odyssey battery? - Page 4 - Can-Am ATV Forum
post #31 of 63 Old 10-15-2009, 05:59 PM
BrianE's Avatar
Originally Posted by berick View Post
Originally Posted by BrianE View Post
Ok well anyway since I went to the Odyssey my winching issues have went away. No low batt when plowing either. It seems well built also. As far as cca and ca last winter seen -20 here. My quad did not even grunt it spun and fired off like it was summer. This is just my experience.
Which Odyssey model did you use? I want to get one as well but have no idea if I need a PC625 or a PC680? I have an 07 outlander 800XT. Did you have to modify anything to get it to fit?
I use the PC680. It will fit with minor modification to the battery tray. Still have no issues and am now running extra lights and grip and thumb warmers. seems to do well. I keep mine on a battery tender JR.
2010 Outlander XT 800R
Muzzy slipon & Doebeck AFR+
Elka s
tage 3 shocks
FasstFlex Bars/ROX riser.
Kenda BK HTR 26"
Camoplast Tatou 4s tracks
TEAM/STM clutches
BrianE is offline
post #32 of 63 Old 10-15-2009, 10:25 PM
berick's Avatar
Perfect! PC680 it is! Thanks a mil for the info guys!
berick is offline
post #33 of 63 Old 12-22-2009, 07:23 PM
Highlander's Avatar
Its time for a battery for my 2007 Otty 800 max and BatteryTex carries a few PC680 batteries. Is model Odyessey PC680-p the correct battery to get?
07 Outlander Max Ltd
Highlander is offline
post #34 of 63 Old 12-22-2009, 07:45 PM
Yep. shop around tho, prices fluctuate and some places have free shipping.
QUADAHOLIC is offline
post #35 of 63 Old 12-22-2009, 08:01 PM
Highlander's Avatar
Thanks for the fast response. The pc680 photo shows no posts on the battery. Do I need to order screw in posts too or can the posts be screwed off the old battery?
post #36 of 63 Old 12-23-2009, 04:27 AM
The terminals are flat with a threaded hole(6 mm, I think) pretty standard nowadays. I don't remember having to do anything special when I installed mine.
post #37 of 63 Old 12-23-2009, 03:51 PM
The only thing I would recommend doing that I did was to add some kind of spacers on each side of the battery. I added about a half inch of sticky backed foam I had laying around to each side to take up the slop there a bit. The battery is a tad taller than the stocker, pretty much the same length and a bit narrower. You can still run it without the side spacers though, I just wanted to keep it from having that slop room on the sides.
PRP Steering Stabilizer
fmj40 is offline
post #38 of 63 Old 12-27-2009, 08:23 AM
Highlander's Avatar
I ordered the pc680 model on the 22nd and it arrived on the 24th. that was fast shipping considering the Christmas rush. The battery came with hardware so that was good. Now I need a nice day so I can install it
Thanks All.
post #39 of 63 Old 12-27-2009, 02:27 PM
X-Devil's Avatar
Originally Posted by QUADAHOLIC View Post
The Odyssey batteries are like rv batteries, they can handle "charging abuse".
They hold a charge longer and can go years without getting a charge and then come back up to like new.
Are they rated as a "DEEP CYCLE" battery ?
Keep the rubber side down !
X-Devil is offline
post #40 of 63 Old 12-27-2009, 03:13 PM
HIGHOCTANE's Avatar
"The Odyssey battery ingeniously uses absorbed glass mat (AGM) technology to offer, in one box, the characteristics of two separate batteries. It can deep cycle as well as provide enormous cranking power.
These batteries are capable of providing engine cranking pulses in excess of 2250A for 5 seconds as well as 400 charge/discharge cycles to 80% depth of discharge (DOD). A typical starting, lighting and ignition (SLI) battery can do one or the other, but not both.
Odyssey batteries will do both - provide short duration high amperage pulse or low rate long duration drains."
2010 Camo Outlander 800 Max-XT
ATR Chassis Spine/Ricochet Skids
Big Horn 2.0's 14" SS212's/QSC Clutch Kit
Koplin Hitch Reciever
50W Eagle Eye HIDs
HIGHOCTANE is offline
Odyssey battery Sandgnat Can-Am / BRP 14 12-29-2008 06:53 PM
Odyssey PC680 Sandgnat Can-Am / BRP 23 11-16-2008 08:34 PM
need a new battery.... dmented692006 Can-Am / BRP 16 04-04-2008 05:55 AM
Will an ATV run without a battery? BobWV Can-Am / BRP 13 04-07-2007 01:20 PM
Need new battery? turboman Can-Am / BRP 5 03-12-2007 11:40 PM
