smoking crankcase vent tube...HELP! - Can-Am ATV Forum
post #1 of 15 Old 04-09-2012, 07:01 PM Thread Starter
Just noticed my wifes crankcase vent blowing smoke,,,it feels like steam and isnt blowing really hard.
married06 is offline
post #2 of 15 Old 04-09-2012, 07:04 PM
murderedcanam's Avatar
There be no steam coming from there
I am here: http://tapatalk.com/map.php?cdgufp
08 outti 800 xt
4" up & back catvos
14 m12's
31" laws
Highlifter triple flow on the front rack
Pc3
Twin air
Hmf
Hid's
murderedcanam is offline
post #3 of 15 Old 04-09-2012, 07:09 PM Thread Starter
What would be the cause...any help would be appreciated.....Blow by? How would i trouble shoot? Just dont want to damage anything
post #4 of 15 Old 04-09-2012, 07:14 PM
DieselDad's Avatar
Need to do a compression test on the cylinders. Not sure of acceptable numbers. Maybe Mr.RPM a senior member would know the acceptable compression numbers.
DieselDad is offline
post #5 of 15 Old 04-09-2012, 07:26 PM Thread Starter
sounds good any special compression tester for can am?
post #6 of 15 Old 04-09-2012, 07:36 PM
crazypj's Avatar
How cold has the weather been?
How high is the humidity level?
How far does it get ridden?
Does rear of engine get too hot to touch (it should)
Try getting it hot and doing an oil change, could well be water/condensation in the oil
I'm not a complete idiot, but, I'm working on it
crazypj is offline
The Following User Says Thank You to crazypj For This Useful Post:
married06 (04-09-2012)
post #7 of 15 Old 04-09-2012, 07:44 PM
DieselDad's Avatar
Thats a good "?" May be able to check and match spark plug threads to one up at a the parts store. They usually have the loan-a-tool program and could help.
I've found that 175 psi is about what your looking for. See this link: Compression Check
post #8 of 15 Old 04-09-2012, 07:58 PM Thread Starter
Thanks crazy sounds like a winner will do...and diesel, my wifes outty is a 500 so should the psi be different?
post #9 of 15 Old 04-09-2012, 08:13 PM
DieselDad's Avatar
Yes, I would think so but i don't know by how much as the 175 looks to be for the 800's.
I would think that both of the 500's cylinders should be real close to the same numbers though. Wished I could help more. I suggest that you may want to call a couple of the dealers like the ones suggested on this site or your local dealer to get the numbers as it would depend on the make/year/model specifics. I'm not sure how "freely" they will give this type of info out but I would think that MrRPM would be the best bet for an outside source on this type of info.
For instance, the 2012 numbers listed here.
For the 800 - Bore x Stroke 91 x 62 mm
For the 500 - Bore x Stroke 82 x 47 mm
The Following User Says Thank You to DieselDad For This Useful Post:
post #10 of 15 Old 04-09-2012, 08:19 PM Thread Starter
Great...thanks for the info...appreciate it
Need quick help gearbox vent tube. kd7joe Can-Am Outlander 10 03-04-2012 03:58 AM
Gas in the crankcase oil...... fox128 Can-Am Outlander 8 08-13-2011 07:57 PM
Rear differential vent tube leaking Chia292 Can-Am / BRP 0 03-23-2010 05:24 PM
Vent Tube on Trans Sterg Can-Am / BRP 6 08-29-2008 09:25 AM
Vent tube rerouting JAM NC Can-Am / BRP 9 05-05-2008 10:39 AM
