oil drain plug stripped the engine what now - Page 2 - Can-Am ATV Forum
post #11 of 15 Old 01-06-2012, 04:01 PM
WiNdGaDe800's Avatar
Old but good!
If this happens to me I'll end up welding an aluminum piece of pipe to my engine, kinda like an 02 sensor bung but shorter, and then I will have so many threads it should be about impossible to strip it again (use a torque wrench) Oh and I will also have a bolt with a magnet on the end for those sneaky metal pieces...
WiNdGaDe800 is offline
post #12 of 15 Old 05-16-2013, 04:14 PM
axkaizen's Avatar
qwikvalve
Has anyone tried this on their canal? Fumoto Valve | Qwik Valve™
I wonder if the housing is large enough.
But there doesn't seem to be a magnet.
axkaizen is offline
post #13 of 15 Old 05-22-2013, 08:16 PM
whatever you do don't take it to most dealers. If like cars, they crank the engine oil plug and oil filter on so tight the next time you want to do it yourself both are very hard to get off almost like it is welded on.
cookiedough is offline
post #14 of 15 Old 05-22-2013, 08:36 PM
MagsH2's Avatar
No kidding, I just did my 2nd oil change, the dealer did the first. My plug was on so tight I ripped open my thumb on the skid plate after using so much force to break it free. .
2012 Max XT with XMR snorkle kit.
Ricochet Skids, Pitbull Growlers, STI HD2SE Wheels.
2012 DS 250 for my son
MagsH2 is offline
post #15 of 15 Old 05-26-2013, 06:20 PM
blevinsbulldog's Avatar
Send a message via AIM to blevinsbulldog Send a message via MSN to blevinsbulldog
Stripped mine like a week ago. Went to a local mechanic & he charged me $5 to tap to a 14mm X 1.5. Got drain plug at advance for $4, so a $9 fix for me. Well i take that back, i used 3 qts of cheap oil to flush in case any particles were in there. So ill say less trhan $15. Ill take that any day
07' 800 Outlander Max
R-LAWS 28's Skinny Wide
ITP SS108's
Crutchfield Springs
XMR Relocate Kit
/// CVtech
/// Secondary
Full Snorkz
Warn RT30
Hmf pipe
blevinsbulldog is offline
oil drain plug stripped 25TH INFANTRY Can-Am / BRP 22 04-13-2012 02:34 PM
Stripped oil drain plug housing texdot5 Can-Am / BRP 7 06-21-2011 06:52 PM
Stripped drain plug =[ Rags16 Can-Am Outlander 1 12-01-2009 08:07 AM
Stripped crankcase drain plug !! machzx ATV Tech Tips 5 06-02-2008 04:24 AM
Stripped the hole for the Drain Plug on the opil pan any Suggestions!!!!!!!!!!!!!!!!! admmoor Can-Am / BRP 13 07-09-2007 09:34 PM
