bombardier 330 timing chain marks
This is a discussion on bombardier 330 timing chain marks within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Hi does anyone know about cam chain timing marks on these bikes i can see the cam marks but not any crank marks I have ...
Old 04-09-2012, 01:02 AM
Member #21972
View mrkiwi2's Photo Gallery(0)
Default bombardier 330 timing chain marks
Hi does anyone know about cam chain timing marks on these bikes i can see the cam marks but not any crank marks I have been told they maybe the same as the can-am 400 any help would be good thanks
Old 04-09-2012, 04:39 AM
View QUADAHOLIC's Photo Gallery(58)
Gonna move this to a more appropriate forum. You'll get more "views" here.
The Following User Says Thank You to QUADAHOLIC For This Useful Post:
mrkiwi2 (04-09-2012)
Old 04-10-2012, 05:10 AM
OH BTW to the site.
bump
Old 04-10-2012, 10:43 AM
Member #12940
View Over50's Photo Gallery(0)
Unplug spark plug cable then remove the spark plug.
Remove valve cover (refer to CYLINDER AND HEAD).
To place piston at TDC, pull rewind starter to rotate
crankshaft until piston is at TDC compression position.
Or take off CVT cover and turn by hand.
Remove screw
no. 1 and sealing washer no. 2.
Look for the screw to the right of the front output shaft with a slight angle pointing downward,
position about 4 oclock to the shaft and about 1 inch (25 cm) < or> away from output edge
Use a screwdriver to check for groove in crankshaft
is aligned with the hole.
Try and download the manual for a 04/400, it does refer to the 330 in there.
If it were me I would take off CVT cover, then take out spark plug, attach plug back to plug wire like it was in machine and ground body of plug to cylinder head and turn key on and turn motor over by hand with primary front clutch, till you get the spark at plug, now you should be close to TDC. Stick a drinking plastic straw into cylinder and now rotate motor back and forth till you feel motor piston at TDC, now you could set the cam with marks on side of cam gear and install chain if that is what you were trying to do. Hope this helps
The Following User Says Thank You to Over50 For This Useful Post:
QUADAHOLIC  (04-10-2012)
Old 04-10-2012, 11:52 AM
Member #13825
View sargent-tom's Photo Gallery(0)
When you get it locked on TDC align the two marks on the cam gear to be parallel with the valve cover gasket flange of the cylinder head.
05 can am 400 crankhaft
330 bombardier
330 outlander motor view
bombarder atv 400 chain
bombardier atv crankshaft
bombardier atv forum
bombardier engen timing
bombardier marka atv forum
bombardier timing
canam 450 timing mark
how do you fix the timing chain on a 04 330 can am outlander
how to replace a broken timing chain on a 330 bombardier
pictures of timing chain for 05 bombardier atv
timing a 330 bombadier
timing marks on can am
Timing chain info Camofcourse Can-Am Outlander 10 03-30-2012 04:51 AM
timing chain ???? steeliedit Can-Am Outlander 5 01-07-2012 06:11 AM
400 dropped timing chain?/ fastdart360 Can-Am / BRP 5 11-09-2011 06:35 PM
Timing chain off Bubba n TX Can-Am Outlander 2 05-27-2010 12:41 PM
timing chain tensioner RenRunner Can-Am / BRP 0 09-09-2007 10:35 PM
