01-15-2012, 07:35 PM
Member #11543
Anyone painted there rad?
I am considering spraying my rad black before installing my rad relocate kit, I think it would look better. Was wondering if anyone has done this? I know lots of old hot rods cruising around with painted rads but what about a 800 with a cooling system that is already maxed out?
[I]2010 800XT, 28" MUDZILLA's, SS 212's,PCV,Autotune, xmr snorkel kit,BRP rad relocate, QSC Adj. clutch kit, 650 helix, Full skids,Pro taper Bars, Rox risers, Big Gun exhaust, UHMW frame mod, 55W 6000k HID, Renny Pegs, BRP cargo Box, brp mud guards, Symtech hand warmers, Twin Air, fan controller, hpg shocks, HD springs
2011 650XT MAX, full ricochet skids, alumatech rears, UHMW frame mod, BIG GUN exhaust, "XTP" wheels, 27" XTR radials, BRP cargo box
01-15-2012, 08:00 PM
First Name: Vanilla Gorilla
Member #19419
as long as it's a lite coat i don't see a problem. i did a lite coat off flat black on my bike engine that is air cooled and i didn't notice a rise in temp even check with my temp gun.
2012 Outlander Max 650 XT-P - Black Ricochet Skids,BRP Snorkels, BRP Rad Relocate, Renegade Foot Pegs,BRP Cargo Box with quick release, Temp and Volt Gauges, 1" wheel spacers, Hayden Fan Controller, One way bearing mod and Dalton clutch kit.
1989 Yamaha Warrior 350 - skid plates,tusk front bumper,protaper bars,rear cargo rack, Kenda bear claws and other little goodies.
The Following User Says Thank You to RoyBoyz69 For This Useful Post:
01-16-2012, 08:20 AM
First Name: HNIC
Member #18992
I wouldn't because its gonna hold heat and if you do a light coat its gonna flake off here and there and really look like crap.
"You can say 'stop' or 'alto' or use any other word you think will work but I've found that a large bore muzzle pointed at someone's head is pretty much the universal language."
- Clint Smith
01-16-2012, 09:20 AM
Member #12221
2X
As you should already know the CA cooling system is not the best designed in the first place. Paint will only insulate the fins and slow the cooling down. It will start pealing shortly and then the pealed paint will plug the airway. As it is unless you are using the Temp controller to bring the fan on at 160* the cooling system in next to nothing untill you get up to speeds over 30 MPH.
You would only be making a bad problem worst by painting the fins.
The Following User Says Thank You to Mile Hi Outlaw For This Useful Post:
01-16-2012, 03:16 PM
Perf Tuners
Member #2653
I painted the outside part of the rad (not the fins) and have not had a problem.
01-16-2012, 03:36 PM
Member #19419
yes you only paint the tanks NEVER EVER PAINT THE FINS!!
01-16-2012, 03:51 PM
Plywood garage floor?? Would be nice in the winter but... Flammable all the time... lol
Radiators are bare aluminum or copper for a reason... Now you could Anodize them.... that would be fine..
01-16-2012, 10:11 PM
Member #5864
I painted the Rads on my KX500. It worked great. The trick is to do 2 to 3 light coats. Dont rush it and you should be fine. If anyone knows about KX500's. They run hot anyway.
07, Outy 650XT, 29.5 Outlaw 2's w/w combo, MSA diesels , Custom snorkels, 1' spring and pipe lift. Aaen Power pipe, Twin air filter. ------------------------------------------------------------------------------------------------------------------------------ Soon to be mods. Rad re-locate, Ricochet Skids, ATR chassis spine. More to come. -----------------------------------------------
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein ---------------------------------------------------------------------------------------------------------------
01-17-2012, 02:25 PM
Member #8848
x 2
On fins the pain will behave like insulation and reduce the heat transfer rate.
fear is temporary, regret is forever
01-17-2012, 04:35 PM
Anodizing is easy.... They sell kits aswell...
ac wildcat muzzy, can+am atv, can+am forum, can+am renegade, colony cargo reviews, has anyone painted a can am commander, renegade foot pegs on outlander
