Outlander Rad Relocate Issue - Can-Am ATV Forum
This is a discussion on Outlander Rad Relocate Issue within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Both of my Outlanders have the Can Am Rad Relocate installed. On each of them the rubber bushings have worn and had to be replaced, ...
Old 11-10-2012, 08:42 AM
taurus31's Avatar
Member #5760
View taurus31's Photo Gallery(0)
Both of my Outlanders have the Can Am Rad Relocate installed. On each of them the rubber bushings have worn and had to be replaced, on my 2011, the bracket on the rad actually broke off , on a long ride, and the rad had to be replaced.
Anyone else having this issue with the rubber bushings? Or have a good fix, other than replacing them often?
Old 11-10-2012, 08:44 AM
gbroad23's Avatar
Member #4746
View gbroad23's Photo Gallery(0)
What relocate kit do you have?
07 outty 800 max xt, XMR stealth snorkels, Fox evolution shocks, CV tech primary by Airdam, 650 helix, Y/B Dalton secondary spring, Odyssey pc680 battery, 5000 pound viper max winch, 28 " Swamp Fox with off set rims, Full Ricochet skids, Moose Grip/Thumb and seat warmers, steel frame mod, Wild bore rad relocate, Allballs Tie rod ends, ATR heavy duty tie rods, All balls ball joints and wheel bearings, XMR dash pod, extended vent lines, updated cvt back plate, custom built steering stem (2" longer than stock), MRRPM 840 bbk, stage 1 drop in cams, Throttle wedge mod, PC5, FMF slip on, O2 bungs welded for dual tune.
Old 11-10-2012, 08:57 AM
taurus31's Avatar
Member #5760
The one straight from Can Am - dealer installed
HTML Code:
http://store.can-am.brp.com/product/474832/715001178/_/Radiator_relocator_kit
Old 11-10-2012, 09:27 AM
christisk's Avatar
Member #18241
View christisk's Photo Gallery(3)
Hmmm.....I have never heard of others having those issues. granted I have not had mine on that long but I have had zero issues with mine thus far on a 2011. maybe yours rattles too much due to metal on metal during install? I put rubber bumpers inbetween all metal when i installed mine.
The Following User Says Thank You to christisk For This Useful Post:
GunnyE9  (11-12-2012)
Old 11-10-2012, 11:00 AM
taurus31's Avatar
Member #5760
Thats a good idea - when I replace the rubber bushings I will check it out to see if I can get some rubber in strategic place to combat the rattling.
Old 11-10-2012, 12:20 PM
gbroad23's Avatar
Member #4746
Probably cheaper to get the rad mount welded than replace the hole thing. Mine broke and I was gonna get a buddy to weld them but I found a new rad for $100.00 Havent changed it yet though. Tarp straps are currently still doing there job.
Old 11-11-2012, 11:59 AM
Member #6668
View ostacruiser's Photo Gallery(0)
I had two sets of rubber bushings wear out on me on my 2010. I just hard mounted it with large washers, been perfect ever since. I don't think the rubber bushing were designed to sit with the rad laid back and weight on them all the time, that's why they fail quickly...and like you mentioned when they do fail your rad flops around
Tags
radiator relocate system
2006 can am outlander 800 radiator
2011 can am outlander rad relocate
best outlander rad relocate
07 Outlander 800 relocate (custom) Dorgie Can-Am Outlander 6 07-07-2012 08:35 AM
06 outlander max electrical issue - need help shive Can-Am Outlander 2 04-02-2012 01:56 PM
outlander 800 xt electrical issue?? i think STEEPFALLSLEDNECK Can-Am Outlander 12 09-22-2011 06:32 PM
Outlander 800r x mr Radiator relocate system (STOCK) PHOTOS gator Can-Am Outlander 20 03-22-2011 08:27 PM
Outlander 800 Clutch issue retic Can-Am Outlander 3 04-20-2006 09:57 PM
