MrRPM oil cooler test results - Page 6 - Can-Am ATV Forum
post #51 of 97 Old 08-07-2009, 03:16 PM
Kratos's Avatar
Understood. We will excercise patience.
07 Renegade 1026cc FCP stroker motor, THEBOM super race heads, THEBOM super TB, GHR turmoil exhaust, GHR q-jection ecm, Brooks 8" stretch, AIRDAM clutch, mrrpm intake, cannon oil cooler kit
Past quads:
08 Thundercat 1000
06 Brute Force 750
07 Rincon 680
05 Kingquad 700
Kratos is offline
post #52 of 97 Old 08-07-2009, 03:44 PM Thread Starter
Perf Tuners
HAHAHAH That sounded too professional. Just tell us to hurry the hell up..
John Cannon
www.MUDandDIRT.com
www.YouTube.com/mudanddirt
MaD MotorSports
ATV EFI Custom Tuner
Powered by www.MrRPMcycle.com
Outlander X, MrRPM 1004cc, BRP Race TB/ECM, STM, Fasst, Precision, AC, Muzzy
john cannon is offline
post #53 of 97 Old 08-07-2009, 04:15 PM
Kratos's Avatar
Lol
Past quads:
08 Thundercat 1000
06 Brute Force 750
07 Rincon 680
05 Kingquad 700
Kratos is offline
post #54 of 97 Old 08-15-2009, 11:55 PM
Go Hard's Avatar
I too have been running one of Greg's oil coolers. I monitor my oil temp at all times, very good item. I ran a Mr. Transmission tranny cooler in my left wheel well on my 2009 1004cc powered Gade. It works very well. It has been picking up the slack from the cooling system. My fan runs far less now thus conserving battery power to winch out Poo Poo's and the such, lol.
FCP 940cc powered Renegade. NX Nitrous kit. Bopp Racing +2 stem, Fab spindles, TTI rear arm's, Dudding front end kit. Fasst Flexx bars, ODI lock on grips, Power Madd bark busters, Exit Shocks, Maxxis Big Horn 2.0's with 12 inch Hiper Racing Sidewinder wheels, Direction2 Overfenders, Ridgerunner rear rack, Viper 4500lb winch, Crank front bumper. Go Hard Racing Subsea snorkels / cold air intake. Quad Worx intake. BRP rear hitch. STM clutches, Dalton springs. Q-Jection ECM. Blown Concepts custom graphics, custom gauge pod, MRRPM oil cooler adapter with GHR custom oil cooler. Precision steering Damper. Go Hard Racing custom skid plate and frame mod. Dingo Tim's seat cover.
Go Hard is offline
post #55 of 97 Old 09-29-2009, 05:09 AM
Originally Posted by mrrpm View Post
John is planning on selling a kit that has all the stuff you need to do a complete install. I'm just wanting to sell the adapters. I have 2 different styles, one that mounts the filter on the adapter, and another that has to have the filter mounted to a seperate oil filter mount. The adapters are available now, price for the adapter that mounts the filter on the adapter is $75.
How much is the adapter that relocates the filter, elsewhere? I may have to go that route to avoid cutting the wheelwell on my Outlander MAX.
QUADAHOLIC is offline
post #56 of 97 Old 12-04-2009, 07:25 PM
Does anyone have a of pictures to show how much fender you have to cut out? I would be very interested in getting the adaptor just to run a normal filter that should be cheaper that the BRP and also it should help you a little bit just by being able to increase your oil capacity even if you don't have the cooler. I was also wondering about the dipstick gauges, do they just pop in place or are they screwed in like factory? I was just wondering about the seal of it when your doing water crossings. If I got the adaptor with the 3 ports for temp & cooler lines could I leave 3 plugs in them and run it unti I get it geared up with a cooler? Would the plugs block an oil passage? Thanks for any help.
MacLean is offline
post #57 of 97 Old 12-04-2009, 10:44 PM Thread Starter
Perf Tuners
MaD MotorSports
You have to run a line out and back into the adapter. Plugs will stop flow. dont know anything about the dip stick guages.
John Cannon
www.MUDandDIRT.com
MaD MotorSports
post #58 of 97 Old 12-05-2009, 05:54 AM
f419sr1's Avatar
Send a message via AIM to f419sr1 Send a message via MSN to f419sr1
You can get the remote filter adapter at any good parts store or speed shop for $20 plus.
06 outty 800 MRRPM 840 gen 2 cams 09 intake PC3 engine oil cooler fan over ride xmr snorkel full skids Aluma Tech CV Guards HTR 25s secondary radiator digital engine temp heated hand and thumb BRP fender extensions Fasst Flexx 14deg bars Rox Anti Vibe Risers Cycra Hand Guards and bark busters fox podiums on all 4 corners ridged light bar aluma tech intrusion bar rear diff supports STM primary and secondary
07 Renegade 800 Rox anti vibe risers Aluma Tech external oil filter and cooler SOLD
2011 Outlander XXC 25 XTRs and anti vibe risers for now
f419sr1 is offline
post #59 of 97 Old 12-05-2009, 05:59 AM
f419sr1's Avatar
Originally Posted by MacLean View Post
Does anyone have a of pictures to show how much fender you have to cut out? I would be very interested in getting the adapter just to run a normal filter that should be cheaper that the BRP and also it should help you a little bit just by being able to increase your oil capacity even if you don't have the cooler. I was also wondering about the dipstick gages, do they just pop in place or are they screwed in like factory? I was just wondering about the seal of it when your doing water crossings. If I got the adapter with the 3 ports for temp & cooler lines could I leave 3 plugs in them and run it unit I get it geared up with a cooler? Would the plugs block an oil passage? Thanks for any help.
If you dont have a steering stabilizer you can mount it between your frame and steering shaft
f419sr1 is offline
post #60 of 97 Old 08-28-2011, 03:12 PM
kmb760's Avatar
Seeing how this thread is a little older has any one found a filter that works better or worse cause on my adapter it seems like my fram filter doesnt screw in tight enough and I get a tiny bit of oil leakage off the bottom of the adapter where it mates to the filter.
2009 Outlander 840, Dual Muzzy, Auto Tune, K&N Filter, CV-Tech Primary, STM Secondary......
RYR
kmb760 is offline
MaD/MrRPM 1004 pics and test drive john cannon Can-Am / BRP 32 07-26-2009 06:54 PM
does MrRPM have a web site LIMO-MAN Can-Am / BRP 1 07-04-2009 09:12 PM
MrRPM 1107cc Kit madppcs Can-Am / BRP 19 07-02-2009 07:30 PM
Thanks MRRPM dgarmon Can-Am / BRP 10 04-01-2009 06:02 AM
Congratulations mrrpm Kratos Can-Am / BRP 56 10-30-2008 08:14 PM
