05-08-2009, 06:05 AM
More info on grease HERE. :2cent:
07-650-MAX
Ricochete ~ Crutchfield 2+1
05-08-2009, 06:10 AM
usctrack IF you odered from us I didn't get it. :shrug:
07-650-MAX
05-08-2009, 07:30 AM
Member #4496
Quad, I seem to be a little impatient and did not read the whole thread before ordering. About 10 mins after i ordered from Kluner I ran across the reponse to order from you guys! Sorry about that! I will make it up! I am on a handful of forum and you guys rock!!
[COLOR="Red"]2008 Can-Am Outlander 800 Max XT[/COLOR], Full Ricochet Skid plates, 14" SS112 rims with 27" Swamp Lites(in garage), East Coast ATV Snorkels, PCIII & HMF Exhaust w/ Snorkel, K&N air filter, 2" Highlifter lift and Pipe lift, 12" SS212\'s with 29.5 Outlaws!, Temp Guage installed, a couple extra lights to light up the trail
05-08-2009, 07:38 AM
No problem, just wanted to make sure I wasn't missing an order. I ship ASAP when I get one.
07-650-MAX
05-08-2009, 10:10 PM
Member #2236
Hey Quad... how much is a little amount you are selling. I am doing the new bearings for my gade and a friends 650 outlander. Is one batch enough for both clutches???? And do you need anything extra for shipping up to me in Alaska?
Never mind the quantity question... I read the stickied thread and see it has enough for 4 tries. Just want to make sure you don't want anything extra to ship to me.
\'07 Renegade 800:Ricochet skids, Acerbis hand guards, polaris hand and thumb warmers, Proline 907 grips, K&N air filter, ITP wheels, 27" Outlaw MST tires, Aaen slip-on, "stealth" snorkels, Dalton clutch kit...
\'05 Scrambler 500
02-08-2010, 08:17 PM
Member #9034
Mobil SCH 220
Lubriplate SYN LUBE HD220
both are class 7 bearing greases
02-09-2010, 03:50 AM
Member #240
I finally broke down and got isoflex a while ago. It was the "long lasting" thing that got me, not the "unmatchable" lubing properties. But i've since seen in the BRP website parts diagram (2006 outty) where they recommended "LOCTITE 767 Antiseize lubricant" for the one way, and isoflex for the friction washer, both on the same diagram. I used another version of antiseize and it dried up after about 400 hours BUT that was way longer than the recommended 100 hours service interval
http://www.rshughes.com/products/079340_76759.html
05-26-2010, 02:17 AM
Member #7322
Since the topic was "suitable substitue for for isoflex" I thought I would ask opinions on Gunk Brake Caliper Grease. I happen to have a tube (as most of us probably do) in my tool box... I did a google on it and came across the following info:
FUNCTION AND APPLICATION: Solder Seal/Gunk® Squeal Medic™ Caliper Grease is a molybdenum disulfide fortified synthetic lubricant formulated to lubricate under the most adverse conditions. It is excellent for lubrication in high temperature applications where other greases fail.
OUTSTANDING PROPERTIES: Squeal Medic™ Caliper Grease has excellent corrosion resistance, a wide temperature range, and excellent extreme pressure protection. Squeal Medic™ Caliper Grease is non-melting and is water-resistant. It is excellent on all bearings and sliding surfaces in conditions above 500°F and is compatible with most rubber and plastic hardware including ethylene propylene rubber.
Sounds like a possible good substitue... any opinions.. besides the normal "why chance it... only use isoflex".
05-26-2010, 02:33 AM
most bearing grease is very thick. isoflex is a very thin and light weight grease you will wonder if its even grease at all and maybe you grabbed a miss labled tube of neosporin. the forum here sells it in smaller quanity .... Id stick with the isoflex
05-30-2010, 04:24 PM
Member #8848
What is the big cry and drama about this darn grease?
Guys buy 10k bikes and the complain about the cost of grease
I got Isoflex 50g tube at 25 bucks plus shipping, ended up just under 30 bucks.
| Visitors found this page by searching for these keywords: |
isoflex grease, isoflex grease 50g, isoflex
