 PM
trailrider2's Avatar
First Name: Mike
Member #3555
View trailrider2's Photo Gallery(2)
http://www.can-amforum.com/forums/ca...t-cv-boot.html
AWF how-to. ^^^^
'07 800 XT mine
'07 500 XT hers
Frame mod by weewane
Come ride Southern WV
Old 07-01-2009, 06:15 PM
locomike's Avatar
First Name: Weekend Mudder
Member #5398
View locomike's Photo Gallery(0) Send a message via AIM to locomike
Give a HARD jerk out of the front differential. Put the entire shaft in a vice. Whack it HARD with a hammer. Follow the pocs in reply above..... just don't be shy.
08 Can Am 800 XT MAX
Richochet Full Skids
Alumitech Rear CV Covers
ITP SS108 14" wheels
ITP 27 x 14 Mudlite Radials
EBC 'SV' Series Brakes
'Loco Mike' Configurable Snorkle
Gorrilla Rear Axles
Dalton Clutch
Oil P- Water T- Volt Guage Console
Moose Snow Plow (when needed)
Old 07-02-2009, 09:23 AM
stangs4's Avatar
Member #5920
View stangs4's Photo Gallery(0)
got wake came up with the best way. unbolt both a-arms after removing the caliper and tie rod end (shock must be un-bolted first). it's far easier than trying to remove the ball joints without tearing them. once the shaft is out, put in a vise and knock the end off with a hammer and block of wood. i buy my replacements from thecvman.com for $20, same quality as oem.
Old 07-03-2009, 12:25 AM
Member #6375
i got it off. i was not not exactly sure if i had to pull the axle completely out but it turn's out all i had to was to remove the to t-40 torax bolts or what ever they are called and the axle came out no problem then i put it in a vice like you said and it came apart easley. i just have to clean everything up and put it back togther tomorrow and will be rideing again thanks guys
800 outlander how to remover front cvaxel
can am front axle joints
can am outer cv boot
can am outlander front cv boot removal
front cvc shaft boot for can am outlander 800
how to change boots on can am 800 renagade front cv joint
how to change front cv joint boot on 2007 outlander 500
how to install outer vc boot on artic cat 500
how to remove axle shaft and cv joints arctic cat
how to remove the front axle on a cam am 450
outlander 800 cv boot replacement
removing front outer cv joint on suzuki atv
replace outter cv boot front renegade 800
replacing 2007 arctic cv joint and boot
you tube videos of complete front cv boot change out on a arctic cat 700
Photos of replacing Front CV boot motelcambodia Can-Am Service Bulletins /Recalls / How To 38 08-10-2012 03:22 PM
replacing rear outer cv boot ruger1 Can-Am / BRP 9 04-28-2008 03:56 PM
how to remove arctic cat outer cv boot from axle? Muncher Arctic Cat 0 04-06-2007 09:22 PM
how to remove arctic cat outer cv boot from axle? Muncher General Chit Chat 0 12-31-1969 07:00 PM
Photos of replacing Front CV boot motelcambodia Can-Am / BRP 16 12-31-1969 07:00 PM
