can I start without a gauge cluster?
This is a discussion on can I start without a gauge cluster? within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Hey guys, I am rebuilding my 07 renegade that had a nice unfortunate roll over. I have purchased all the pieces needed in order to ...
Old 03-07-2010, 10:44 AM
Member #9193
View Anthonyy's Photo Gallery(0)
Default can I start without a gauge cluster?
I have purchased all the pieces needed in order to get it running again, however my gauge cluster hasnt arrived yet.
Last night, I went to try to start it.. I heard the fuel pump priming, but no ignition. When I jumpered the starter solenoid, it cranked but sounds like no spark as it just kept cranking with no start.
I don't have a gauge cluster plugged in, will this prevent it from getting ignition?
Thanks,
anthony
Old 03-08-2010, 05:32 AM
Kraker's Avatar
Member #240
View Kraker's Photo Gallery(0)
Pretty sure u have to get the new speedo "linked" to the ecm at the dealership.
The Following User Says Thank You to Kraker For This Useful Post:
Anthonyy (03-09-2010)
Old 03-08-2010, 11:06 AM
Member #8003
View silverz98's Photo Gallery(0)
when i was doing my snorks out the pod it started raining on me i started my outty wit hout the gauges hooked up and moved it under the car port
The Following User Says Thank You to silverz98 For This Useful Post:
Old 03-09-2010, 12:35 AM
Member #9193
dang. I gotta figure out why mine wont start.
I ordered a new cluster, but it hasnt arrived.
the old one got 'lost' in the 'rollover'
I hear the fuel pump prime.. but no crank.
if I jump the crank, itll crank but wont start.. something is telling it not to start.. i may be forced to take it to the dealer.
Old 03-09-2010, 07:03 AM
Kraker's Avatar
Member #240
thats exactly what happens when a key breaks (does everything but crank & will wind if solenoid jumped) but that may be the same symptom of all that ign related stuff.
Old 03-09-2010, 04:10 PM
DTX's Avatar
DTX DTX is offline
Member #8496
View DTX's Photo Gallery(0)
It will start and run just fine without it. I recently put my plastics back together in a hurry and forgot to plug it in. It ran just fine.
Old 03-09-2010, 11:12 PM
800VTwin's Avatar
Member #4130
View 800VTwin's Photo Gallery(0)
Yes, it will run. If there is any security, dess or ecm problem it will not crank.
Check the ignition fuse and your coil is plugged in.
08 gade 800
-800vtwin.com ECM
-Koso Display
-LTE Dual Exhaust (ceramic), modded QC's
-50mm tb
-09 tb boot, airfilter, cams
-Race Intake
-Modified Airbox
-Dalton Clutch Components
Old 03-10-2010, 08:38 PM
Member #9193
OK, so my cluster finally came in.
I plugged it in.
it says "Check Engine"
However, when i check the service manual, it says go to the engine hour screen, (Which I do)
press and hold the button while quickly flashing my high/low switch. but nothing happens..
Heres what I replaced in the rollover. (besides all the plastics)
I needed a new gauge cluster, Throttle sensor (TPS), fuel rail (was able to reuse the stock injector) and a new "start" switch assembly. the rest is non electrical parts.
Outlander Gauge Cluster Avalanche Can-Am Outlander 4 02-07-2010 09:36 PM
Moisture in Cluster..... Camcrazy Can-Am / BRP 11 12-08-2009 10:07 PM
instrument cluster error rob13 Can-Am / BRP 3 03-22-2009 09:12 PM
Instrament cluster problems 800outtybounds Can-Am / BRP 26 02-15-2009 05:56 PM
Cluster FALCAN Can-Am / BRP 3 08-15-2007 01:37 PM
