2003 Rally? I need help PLEASE - Can-Am ATV Forum
This is a discussion on 2003 Rally? I need help PLEASE within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Hi there, Im Angie a single mother and my 10 year old just bought his first 4 wheeler today with all his savings, it was ...
Old 07-07-2011, 11:33 PM
Member #17165
View angie's Photo Gallery(0)
Angry 2003 Rally? I need help PLEASE
Hi there, Im Angie a single mother and my 10 year old just bought his first 4 wheeler today with all his savings, it was $1300, it is a 2003 bombardier Rally and need your help..... We had it 10 minutes and when he was driving it, it just died and now it will not start. I took out the battery had it tested and it was no good now, so I went and got a new one and put it in and still all I get is a click? help us please, I do not have tons of money to put in this thing. :-( and he is bumming
Also I tried hitting the starter and does nothing any help would be great..
Old 07-07-2011, 11:48 PM
Member #16778
View brady's Photo Gallery(0)
starter or ignition might be pooched.. check the spark plugs, maybe out of gas?? haha if he is it takes time to get it going again..
Old 07-07-2011, 11:49 PM
Wyldlander's Avatar
Member #2451
View Wyldlander's Photo Gallery(0)
Check the fuses and the spark plug. Might be good to check all battery connections to make sure they are tight( while you're doing this, get some Dilectric grease and grease the electrical connections).
Also check to see that the engine cut-off is switched on. ( also there should be a fuel cut-off switch on the side of the machine, Check to see that it is on).
2008 Outlander 650 max XT in Yellow,Full Ricochet skidplates, Amsteel synthetic line, 26 inch Maxxis Bighorn 2.0s, HMF Performance Utility pipe( in Yellow), HMF fuel controller, BRP rear box, Tigertail w/1.25 reciever, Gade footpegs, Kolpin/Moose overfenders, (1) gallon Rotopax fuel pack( just in case)
Cumberland ATV Riders
Southernoffroadriders
My Youtube channel can be found here:
http://youtu.be/0h8WlovZRA4
The Following User Says Thank You to Wyldlander For This Useful Post:
angie (07-07-2011)
Old 07-08-2011, 12:07 AM
Member #17165
thanks
thank you, you guys...
LOL it does have gas... The battery connection is good and tight and a new battery, charged it for 8 hours also. The gas switch by the carb is on, it reminds me of when I had a problem with my starter on my car and you could jump the solenoid, so i tried that, and plenty of sparks there, but nothing. You can feel the starter click and the solenoid.
So I heard to take the starter off and leave it plugged in to see if the starter turns and if it doesnt then I will know I need a new starter but I was also told if the starter turns the motor could be shot? This is why I am freaking out, the starter costs enough as it is being my 10 year old just bought it this morning but a motor would kill me..
Old 07-08-2011, 11:10 AM
sscard's Avatar
First Name: Shane Cardwell
Member #16318
View sscard's Photo Gallery(0)
what part of minnesota, I have a buddy up there that is a pretty good mechanic, he just rebuilt a renegade
when you jumped the solenoid and got sparks what happened?
did it try to turn over?
I apologise for not being more familiar with the specific machine but Im sure someone on here is going to hit it on the head
oh and fyi, if the oil looks good and the motor wasnt making weird noise before it quit I doubt its a motor
since it died while running I do believe it could be a short of some type
800 R Outlander
800 Max Outlander
29.5 outlaws, extra set of crushed 31s
Old 07-08-2011, 11:26 AM
sscard's Avatar
Member #16318
just did a little reading on the unit
seems there is a plastic spring and clip that holds the machine in neutral and it will not start if it is not getting a signal to say it is in neutral
try playing with the shifter and see if it starts
800 R Outlander
800 Max Outlander
Old 07-08-2011, 11:28 AM
Member #17165
I live in North Branch MN, I am 30 miles north of the twin cities... But when I tried to jump it, it just clicked, nothing changed, but I am thinking it is the starter, I just found out when talking to the guy I bought it from that he had the timing fixed and I think maybe the guy messed it up and the starter is stuck on a notch and just wont turn, cause the starter feels like it wants to turn when you touch it. I have a buddy coming over tonight to see what he can do, he is pretty good with this stuff.. I will keep updated, but love to hear other peoples suggestions... it helps, ty
Old 07-08-2011, 11:33 AM
Member #16778
ya its more than likely something eletrical.... it could be the carb on those things too... could be all gummed up and not working properly or even seized.. dont worry tho if its that you simply take it off and clean it up... carb could be stuck shut. something to look at
Old 07-08-2011, 11:41 AM
sscard's Avatar
Member #16318
its not turning over, i wouldnt jump on the carb just yet
may also pull the plug and see if it will turn over wtihout it, may signal a bad starter or loose connection, if it will turn it over with no compression but will not with compression
800 R Outlander
800 Max Outlander
Old 07-08-2011, 12:03 PM
Member #17165
ok update.... well I charged the new battery last night and just put it in, the starter is spinning but wont turn over though. could it be possile that the timing chain got stuck and my battery was not good to begin with that it would not turn starter completely and now the new battery turned the starter and broke the timing chain?
02 bombardier rally jump start
05 bombardier rally 200 solenoid how to remove
2003 bombardier rally 200 flywheel wont turn
2003 bombardier rally 200 parts won't start
2003 bombardier rally 200 starter just clicks
2003 bombardier rally 200 timing chain
battery rally 200
bombardier rally 200 flywheel wont spin
bombardier rally 200 timming chain set
bombardier rally 200 wiring diagram
can am rally 200 no start issue
can am rally 200 timming chain set
rally 200 no compression
rocker arm 2003 rally 200
what kind a engine u can install in bombardier rally
Just Acquired a 2003 Bombardier Rally 200 IronBear Can-Am / BRP 3 11-29-2010 01:13 PM
2003 Rally Needs Piston Kit Aintskeered Can-Am / BRP 0 05-05-2010 06:34 AM
2003 sportsman 600 can8 Polaris 0 04-18-2010 08:03 PM
2003 250 trailblazer frank giles Polaris 2 04-28-2008 06:53 PM
2003 Vinson lefty1953 Suzuki 2 01-21-2006 07:52 AM
