Battery ?????
This is a discussion on Battery ????? within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Does anyone know if Optima or some other similar type extream battery is available for the outlanders. I looked at the Optima site and could ...
Old 03-21-2007, 04:59 PM
cc1999's Avatar
Member #682
View cc1999's Photo Gallery(317)
Does anyone know if Optima or some other similar type extream battery is available for the outlanders. I looked at the Optima site and could not find any details.
Or has anyone found a better grade battery than the OEM.
My battery was just fine 3 weeks ago but last weekend I had to steel the battery out of the Renegade to get the Outlander going, when weat the dunes.
Current Quads:
2012 Can-am 1000 Outlander XT Black
2011 Sportsman 850 Touring LE
2009 Sportsman 850 XP EPS Stealth BLACK
with Bighorns on 14 inch Hipers, Handguards, storage boxes, backrest, Sport bumper, Pia lights, 35oo# Winch w/wireless remote, rear work lights.
Recent Past Quads:
09' King Quad 750 W/PS,08' Polaris Sp800 X2 \ 09' Outlander 800R \ 08' ThunderCat 1000 \ 06' Diamond G Outy 800 \ 08' Honda Rincon 680 EFI \ 08' Polaris 800 RZR \ 07'Renegade 800 \ 06' Outlander 800 XT \ 06 Outlander MAX 800 \ 05' Polaris 800 Sportsman \ 04 Susuki Twin Peaks (Kawi prarrie) 700.
Old 03-21-2007, 11:14 PM
Member #45
View turboman's Photo Gallery(0) Send a message via AIM to turboman Send a message via MSN to turboman
Bike Battery
800 MaxXT,25"XTR\'s.RAM GPS,Twin-Air, Ricochet,ELKA fronts,EBC pads,Kevlar cable,PIAA bulbs,grip-reinf\'s,Leeds hitch,Precision damper,1" Rr spacers,Iridium plugs,Rene\'wgts,OEM w/shield,OURY grips,WestCo coated muffler,Saeng mirrors,flares,AGM bat
Old 03-22-2007, 12:47 AM
cc1999's Avatar
Member #682
This is more like what I was thinking about. Odessy battery's are a extream duty dry cell type battery. This model listed below is listed as compatable with the Older Outlander 400s and 330s. I am just wondering if it would work on the newer 800s.
Here are the dimensions (+/- 1/16 inch): 6 7/8" x 3 7/16" x 6 1/8 of the OEM Outlander 800 battery. I think the PC545 Odessy might just fit. Anyone have in thoughts on this.
PC 545 Specs:
  • 545 cranking amps for 5 seconds
  • 495 cranking amps for 10 seconds
  • 420 cranking amps for 20 seconds
  • Short circuit current over 1200A
  • 19 minute reserve capacity with 25amp load
  • Female brass terminal w/M6 SS bolt
  • Length 6 13/16"
  • Width 3 3/8"
  • Height 5 1/8"
  • Weight 11.0 lbs
Odyssey design:
  • 2 year full warranty
  • Rugged Drycell sealed design
  • Military grade
  • Vibration resistant
  • 60% more starting power
  • Deep discharge reserve power
  • 2 year storage life
  • 8-12 year design life
  • Can be mounted flat or upright
[align=center][/align]
Current Quads:
Recent Past Quads:
Old 03-22-2007, 01:05 AM
Member #45
The AGM batteryI indicated is:
3 1/4" W
6.75" L
6 1/8" H
This was measured off the $48 battery I have on my desk. It is supposed to be a direct replacement for a OEM YTX20-LBS, as he tnumbers indicate.
Old 03-22-2007, 01:23 AM
Member #45
remember the PC545 is almost 1.0" LOWER than the OEM battery. If you go to the Renegade batt case and metal hold-down you would need some kind of 1" thick spacer either above or below.
How much are the Odyssey batts anyway?
Old 03-22-2007, 05:01 AM
View QUADAHOLIC's Photo Gallery(58)
When I replaced the battery on my Arctic Cat it was about $90 delivered, I think it was the #680. When the one in my Outty goes I'll get another Odessey.
Old 03-22-2007, 08:31 AM
cc1999's Avatar
Member #682
What about going with that same Odessy battery but the MJ model (MJ=metal jacket model). That would offer even more protective shielding,sincethe battery is in kind of a high exposure area on the machine.
Note: that metal case does increase the demensions a little bit.
PC 545MJ Specs:
  • With metal jacket
  • Length 7.00"
  • Width 3.37"
  • Height 5.17"
  • Weight 12.6 lbs
Odyssey design:
  • Military grade
[align=center] [/align]
The PC 545MJ is a direct replacement for:
Current Quads:
Recent Past Quads:
Old 03-22-2007, 08:41 AM
cc1999's Avatar
Member #682
Odyssey also offers billet aluminum brackets custom fit to there batterys.
[align=center]PC680 Hold Down
Aluminum hold down box for the PC680 and the FAA approved small aircraft battery. Can be used with or without automotive terminals.[/align]
Also available with a textured matte black finish
  • [align=left]Lightweight aluminum weighs less than 1 pound[/align]
  • Great for buggys, cars, and small aircraft
  • Brushed finish suitable for painting
[align=center]
Click any image for a larger view[/align]
Measurements:
9.5" x 6.25" x 3.1"
Bottom lip measuring 1.75" secures bottom of battery.
Three mounting holes on each side.
[align=center]PC545 Hold Down
Same style aluminum hold down box for the PC545. Can be used with optional SAE battery terminals.[/align]
Available only in the brushed aluminum finish.
Measurements:
9.25" x 4 7/8" x 3 3/8"
Bottom lip measuring 1.75" secures the battery from the under side.
Two mounting holes on each side.
[align=center]Click any image for a larger view[/align]
[align=center]
[/align]
[align=center]Aluminum hold down box for the PC925 series Can be used with or without automotive terminals.
[/align]
  • [align=left]Lightweight aluminum [/align]
Can be used on all PC925 models:
PC925, PC925 T, PC925 MJT, PC925 MJ, PC925 L, PC925 LMJ
[align=center]
Measurements:
8 9/16" x 7 1/16"
Bottom lip measuring 3/8" secures underside of battery.
[align=right]
  • Lightweight and durable
  • Four 3/8" NHRA approved mounting holes in tray
  • Custom made for our PC925, PC1200, and PC1700 series
  • Great for boats, buggies, and street rods
  • Will withstand the vibration that plastic mounts can't.
Battery pictured is the PC1200MJT
Tray measurements:
(measured at the widest part)
PC2150 billet - 15 11/16" X 7 5/8"
PC1700 billet - 15 11/16" X 7 5/8"
PC1200 billet - 10 1/2" x 7 1/2"
PC925 billet - 8" x 7 3/4"
PC680 billet - 8 11/16" x 3 7/32"
[align=center]PC680 billet
P/N - HDB 680[/align]
[align=center]PC925 billet[/align]
[align=center]P/N - HDB 925[/align]
[align=center]PC1200 billet
P/N - HDB 1200[/align]
[align=center]PC1500 billet
P/N - HDB 1500[/align]
[align=center]PC1700 billet
P/N - HDB 1700[/align]
[align=center]
PC2150 billet
P/N - HDB 2150[/align]
The PC2150 billet has a new design and is not as pictured
[/align]
Custom made battery box for the Odyssey PC925 series.
Two pieces - Top plate and bottom box.
P/N - HDB 925 P
[align=center]
Larger image[/align]
  • NHRA approved mounting holes on tray
  • Two piece construction
  • Fits the entire PC925 series
Tray measurements:
Footprint - 7 3/8" x 6 7/8"
Top measurement - 9 5/16" x 7"
We have Billet Battery Hold Downs for Optima too!
More hold down options available on the accessories page
Current Quads:
Recent Past Quads:
Old 03-22-2007, 10:45 AM
cc1999's Avatar
Member #682
Here is another higher end battery that I have found not sure if its on par with the oddyssey battery. It isby a company called Deka. This battery is an exact fit to our OEM YTX20B-LS
[align=center]Deka ETX20L Sealed Motorcycle Battery[/align]
Premium quality absorbed glass mat technology (AGM) is ideal for ATV’s, motorcycles, personal watercraft and snowmobiles.
The Deka Power Sports AGM Battery was designed for more than performance; it was designed for the enthusiast. Completely spill proof and leak proof; frequent replacement and high maintenance are over! The AGM technology increases power while improving rider and environmental safety. The key to this technology is the highly porous microfiber separators, which completely absorb and trap the electrolyte. Molded top and side connections terminals provide versatility, increased strength and durability. The Deka Power Sports AGM Battery provides the most advanced power and value in the industry and are made in the U.S.A.
SPECIFICATIONS
[align=center]
[align=center]Part No.[/align]
[align=center]CCA @ 0*F[/align]
[align=center]10 AH RATE[/align]
[align=center]Wt. Lbs.[/align]
[align=center]Wt. Kg[/align]
[align=center]Length inches[/align]
[align=center]Length mm[/align]
[align=center]Width inches[/align]
[align=center]Width mm[/align]
[align=center]Height inches[/align]
[align=center]Height mm[/align]
[align=center]ETX20L[/align]
[align=center]270[/align]
[align=center]17.5[/align]
[align=center]15.5[/align]
[align=center]7[/align]
[align=center]6 7/8[/align]
[align=center]177[/align]
[align=center]3 7/16[/align]
[align=center]88[/align]
[align=center]6 1/8[/align]
[align=center]155[/align][/align]
Current Quads:
Recent Past Quads:
Old 03-22-2007, 11:57 AM
Member #2127
View chris85am's Photo Gallery(4) Send a message via AIM to chris85am Send a message via Yahoo to chris85am
CC1999
Looks like you have been busy doing some battery homework.Cool find on theDEKA battery as there factory is about 5 miles from my house. :dan:
06 Red Outty 800 XT, Ricochet skid plates, Alumtech CV guard, Renegade foot pegs, BRP windshield & mirrors, Odyssey PC680 battery, Moose cargo boxes, Dick\'s ATV adapt-a-hitch, HMF optimizer & exhaust, Crtuchfield stage #2F&#1R, plus more to come.
battery for can am 800
battery location can am commander
battery location on can am commander
can am commander 1000 battery location
can am commander battery
can am commander battery location
can i use a battery out of a can am outlander xt in my std
can-am 2009 battery location
how to get a battery out of an 09 can am outlander
pc925
what optima battery fits a can-am outlander
what size battery does a can-am commander take
where is the battery on a can am outlander
where is the located battery on a 2013 brp commander
