Suitable substitue for the isoflex grease?
This is a discussion on Suitable substitue for the isoflex grease? within the Can-Am / BRP forums, part of the Can-Am ATV Discussion category; You caught me...
Old 03-22-2008, 10:33 PM
Member #202
View KYRenegade's Photo Gallery(0)
You caught me
Elka Elite, Muzzy Full Ti Pipe, PC3, PRP Stabilizer, Beadlocks, Dalton, Richochet, Uni, H2O Gauge, Fasst Flexx Bars, Cycra Bark Busters, Stealth Snorkle
"Experience is the name we give our mistakes ...and they are our best teachers."
Old 03-23-2008, 01:00 AM
BrianE's Avatar
Member #4041
View BrianE's Photo Gallery(8)
http://kluberna.com/index.asp?p=products#004131
Isoflex Topas NB 52
$26.79 to my door. I would rather stick to the right stuff for that price. 50g should be a life time supply.
Modded 07 Outlander 800X
  #13
Old 03-23-2008, 01:21 AM
Revicm's Avatar
Here's Johnny!
Member #3196
View Revicm's Photo Gallery(3)
I have a hydrallicrock hammer and the recommended grease for it is made by Pennzoil called adhedoflex. It is really sticky and thick would this be along the same lines as Isoflex? Cause I got cases of it.:tg:
  #14
Old 03-23-2008, 03:29 AM
BrianE's Avatar
Member #4041
Revicm wrote:
  #15
Old 03-23-2008, 03:34 AM
Benefactor Gold
Member #396
View MtnOuty's Photo Gallery(0)
revicm, if you could get a sample of the recommended grease, put it on the end of a hot tee rod, your stuff on the other end, put it in your drill,you might get an answer.
I make you the same offer I made to fmj40, you send a container that will make it back thru the mail with your address on it, I'll send you some of the stuff in a baggie to try.
On the 50 gm tube of thekluber isoflextopas nb 52 it says 'special rolling bearing grease', made in Austria, contains N-alkylated benzotriazole (may produce an allergic reaction, wooohoooh!).
Might be just a sweetheart deal with brp since ouratv engines used to be made there,other brp engines are still made there, and your stuff isabout as good. If it sticks to the hot spinning rod, centrifugal force, maybe we could use it instead.
May be all pie in the sky,may be not.
Wear a patch like my avatar to hospital emergency room, clears it out fast.
Vote For Us!!
  #16
Old 03-23-2008, 07:59 AM
Member #240
View Kraker's Photo Gallery(0)
wildcard said.............. " brp recamends anti seize by loctite"
:shrug:
  #17
Old 03-23-2008, 09:15 AM
SPAMINATOR
For those who have not seen the Isoflex, it is literrally like cold cream. If you put some on your hand right next to some Jergens or Pond's cream, you can't tell the difference. It is creamy unlike most greases, some greases have wax in it that has to melt to get the full lubricating benefits. Isoflex is a "cold" grease, starts to work at any temperature, no wax to melt. I used to use Isoflex 20 years ago where I worked.
Also, Isoflex will not seperate, like most greases that are a combination of lubricants.
It works well in some firearms too.
The size below is enough to last a lifetime of "greaseing your shaft" (inside the cvt, that is).:sm:
07-650-MAX
Ricochete ~ Crutchfield 2+1
  #18
Old 03-23-2008, 09:18 AM
SPAMINATOR
PS. if a couple guys got together on a tube of the Isoflex, it would be more affordable and you'd still have a lifetime supply.
07-650-MAX
  #19
Old 03-23-2008, 09:34 AM
Member #2217
View fmj40's Photo Gallery(7)
Isoflex Topas NB 52 is a fully synthetic, long-life, high-speed, spindle bearing lubricant. It is similar to the Isoflex NBU 15 with a different synthetic base oil type and slightly higher viscosity. It is well suited for high speed, medium to high loads, and excellent coolant resistance.
Base Oil Type Synthetic Hydrocarbon
Thickener Type Barium Complex
Service Temperature Range (°C) -50 to 150
NLGI Class 2
Speed Factor, nDm (mm/min) 1,000,000
Guys, since we had pretty much disussed the other regularly used fluids for this rig I figured this discussion was long overdue. As quad said.. this stuff is quite a bit different in texture than regular grease so part of me thinks that we should stick with it. But then it doesn't hurt to discuss amongst ourselves.. I might have to get a tube for myself just to have it in the future. But it doesn't take any more than 1/2 a teaspoon to completely lube the points during a clutch rebuild.. so it'll last a while.
PRP Steering Stabilizer
  #20
Old 03-23-2008, 12:43 PM
Member #3979
View snw629's Photo Gallery(0)
i think can-am uses isoflex for the long lasting of it. they think most will never lube this bearing. i talked to the lead tech at my dealer and he thinks the same. for the guy who lubes his say once a year as i just did i think high temp disc brake grease that is good to about 500 degree is okay. these parts will not see temps that high. lazer temp a hot brake rotor some time. my:2cent:
09 POLARIS 850 XP EPS
28" ZILLAS FOR MUD ON STOCK WHEELS.
26" BIGHORNS ON SS212 FOR TRAILS.
WARN RT30 WINCH WITH KFI MOUNT.
POLARIS REAR RACK EXT. SPIDER A3 GRIPS.
HMF SWAMP XL. DALTON CLUTCH KIT.
2009 RZR 27" ZILLAS,FMF.
