Suitable substitue for the isoflex grease? - Page 10 - Can-Am ATV Forum
post #91 of 99 Old 05-30-2010, 05:40 PM
Outtie's Avatar
my order is in...thanks Quadaholic for doing this for everyone..
'08 ski-doo summit
'08 500XT
Outtie is offline
post #92 of 99 Old 07-14-2016, 05:23 PM
DugT's Avatar
Tried regular grease on one way bearing?
Sorry for reviving this old thread but I noticed that no one mentioned the low temp performance of Isoflex. It is good down to -58F. It is relatively thin at room temp and maybe grease that is good at -58F must be thin at room temp. Grease that is thicker at higher temps might be even better at other requirements like not being forced out by centrifugal force. If you don't ride in temps below 0 degrees, maybe you don't need Isoflex and maybe a more viscous grease would be even better.
On the other hand, maybe more viscous grease causes too much friction at idle. Has anyone tried good high quality grease yet on their sheath or one way bearing?
I never killed nobody and I didn't rob that train.
2010 Renegade 500.
DugT is offline
post #93 of 99 Old 07-15-2016, 05:27 PM
RMINC's Avatar
Mobilgrease 28 and I think Aeroshell 20 something have almost identical properties to Isoflex. Look them up and decide from there. Theyre much less expensive.
RMINC is offline
post #94 of 99 Old 07-15-2016, 05:33 PM
RMINC's Avatar
Here you go. Had to find my old post from Dec:
Aeroshell 22 and Mobilgrease 28. Both are mil-spec oils meant for aviation landing gear. They both have similar or better performance low/high temp wise. $13 per tube.
RMINC is offline
The Following User Says Thank You to RMINC For This Useful Post:
DugT (07-16-2016)
post #95 of 99 Old 07-15-2016, 05:40 PM
PFDK3's Avatar
If you look around, isoflex can often be found much cheaper ok eBay. I wound up with a small tube, but you don't use much doing a service.
Life feels like that final exam I didn't study for.
Red 2010 Outlander Max 800 XT
Rigid LEDS,
Ricochet Skids,
Kenda Bearclaw HTR's
Frame Mod
Apache WT tracks.
Hand and thumby warmers
More mods to come...
2003 Traxter XT Autoshift
Kenda Executioners
2001 Traxter XT
PFDK3 is offline
post #96 of 99 Old 07-16-2016, 09:30 AM
DugT's Avatar
Most of the Isoflex on Ebay is promoted for use in snow mobiles. For that application I think it makes more sense. It is very low viscosity and stays low viscosity down to -40C. I know I don't need that as much as I need a lubricant that won't drift onto the belt and the surfaces that interface with the belt. A thicker lubricant would be better for that. I suspect BRP specs Isoflex for their ATV's because it was carried over from their snow mobile roots.
My reason for asking if anyone had tried other lubes is a deadline more than price. I wanted to finish my One Way rebuild yesterday and there was no Isoflex in town. I used "premium red grease" and test drove it briefly yesterday and it exceeded my expectations. If I ever decide to switch to Isoflex it would be fairly easy to clean out the red grease. Before trying Isoflex I would probably use "Super Lube 3 oz. Synthetic Grease with Syncolon PTFE" because it has similar specs and it is easier to get for less than $10.
2010 Renegade 500.
DugT is offline
post #97 of 99 Old 07-16-2016, 11:13 AM
Chief...'s Avatar
I was going to order some of Isoflex grease before, but with the cost and having to wait wait for it to arrive, I decided to check the spec's on the Isoflex Grease and Super Lube Synthetic Grease (which I already had). And after looking at the spec's on them both, the spec’s on the Super Lube exceed the spec’s of the isoflex.
Isoflex — Resistant to water and ambient media
Super Lube — Excellent dielectric, impervious to salt water
Isoflex — Temperature range —60 to 250 deg. F
Super Lube — Temperature range —45 to 450 deg. F
Isoflex — Dropping point 240 C
Super Lube — Dropping point 260 C
(The dropping point of grease is the temperature at which it passes from a semi solid to a liquid)
I have been using this for several years now and it's working fine and it was cheaper and is available locally.
2015 Outlander 1000 6x6 XT
2012 Outlander 1000XT (Sold)
2004 Honda Rincon (Sold)
Chief... is offline
post #98 of 99 Old 07-16-2016, 02:02 PM
DaveB's Avatar
The isoflex used in the BRP sleds is in the center main bearing of some of the motors....so it sees heat. I don't doubt it's good grease, but as mentioned all over this thread, there are lots of alternatives. I've serviced the 1-way with whatever chassis grease was in my grease gun before with no effects. (I ran stock primary clutch on my 07 and serviced the 1-way yearly for 5 years)
Pain or damage don't end the world. Or despair, or f*cking beatings. The world ends when you're dead. Until then, you got more punishment in store. Stand it like a man... and give some back.
2016 Renegade 1000 XMR: "Suck My Wake II"
QSC primary, STM secondary, Yoshimura, Dobeck 3.0,
Get Torqed tuned, Rigid LED, skids, blue plasma rope.
2016 Outlander 570L DPS: "Tank"
BRP snorkel and rad relocate, 27" Outback XTs,
LED, blue plasma rope, Alpine Flex plow.
Past machines:
2012 Renegade 1000 XXC
2008 Outlander 400 EFI
2007 Outlander 800 XT
Lots of older non-BRP junk
DaveB is offline
The Following User Says Thank You to DaveB For This Useful Post:
DugT (07-16-2016)
post #99 of 99 Old 07-27-2016, 05:10 AM
livnreklis's Avatar
I use Lucas extra heavy duty grease (green in color). Been using it on my clutch for 3 years now no issues. I re grease once a year and the grease is always still present each time I pull the clutch.
As long as its a good high heat drop off grease, and you do not go super long intervals between servicing your clutch I don't see a problem.
livnreklis is offline
The Following User Says Thank You to livnreklis For This Useful Post:
DaveB (07-27-2016)
