Mighty Tite Trailer Hauling System
This is a discussion on Mighty Tite Trailer Hauling System within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; No tickets on my system as it's totally legal and more secure then most tie-straps. Last summer I went through an MTO road side inspection ...
  #21
Old 03-29-2012, 02:35 PM
Wildwr's Avatar
Member #9576
View Wildwr's Photo Gallery(0) Send a message via MSN to Wildwr
Last summer I went through an MTO road side inspection and they were handing out tickets like crazy.
My tiedown system passed with flying colors.
The inspector commented that the majority of people focus so much on the straps themselves that they fail to recognize a secure anchor point.
They also commented on ATV winch as being an illegal tie off point.
WayneR
Authorized Amsoil Dealer
2008 Can-Am Outlander 800XT RED
EZ Steer Power steering (Super ATV)
Flex-A-Lite Fan controller
BRP rad relocator kit
Ricochet skids
XMR Console/Dash
Elect. Gauge pod trio (by Paul Ashby)
12 inch Douglas Rattlesnakes w/27 inch Zillas
ATR Chassis Spline
UNI Filter
XMR snorkels
Dalton DB800 clutch kit
Gates G-Force belt
HPG shocks w/HD Springs (front)
HPG shocks w/Stage 1 Crutchfield spring kit (rear)
BRP Handwarmers
BRP Thumbwarmer
Direction 2 fender extenders
  #22
Old 03-29-2012, 04:54 PM
WiNdGaDe800's Avatar
Well I live in the USA, we have bigger idiots running our country but so far they only pull you over if your speeding.
  #23
Old 04-04-2012, 06:31 AM
First Name: Enginner
Member #21874
View QWIKRelease's Photo Gallery(0)
Default atv mighty tite
Hello stubbyone50,
You had questions about the ATV Mighty TiTe system. First, is there a place for a padlock thru the lockdown mechanism incase you have to leave your vehicle unattended? Yes there is a place to instsll a Lock thru the tension arm. Is the lockdown mechanism adjustable so it will fit Independent Rear Suspended quads, specifically Can-Am's TTI rears? Also yes, The ATV Mighty TiTe system will work fine on an Independent Suspension. And how much does it cost to ship the kit? This varies according to your location. The sytem in the box weighs about 40 lbs.
The price doesn't seem too bad, there's a lot of steel in there, plus fabricating, welding and powder coating. Not to mention the designing and patent costs. I am presently having discussions with a manufacturer in Tenn. which hopefully will get the sale cost down to around the $200 mark. I designed this system to be Fast and Strong. The fabrication prices are what they are. I don't want to produce a marginal product because I use this system myself. I lost a 4 wheeler off a trailer years ago and DO NOT want to go thru that again. Your machine is a big investment in your fun and is worth protecting with the best equipment you can get. You mentioned keeping your 4 wheeler away from the back window of your truck-I also took out the window in a truck with mine. The ATV Mighty Tite system prevents that from happening. When you slide the front wheel cages in place, they can't go forward any further. I don't like the permanent mounted tire chocks because I haul all kinds of stuff in the bed (like sheet lumber) so I like how this system is removable. The ATV Mighty TiTe components slide on and slide off in seconds so you can use your trailer for other things. I haul gravel, firewood, refrigerators and everything else. After dealing with ratchet straps 6 or 8 times a weekend sometimes, this system looks right up my alley. Make sure you post another thread on this forum when more become availabl. I want to be able to offer the best product for the best price so I'm not rushing into anything. Made in USA quality is one of my strong points. Hopefully as the economy gets better, so will my prices. We are sold out of the ATV Mighty TiTe right now but will be available soo. The system will fit front tire sizes up to 27 x 10. With some minor modification, they will fit even bigger sizes. The rear tensioner uses your ATV trailer ball receiver and a special threaded end chain for a very secure set up. Hope this answers all your questions. If you have more, just give me a call at the number on the website.
  #24
Old 04-04-2012, 06:37 AM
SmokeyMcBong's Avatar
First Name: i am the cooker of the foods
Member #17393
View SmokeyMcBong's Photo Gallery(0)
welcome aboard QWIKRelease, thanks for joining in to the convo.
2013 Can-Am XMR 1000!!!
http://www.youtube.com/user/mcbongsmokey?feature=results_main
KawarthaATV director/chef - www.katva.ca
  #25
Old 04-04-2012, 06:59 AM
Tumbleweed's Avatar
Member #3163
View Tumbleweed's Photo Gallery(0)
I like the idea, but question the fact that if the rear tie down should somehow fail, then you really have no tie downs. The fronts could become ineffective while bouncing down the rough roads going into various trail heads. There needs to be a secondary, fail-safe attachment. Picture my scenario on a side loaded trailer.
Welcome aboard. Good Luck with your venture.
Jerry
'11 800R Max XT Outlander - Ricochet skids. VIP-Air Windshield. 26.5" Rockers on OEM rims. 1" wheel spacers. Hot Grips.
'11 650 XT Outlander - Ricochet skids. VIP-Air Windshield. 26" Bighorns on 14" black ITP 212s. Hot Grips.
  #26
Old 04-04-2012, 07:43 AM
Member #21874
Hello Tumbleweed,
This is true but the rear tensioner is way strong. I have bounced my trailer with ATV onboard over a drainage ditch sending it 1 1/2 feet off the ground going 25mph and the 4 wheeler stuck like it was glued on. At some point it might break but I would hate to see what it would take to break it.
  #27
Old 04-04-2012, 07:54 AM
hedge's Avatar
Member #7142
View hedge's Photo Gallery(0)
We've talked a bit about it in our group but not sure if it's legal because we have to have a 4-point tie down.
I love the idea though, I'm so sick of ratchet straps.
2012 Outlander 1K, 28" Zillas on 14" MSA Vice beadlock rims, Ricochet skids, Muzzy Dual Full system + PC5, Elka Stage 4 shocks
http://www.youtube.com/user/hedge8888
The Following User Says Thank You to hedge For This Useful Post:
campingnut (04-04-2012)
  #28
Old 04-04-2012, 01:31 PM
Member #18951
View stubbyone50's Photo Gallery(0)
Thank You, QUICKrelease for your response to my questions. That is exactly what I was hoping for...clear, concise, and more info than I thought to ask for (as I run 27x10x12 tires on the front of mine). Also thank you for looking into working on the price. Every little bit helps nowadays, but I agree, I'd rather pay more for something that's built here and built strong.
Again, please post here when more become available, as I am definitely interested. If you're looking for people to test your system and write a testimonial/spread the word in return for a discount off the purchase price, I'd be willing to do that also. There are tons of ATV owners in my area. Either way, good luck with your venture, it looks like a winner to me.
  #29
Old 04-10-2012, 09:35 AM
Member #5191
View motoalliance's Photo Gallery(0)
Glad to see QWIKRELEASE here. We've decided to pass on the manufacturing of the system as we could not get enough cost down enough at this point to make it feasible for us to invest. But they are really good and sharp people at Mighty Tite and I think they will have a winning system on a number of levels.
Thanks for the great feedback. Have a good week everyone.
Peter
President
Motoalliance
Moto Alliance
  #30
Old 04-10-2012, 10:41 AM
uprightshark's Avatar
First Name: Paul
Member #19331
View uprightshark's Photo Gallery(0) Send a message via MSN to uprightshark
Quote: Originally Posted by Wildwr View Post
The end product looks nice but the price point is a bit high.
I built my entire system for about $25 in material and an enjoyable afternoon in my garage with some coolies.
Really nice system Wayne. Are you building to sell, or is this something you dod for yourself?
Uprightshark
SHARK WARNING! Keep your wheels out of the water!
My Ride: White 2013 Commander Limited
BRP full skids, rock sliders, tanneau cover, Dalton Clutch kit and mirror.
atv hauling systems
atv might tite
atv mighty tight quick release tie down system
atv mighty tite
atv mighty tite reviews
atv mighty tite tie down system
atv mighty tite transport tiedown system for sale
atv strapless tiedowns
atv trailer lock down
atv trailer system
mghty tite transport system
mighty tite atv
strapless atv tie down
Which one of yall is hauling your outty like this token Can-Am Outlander 11 07-23-2011 11:23 AM
Mighty mouse 500 Outlander - Soggy Bottom Boyz Soggy Bottom Boyz The Mud Pit 5 02-28-2011 08:25 AM
Loc tite Strength hardy1000 Can-Am Outlander 8 04-24-2010 07:09 PM
Hauling Timber GAUP Can-Am / BRP 12 09-27-2006 02:02 PM
