04-12-2006, 01:40 AM
Member #234
Location: Good fer' Nuthin', No 4-Whellin' Allowed, Florida, USA
If you take a look in the McMaster-Carr catalog, catalog 112, pg.193 you will find some "Super-Flexible,Extend and Compress Aluminum Duct Hose"
Temp. Range -100 to +500F...Flexibility: Very Flexible....Abrasion Resistance: Good....Compression: 83% of extended length.
Starts at 3" I.D.... But the beautiful thing about this stuff is it will "conform" to irregular shapes.
So I'm thinking of takeing the factory snorkel off at the trans. cover, where the rubber boot is that connects the hard plastic snorkel tube to the trans. cover, and slapping this stuff on and ever so gentley tightening a worm clamp around this stuff. Then routing it up and over the air-box....so on and so forth. Might even put a bilge blower down stream.hehehe
What do youthink? Web Site mcmaster.com
Outlander 800XT Camo
14" ITP C-Series w/ 27" Mudlite XTR's
Skids and A-Arm Guards- Rack Extensions-
Heated Thumb Throttle and Grips- Custom Gun Scabbard Mount-
Fender Mud Guards- Custom Hand Guards-
1 1/2" Drawbar Receiver- GPS- Tamarack Quad Trunk-Crutchfield Stage 2 Shocks Front and Rear- Inner and Outer Rear Aluminum CV Boot Protectors- Custom Stainless Heat Guards Around Trans.(These are the ticket!)- 100W Reverse and 110w/135w Silverstar Headlamps- Odyssey Battery-
Quick Connect Battery Jump Connection-
- Aaen Mega Power Pipe- More on the way!
04-13-2006, 02:06 PM
Member #620
Heres more! There is a 2inch to 2inch rubber elbow that connect to the belt cover. Then you put a very small piece of 2 inch pvc to connect the runner elbow to a 2inch to 2 inch PVC elbow. The a 2 inch to 1 12/ inch reducer to connect the pvc elbow to the 1 1/2 spa hose. run the spa hose up the side of the box then put a 1 1/2 elbow and tuck under air box however high you want to go.
04-13-2006, 02:09 PM
Member #620
another view
Member #620
another view
04-13-2006, 02:10 PM
Member #620
another view
Member #620
another view
04-14-2006, 05:26 PM
Member #620
This is how I ran mine out from the front. Works good in the winter for a hand warmer! Still need to run a small bead of rvt around the outside to touch it up. It looks way better than the pics show. The crome really sets the bike off.
04-14-2006, 05:28 PM
Member #620
Left the pipe white, so you good see how it was sitting in there. Once its painted black you can't see the pipe. this a small crome housing like that on a boat cover. It's made out of brass so it will never rust.
04-14-2006, 06:19 PM
those chrome ports were a good idea and for you Minnesota fans those are custom breather inlets and not snorkels  ... it was born a snorkle and raised a snorkle but now its a ...... LMAO
04-14-2006, 06:38 PM
Member #620
This is the exhaust for the cvt.
