Will the 2010 650 watt stator work in my 2006
This is a discussion on Will the 2010 650 watt stator work in my 2006 within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Just looked on the BRP fische, and the '09 Expedition sled has a different cover, stator, and flywheel, than our atv's do, same motor though. ...
Old 07-21-2009, 10:09 PM
mrrpm's Avatar
Member #4276
View mrrpm's Photo Gallery(0)
Just looked on the BRP fische, and the '09 Expedition sled has a different cover, stator, and flywheel, than our atv's do, same motor though. Is this what is being put in the atv's, now, for the power steering system?
Home of the 975cc 90RWHP N/A bolt-on big bore kit!
-High perf cams available!
-51 MM Throttle Body Boring,
-Custom head work
-Billet Heads
-Billet Jugs
-'07 240RWHP Alky Renegade Turbo, ViPec ecu, Billet STM clutches
www.mrrpmcycle.com
Old 07-22-2009, 08:22 AM
Member #3927
View I bleed yellow's Photo Gallery(0)
The 2010 Can-Am Technical update book says it will not fit. The crankshaft is different. It has a oil passage to help with the increase in heat that is produced by the extra output. The wire harness is also different. A new Mosfet type regulator is also used. The flywheel is different also it has stronger magnets.
Go Can-Am X Team!!! Good luck for 2008!!
The Following User Says Thank You to I bleed yellow For This Useful Post:
got wake?  (07-22-2009)
  #13
Old 07-22-2009, 08:55 AM
that's the kind of info i've been waiting to hear it can be done then, but my concern will be in the mosfet regulator. it may need the 2010 ECU to control it, depending on how its setup.
  #14
Old 07-22-2009, 09:11 AM
mrrpm's Avatar
Member #4276
The old regulator, is just that, a regulator. The ecu doesn't even know it's there, in other words, the bike will run without the regulator at all. The regulator simply charges the battery. If the new one is the same way, it will work with the older ecu.
On the crank, maybe we could drill the old crank for the extra oiling. I wish they would put the fische up, so we could look it up. Does anyone know where we can find an online fische for the 2010's?
-Custom head work
-Billet Heads
-Billet Jugs
www.mrrpmcycle.com
  #15
Old 07-22-2009, 09:21 AM
i've seen ECU controlled regulators. my old car had one. it made upgrading the alternator impossible. adding a second one was the only option. it actually had a 2 part regulator and if the half in the alternator was not there or not working properly, the car would not run right. i really hope that can-am doesn't do anything like that, but i've seen it before.
  #16
Old 07-22-2009, 12:27 PM
Member #3927
The parts are up on the dealer site, and if I was better with a computer I could put the photos you want on here. The up date book says that there are 4 different crankshafts. For the 650-800 with dps is 420219745. The wires on the harness are also bigger to ad to the list above. It also states (The magneto is similar in size but includes stronger magnets). Let me know if I can help you more.
  #17
Old 07-22-2009, 12:46 PM
mrrpm's Avatar
Member #4276
Can you tell us if the regulator has 5 wires or not? The older units had three wires that runs directly to the stator plate, (three yellow) and the other two runs to the battery, one plus (red), the other minus (black).
-Custom head work
-Billet Heads
-Billet Jugs
www.mrrpmcycle.com
  #18
Member #1893
View normann's Photo Gallery(0)
www.epc.brp.com
  #19
Old 07-22-2009, 01:08 PM
www.epc.brp.com
i get a page load error from that link.
  #20
Old 07-22-2009, 01:23 PM
Member #3927
mrrpm it is your day I have the 2010 wire diagrams in also. The reg on the 2010 ps (650 watts) units has three yellow wires that go to the mag one red that goes to the batt side on the starter solenoid, and a black wire that goes to ground at the same place the battery grounds. I do not have any 10's yet to take a look, but that is what the diagram has. The tech update book says that the new reg is bigger and has inproved heat dissipation property. Hope that helps.
2006 can am outlander 650 xt stator
2006 outlander 800 stator
2007 renegade stators
650 watt magneto
650 watt magneto can am renegade
650-watt magneto
amps produced by 650 watt stator
can am outlander stator rewind
can am renegade charging stator upgrade
can am renegade stator
can the magneto on a 09 outlander be upgraded to a 650 watt
how do you change a stator in a 2006 can am 800
how many amps can a 650 watt stator produce
how much does a stator cost for 2006 can am outlander
magneto stator hi watt
outlander atv 2006 stator
rotax 650 stator
show how to replace stator in 2006 atv polaris 800
stator upgrade for a 650 outlander
testing stator on 650 can am outlander
Magneto/stator output check guidance/notes wildbill Can-Am Service Bulletins /Recalls / How To 49 11-20-2009 10:59 AM
Stator Kevin Z Can-Am / BRP 10 07-21-2009 08:13 PM
Got my new stator AKOutlander800 Can-Am / BRP 27 01-26-2009 06:02 AM
renegade stator raven Can-Am Renegade 3 10-08-2008 01:10 AM
stator? advance or no? buddebuilt Polaris 10 12-26-2005 09:18 AM
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
