06-26-2010, 03:19 PM
Member #7239
possible fuel pump problem 2010 Outty 800XT
Went on first long (3hr) ride today. Mostly 3-8 mph. on the way out to the trail head to explore the other side of the property my bike started acting up.
It would run for a second then "choke" out, it would pick up and go a lil bit then "choke" out again. Don't know exactly how to explain but it seamed like it was running out of fuel. I switched of the key and cycled the fuel pump a few times. The pump made a few weak start ups. Out of maybe 10 cycles maybe 3 of them were weak.
Does this mean the fuel pump is going out? Was the bike over heating? I had no lights on the dash come on. Needless to say i swallowed my pride and let an olddependable carb Honda pull me on to the truck before I burnt up the top end.
Any ideas on what the problem is?
2010 Outty 800r Max XT, 30x9front 30x11rear silverbacks on 14" black ITP 212's, HMF Swamp series, Gorilla Rad Relocate and front lift, East Coast Snorkel,Dalton DBO800mud pro clutch kit. 08 Gade 840 PCIII Fully Muzzy Exhaust 30" Sbacks,DBO800r w/EPI blue secondary, Snorkel your atv snorkels.MRRPM Oil cooler. Both bikes snorkeled 2" through the bottom of the air box
06-27-2010, 05:18 AM
Member #9576
sounds like a bad fuel pump.
WayneR
Authorized Amsoil Dealer
2008 Can-Am Outlander 800XT RED
EZ Steer Power steering (Super ATV)
Flex-A-Lite Fan controller
BRP rad relocator kit
Ricochet skids
XMR Console/Dash
Elect. Gauge pod trio (by Paul Ashby)
12 inch Douglas Rattlesnakes w/27 inch Zillas
ATR Chassis Spline
UNI Filter
XMR snorkels
Dalton DB800 clutch kit
Gates G-Force belt
HPG shocks w/HD Springs (front)
HPG shocks w/Stage 1 Crutchfield spring kit (rear)
BRP Handwarmers
BRP Thumbwarmer
Direction 2 fender extenders
Reason: we dont link to other sites for info thats already here
06-27-2010, 07:44 AM
Member #2621
battery terminals tight ? vent line ? check coonections to fuel pump ?
2010 can am 800 max xt-p,,26" mst's on black 212 rims
06-27-2010, 01:59 PM
Member #7239
all done camlaw. will drain the tank today
07-16-2011, 03:24 PM
First Name: Fun and fun
Member #14777
Did u ever fix the prblem? Mine is doin the same thing
07-17-2011, 06:49 AM
Member #15447
Cananimal10, mine is doing something very similar as well. After the bike heats up (maybe running for about 1hr) it starts to act up. Runs great when it is cold. When I hit the gas it "bogs" or "chokes" itself out then when kick in again. We are going to have a look at the coil first, and if that isn't the problem then the fuel pump. It is strange though because it only happens once the bike heats up. I get no p-codes or messages on the dash.
What is your bike doing?
#2 TEAM TURNERS PERFORMANCE / HONORARY BENT TOYS TEAM MEMBER...lol
'12 Can Am Outlander 1000xt / 30" silverbacks on 14" aluminum swamplox
SOLD - '08 Can Am Renegade 800x
07-18-2011, 10:02 AM
Member #14777
skturner, was ridin one day( bike was a lil hott). Started boggin down, then it would catch for like two seconds, then it would bog down again. Got it back to the truck and killed it, let it cool off. Went to turn the key on and noticed my fuel pump sounded weaker than normal. Just figured that was what it was. Loaded it up went home, next mornin crunk it up and rode it around and acted fine. Guess it done cooled off? But still didnt idle right and fuel pump still souded weak. Took it in for repair. But even when it was hott, i hammered the throttle, and it didnt miss a beat! Its wierd man hopefully its a warrenty fix
07-18-2011, 07:05 PM
Member #5508
everyone here is explainging classic fuel pump issues and for those not covered under warranty you can buy a replacement pump on ebay for 20-30 bucks
09 OUTTY 800R MAX,30 in silverbacks,108SS OFFSET RIMS,RICOCHET SKIDS,BIONIC SPINE,SNORLKES,RAD RELOCATED,TEMP GUAGE,2IN lift, black hmf utility and fuel controller,custom made kn air filter (09 style)... steerig stabilizer, QSC PRIMARY
07-19-2011, 06:01 AM
Member #15447
Thanks Blacky, guess I will have to look at that then. So does a fuel pump act up more frequently once the bike is hot?
08-27-2011, 10:44 PM
Member #10427
Vapor lock. Mine did the same thing, gas cap whistling etc. Ride faster is what I did, solved the problem.
2010 800 outlander fuel pump problem, atv just shut off while on a ride and never crunk up again had to drag it home, can am fuel pump, can am fuel pump problems, can am outlander 800 fuel pump, can am outlander 800 fuel pump vapour lock problems, can am outlander 800 vapor lock, can am outlander fuel pump problems, can am renegade fuel pump, can-am fuel pump replacement, fuel pump problems can am outlander 800, outlander 800 fuel pump, renegade fuel pump, renegade fuel pumps??? problems, www,can-am renegade 2010fuelproblen
