ATR Can-Am Chassis Spine>>>
This is a discussion on ATR Can-Am Chassis Spine>>> within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Ordered one Sunday, but have not received tracking for it yet....
  #141
Old 07-23-2010, 01:57 AM
Member #9955
View mingman82's Photo Gallery(0)
  #142
Old 07-23-2010, 08:29 AM
cnj cnj is offline
Member #10855
View cnj's Photo Gallery(0)
Just received mine for my '07 Outty 500. The ATR spine really looks like a quality piece. Will probably install it next weekend.
  #143
Old 07-24-2010, 01:54 PM
1evilss's Avatar
Member #11121
View 1evilss's Photo Gallery(0)
Default X mr
Is this spine going to work on the 2011 Outlander X MR? I heard there is now some kind of support or brace in the 2011's
The Chassis Spine is a fully engineered solution designed specifically for this application. We designed these as an extrusion made from 6061-T6 Aircraft grade aluminum. This product went through many revisions until we ended up with a shape that is low in weight while adding the needed rigidity.
  #144
Old 07-24-2010, 05:00 PM
blevinsbulldog's Avatar
Member #4426
View blevinsbulldog's Photo Gallery(0) Send a message via AIM to blevinsbulldog Send a message via MSN to blevinsbulldog
Quote: Originally Posted by ugly betty View Post
Is there any problem due to being different metals? Thinking on getting one.Thanks
I think the best answer to this qestion is, think about how many people are running ricochet skids w/o any problems.
07' 800 Outlander Max
R-LAWS 28's Skinny Wide
ITP SS108's
Dalton G/Y & Y/B
Full Snorkz
Ricochet skids
Warn RT30
Pipe Lift
Hmf pipe
  #145
Old 07-29-2010, 09:23 PM
Selkirk Guy's Avatar
Member #4967
View Selkirk Guy's Photo Gallery(0)
Default My Chassis Spine Installations
Check out this word document to see how my ATR Chassis Spine installation went. I think this product is one of the most important upgrades for your CanAm.
Nevermind. Apparently you can't upload a 1.45 MB word document to this forum. 19.5 kb limit on a word document? What's up with that?
2009 Outlander 800R XT
  #146
Old 07-31-2010, 09:50 AM
Huck BB62's Avatar
Member #871
View Huck BB62's Photo Gallery(0)
After four years of having my Ricochets on, I pulled them to put 'em on my new '11. Some comment on your question:
1. The through bolts suck. They were badly corroded. I bought new stainless ones for the job.
2. The allen head bolts suck. They get damaged and have to be drilled off.
3. There was an evenly displaced mud collection on top of every plate, front, rear, a-arm. The factory paint held it at bay with no problems.
I was shocked at the licks my Ricochet had sustained. It's my opinion that they should come with skids from the factory. My '11 had this Fisher Price plastic goober thing on the center of the frame. They should save the money and stop doing that joke.
And yes, there's some stiffening material in the front of the new '11 frame. I won't be doing a frame mod.
  #147
Old 08-16-2010, 11:29 AM
WilliamBos's Avatar
Member #10836
View WilliamBos's Photo Gallery(0)
Quote: Originally Posted by All Terrain Research View Post
Quote: Originally Posted by silverz98 View Post
when this is installed do you take weld the old back peice back up? or you leave it off? if you leave it off how the spin stay in the fram?
You could weld the plate back on if you wanted. I don't have pictures of this yet but what is also included w/ the Chassis Spine is a bolt that goes horizontally across the rear of the spine thru the 2 holes in the chassis, and sandwiched between we have a machined aluminum spacer that runs behind the Spine. I don't think it's really needed as i can't imagine the Spine being able to slide out once in there, but we thought better safe than sorry. We spent quite some time getting the tolerances just right where it was a very snug fit.. but not so tight that it made it too difficult to install.
Jeremy
Thanks. Do you need to weld the plate back in, or can you leave it out?? Will it hurt leaving it out??
Word on the street is that the 2011 Outty's have the front part of the frame strengthened?? Have you heard of this??
Thanks,
Will
Finally made my mind up, come Spring 2011 400 Outty it will be!!
  #148
Old 08-16-2010, 02:37 PM
WilliamBos's Avatar
Member #10836
Quote: Originally Posted by HIGHOCTANE View Post
I installed mine last night,wasn't bad at all. I just cut the welds on the top and sides then folded the flap back up after install...unless you look real close you can't tell anything has been done.
So it is welded on all 4 sides?? What did you use to cut it??
Thanks,
Will
  #149
Old 08-16-2010, 04:40 PM
WilliamBos's Avatar
Member #10836
Had the crap beat out of it, or what?? Are the weak points where it is broken?? Or where the front/rear suspension mounts to the frame??
Found this on another forum
Thanks,
Will
  #150
Old 08-16-2010, 04:50 PM
Can-AmConvert's Avatar
Member #11198
View Can-AmConvert's Photo Gallery(0)
That looks like it hurt!
09 Outy 650 Max XT
Can-Am bag set, Can-Am front rack extender, 10" rigid E series led light bar, SYA stealth snorkel kit, 1" aluminum wheel spacers, full Ricochet skid plates, Can-Am radiator protector
Hi/Lo HID's *received but not installed*
atv tie downs
can am atr spine install
moose outlander max drill
ships spine
kewltec Frame mod for can am#i
atr chassis spine
ATR frame spine reviews
ATR-CHA-5001A
800 can am weight bushings
ATR Can-Am Renegade Chassis Brace All Terrain Research All Terrain Research 3 07-01-2010 01:21 PM
HELP!!!!! 2004 Outlander Max 400 chassis USAF105 Can-Am Outlander 4 10-20-2009 12:10 PM
Outlander rolling chassis value? Brian B Can-Am Outlander 5 02-05-2009 01:15 PM
Chassis compatability Rene_Rider_NC Can-Am / BRP 6 11-26-2008 08:51 AM
Will be using an Outlander 800 chassis to build a car catx5 Please Introduce Yourself 6 02-18-2007 10:29 PM
