Bleeding Coolant System - Can-Am ATV Forum
This is a discussion on Bleeding Coolant System within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; Gidday all, Any one found/use a fail safe way of bleeding the cooling systems. I've previously had to do it two or three time in ...
Old 12-12-2007, 04:45 PM
Member #2875
View Ntmick's Photo Gallery(13) Send a message via MSN to Ntmick
Gidday all,
Any one found/use a fail safe way of bleeding the cooling systems. I've previously had to do it two or three time in the past. I'm flushing & replacing with distilled water & "water wetter". They are pain to bleed! It's always a long process!
Cheers
Ntmick
Almost time for an upgrade
'07 650 Outlander Max Green
ITP Mudlites 27-9x12 front, 27-12x12 rear
Old 12-13-2007, 01:08 PM
JDUDDING650's Avatar
Member #1386
View JDUDDING650's Photo Gallery(0)
Its extremely easy.
There are two bleeder screws/bolts on the back of each black plastic cap on each head. It is where the coolant line crosses between the heads. All you have to do is fillteh machinefull of coolant leave the radiator cap off let it idle and get hot and then just loosen each bolt alternating sides until you get no air bubbles and all coolant.
Shouldn't take more than 5 minutes.
2010 Can-am X-team
GNCC U2 on a Renegade X XC
Dudding Racing Sponsors:
Douglas Wheel Technologies (DWT), Motoworks Exhaust, Goldspeed Tires, Can-Am BRP, Swampfox Motorsports, Hygear Suspension, Rath Racing, Powermadd, FLY GEAR, DP Brakes, Silkolene/Fuchs, Bopp Racing Components, EVS, Quadtech, Utopia Optics, Gohardracing.com, Ricochet, Atvpartsplus
Old 12-13-2007, 01:33 PM
OSOKILL's Avatar
yup another good one for the DIY thread and the canam how to stickies LOL
www.commanderforums.org
www.atvblog.net
Old 05-11-2011, 09:54 PM
sak699's Avatar
Member #9529
View sak699's Photo Gallery(0)
Quote: Originally Posted by JDUDDING650 View Post
Its extremely easy.
May b a dumb question, but i have my rad relocated on the rack,with it angled,how can i leave the rad cap off to bleed the system. Can it b left on while i do the rest of the procedure or not ?
My son's ride:
09 650 xt outty Black
29.5 laws
black ss wheels
Full custom snorkel
Skids
BRP fender flares
Dalton clutch kit
1 inch pipe lift in front and 1 inch in back
Renegade exhaust
rad relocate
My ride:
08 outty 800
Dalton mudrunner clutch kit
1 3/4 inch pipe lift
Full custom snorkel
Rad relacate
29.5 laws
Old 05-12-2011, 09:56 AM
DaveB's Avatar
Member #1412
View DaveB's Photo Gallery(0)
Yes. Do the bleeder on the rear head first as it is lower.
Pain or damage don't end the world. Or despair, or f*cking beatings. The world ends when you're dead. Until then, you got more punishment in store. Stand it like a man... and give some back.
2016 Renegade 1000 XMR: "Suck My Wake II"
QSC primary, STM secondary, Yoshimura, Dobeck 3.0 Get Torqed tuned, Rigid LED, skids, blue rope, Alpine Flex plow.
2016 Outlander 570L DPS: "Tank"
BRP snorkel and rad relocate
Old 12-03-2013, 02:29 PM
Member #29465
View Outlander650green's Photo Gallery(0)
Sorry to open up this old thread but when you guys are doing the burping technique, do you pull the screw completely out so you can tell its good flow or just to where you see it running out? Seems kinda hard to tell if you have a good flow if the screw is still there.
Old 12-03-2013, 02:42 PM
slayer1962's Avatar
Member #25958
View slayer1962's Photo Gallery(0)
Radiator relocate
My local repair shop installed a filler neck and cap from a motorcycle it is at the highest poit and level. Filling is easy and can run with it open and no spillage. I have never had to use the bleeders in the back of the engine. I filled it ran it with it open refilled it ran it again for 20 minutes and topped it off.
2012 1000 XT 27" outlaw radials hd3 rims, EPI clutch kit, 1.5" billet lift, heated grips, snorkel kit, Can Am rear storage, gas PAC., Dobeck PC5 tuner and auto tuner. Dual Muzzy exhaust! higher bars, richochett skid plates. Wild Boar radiator relocated. Removed billet lift installed Eka Stage 3's , replaced broken heated grips!
work in progress
Old 03-15-2014, 11:34 AM
sparky81's Avatar
Member #31575
View sparky81's Photo Gallery(0)
Surprised no-one has done a how to slideshow or video on this yet. Sure would be helpful. If I don't come accross one by the time I do mine I guess ill have to make one.
Old 03-15-2014, 11:54 AM
Member #12221
View Mile Hi Outlaw's Photo Gallery(0)
Mybe the reason that some are having so much trouble bleeding the air out of the system is the there is no talk of the bleeder screw on top of the Tstat housing.
http://whathappenedinmybirthyear.com/
Type the year of your birth "xxxx" Then click the QUESTION (?) MARK
Old 03-15-2014, 12:53 PM
Member #12221
Cooling system: Draining Filling and Bleeding the cooling system
Two things that can be easily over looked in the tex
Draining system: Partially unscrew plug below water pump housing.
Filling: Unscrew bleeding screw on top of thermostat.
2012 can-am commander bleeding coolant system
2014 1000 comander bleed the coolung system
2014 commander 1000 coolant bleed screw
2015 maverick air bleed
2016 can-am maverick coolant
bleed air out of coolant system on a 2016 can am commander
bleed spot on maverick 1000
bleeding a commander 1000 cooling system
burping spyder can am coolant
can am commander bleeding cooling system
can am outlander bleeding cooling system
how to access bleed screws on can am commander
how to bleed a can am outlander radiator
on a can am maverick how do you change the antirfeeze
