04-16-2006, 09:25 PM
Member #65
What kind of grease is everybody using for the 8'er? How often is everybody greasing it?
06 Outlander 800 XT Camo-Ricochet skidz, HMF pipe, Dobeck, Dalton
03 Honda Rincon- MBRP pipe, Dynojet Kit, K&N
Team Outty 800 Member #4
04-17-2006, 06:08 PM
Member #204
I use Bombardier suspension grease for u-joints and front suspension grease zerks. Part number 293 550 033. I grease mine every 1000 miles. There are a total of eleven zerk fittings. Three on u-joints and eight on front suspension.:aniwh:
2006 Yellow Outlander 800 XT
Works Performance Shocks
XM Radio
Vip Air windshield
Hand and Thumb Warmers
25" bighorns
ceramic coated exaust
2007 700 Camo Grizzly
XM Radio
Hand & Thumb Warmers
Vip-Air Windshield
25" Bighorns
04-17-2006, 06:10 PM
Member #260
Wow I missed some then! I will have to look again
NRA LIFE Patron MEMBER!
Can-Am Outlander 800 Camo
Dalton Clutch
BRP Heated Grips
Leed Eng. 2" reciever
HMF+Doebeck TFI
Ceramic Exhaust
BRP MudGaurds
Line-X Racks & Bumpers
28" MudBugs, ITP BLK Type 7\'s
25" BigHorns
04-17-2006, 07:09 PM
Member #90
What is the reasoning in doing it say every 1000 miles versus 250 miles. I have seen talk of greasing after every water ride, or every other without water.
Everyone chime in here and get some good grease "101" going, im interested......
drpep wrote:
This is my signature, there are many like it, but this one is mine.
04-17-2006, 07:10 PM
I use Amsoil Synthetic Water Resistant Grease
eight fittings?
04-17-2006, 07:26 PM
Member #204
There are two zerks on each A arm,upper and lower for a total of eight. There is one on front u-joint and two on the rear u-joints. The vehicle manual doesn't identify all of them. I don't ride in mud if I can avoid it and in general don't ride in deep water. For those that do they should be greased more often. :aniwh:
XM Radio
Vip Air windshield
25" bighorns
XM Radio
Vip-Air Windshield
25" Bighorns
05-13-2006, 06:25 PM
Member #792
Did anyone but me have trouble getting gease into the rear universals. I replaced the one closest to the motor with a 90 deg. zerk but could not get the rear one out. I held the gease gun on as tight as possible and got gease in with a lot of mess. Any ideas to make this easier?
05-13-2006, 06:32 PM
Member #216
Take the grease coupler off the gun and grind it flat on two sides,just be careful not to grind too much off.This is what I did and you canget it on enough to get it to take grease.
06 800 Outty Max XT Red
05 400 Outty Max XT Yellow
05-13-2006, 08:56 PM
Member #312
A needle adapter makes greasing the u joints alot easier.A lesson learned with the ole Grizz 660!:wh:
06 outlander 800
07 Arctic cat 700
05-13-2006, 09:14 PM
Benefactor Gold
Member #396
Also someone on another thread about this said if you keep turning it, you will hit a sweet spot that the gun will fit into.
Wear a patch like my avatar to hospital emergency room, clears it out fast.
Vote For Us!!
2005 bombardier 400 max lube fittings, 293 550 033, atv grease type, atv synthetic grease, buy 293 550 033 grease, can am grease, can am pn 293 550 033, can am suspension grease, can-am suspension grease, canam atv grease fittings, grease 293 550 033, grease for can am atv, grease zerks honda atv suspension, powered by vbulletin 550 am radio, suspension grease can am, suspension grease p/n 293 550 033, synthetic grease 293 550 033, what kind of grease can am atvs, what kind of grease for can am atv, what type of atv grease should i use?
