New Can-Am Commander Specs and Demensions
This is a discussion on New Can-Am Commander Specs and Demensions within the Can-Am Commander forums, part of the Can-Am ATV Discussion category; COMMANDER™ 1000 COMMANDER 1000 SPECIFICATIONS ENGINE Type: 976cc, V-twin, liquid-cooled, SOHC, 8-valve (4-valve/cyl) Bore & Stroke: 91 x 75 mm Fuel System: iTC™ with EFI ...
Go Back   Can-Am ATV Forum > Can-Am ATV Discussion > Can-Am Commander
Old 06-10-2010, 08:24 PM
OSOKILL's Avatar
Default New Can-Am Commander Specs and Demensions
COMMANDER™ 1000
ENGINE
Fuel System: iTC™ with EFI and 54mm Throttle Body, 2 Siemens VDO injectors
Starting System: Electric
Transmissi on: CVT, sub-transmission with high, low, park, neutral & reverse. Standard engine braking
Drive Train: Selectable 2WD/4WD shaft drivenwith Visco-Lok† front differential
CHASSIS
Frame: Steel
Cage type: 2-inch diameter, high-strength steel, ROPS-approved
Steering wheel adjustment: Adjustable tilt steering
Front Suspension Type/Shocks: Double A-arm with dive-control geometry / Motion Control shocks
Front Suspension Travel: 10 in (254 mm)
Rear Suspension Type Shocks: Torsional Trailing arm Independent (TTI) with external sway bar/ Motion Control shocks
Rear Suspension Travel: 10 in (254 mm)
Front Brake: Dual 214 mm ventilated disc brakes with hydraulic twin-piston calipers
Rear Brake: Single 214 mm ventilated disc brake with hydraulic twin-piston caliper
Tires/Front: Carlisle Black Rock 27 x 9 x 12 in - 686 x 229 x 305 mm
Tires/Rear: Carlisle Black Rock 27 x 9 x 12 in - 686 x 229 x 305 mm
Wheels: Steel
DIMENSIONS
L x W x H (in): 118.3 x 58.6 x 72 in
L x W x H (mm): 3,004 x 1,489 x 1,829 mm
Wheelbase: 75.8 in (1,925 mm)
Ground Clearance: 11 in (279 mm)
Dry Weight: 1,295 lbs (587 kg)
Towing Capacity: 1,500 lbs (680 kg)
Cargo Box Capacity: Total: 600 lbs (272 kg) - Upper: 400 lbs (181 kg) - Lower: 200 lbs (91 kg)
Cockpit Storage: Glove box: 4.5 gal (17.2L) - Under driver seat: 3.5 gal (13.1L)
Fuel Capacity: 10 US gal (37.8L)
FEATURES
Instrumentation: Multi-function gauge: Speedometer, tachometer, odometer, trip and hour meters, fuel, gear position, sport mode, seat belt and 4x4 indicator, diagnostics, clock, auto shut off
Anti-theft System: D.E.S.S. (Digital Encoded Security System)
Electrical: Prewired for winch
Lighting: 4 60-watt projectors with tail lights/ brake light
DC Outlet: Lighter type in console, standard connector in the back (15A)
Color Available: Yellow
WARRANTY
Basic: 6 months limited factory warranty
Extended: B.E.S.T. available from 6 to 18 months
X™ PACKAGE
• Front and rear Fox Racing Shox! HPG piggyback shocks with dual speed compression, rebound and preload adjustments
• Front sway bar
• 12-inch aluminum beadlock wheels
• Maxxis Bighorn! 2.0 tires
• Rock sliders
• Heavy-duty front bumper
• Analog/digital gauge
• Custom steering wheel with brushed aluminum center part
• X-package seat trim and graphics
• Color: Black & Yellow
XT™ PACKAGE
• BRP XL 4000 winch with roller fairlead, wired remote control and integrated winch remote storage
• 14-inch cast-aluminum wheels
• Maxxis Bighorn 2.0 tires
• Rugged bed rails
• Mudguards
• Analog / digital gauge
• Colors: Red & Yellow
www.commanderforums.org
www.atvblog.net
Click??
Old 04-26-2011, 06:44 AM
First Name: I love the woods and lake so after spending the week selling seafood all over the country I go out
Member #15858
View fishmonger ed's Photo Gallery(0)
6 month warranty sucks when you pay18,000.00 for the dam thing but I did get a LOT of stuff with it. I have most of the add on stuff from the book along with the plow and they gave me 25% off of the add on parts.doese that sound like the right price?
Old 04-26-2011, 07:15 AM
st222's Avatar
Member #7470
View st222's Photo Gallery(0)
dont no, but i have most the addons to. just take it with a grain of salt
2012 rzr xp 900 (orange madness) polaris pre-runner frt bumper, rigid d2 led, L&R sport roof, L&R 1/2 windsheild, L&R rear cargo box, rear cage extender, headach net, soft top, heated riding gear on t-stats, music
2012 outlander 1000xt (yellow) x-beadlock wheels, 26" bighorn 2.0, heated riding gear on t-stats, brp heated hand and thumb warmers, music
Old 06-15-2011, 04:39 PM
Member #16783
View sledford's Photo Gallery(0)
got a commander 1000 x and has left than 15 hrs on it and the transmission gearbox went out. Been in the shop waiting for a part for 3 weeks now, they're telling me at least 2 more weeks. Anyone else out there having this problem?
Old 06-15-2011, 04:48 PM
Member #16783
Default 2011 commander 1000 x transmission gearbox out?
Old 12-18-2011, 02:37 PM
xt1000's Avatar
Member #19804
View xt1000's Photo Gallery(11)
got a 2011 commander 1000xt and its 7 months old now, and has 2450klm on it , no problems what so ever, just a loose latch on the top tail gate thats it. very impress so far, and i had 2 outlanders 1 renegade, and going to this thing took a little getting use to but very fun,i have a set of mudlites 30x10x12-30x12x12 on it no problems, all stock still,fo now, made boat rack,rear stern for 2 horse, can am plow frame home made, i just love this thing...check out my pics in my galery, enjoy
2011 can am commander specs
2012 can am commander 1000 xt specs
2012 can am commander dimensions
2012 can am commander specs
can am comander specs
can am commander 1000 specs
can am commander bed dimensions
can am commander specifications
can am commander wheel base
can-am commander specs
canam commander specs
commander specs
specs on can am commander
Frame mod specs rene500ds90 Can-Am Renegade 3 06-25-2009 01:08 PM
Torque specs? normal_deviation Can-Am / BRP 6 04-22-2009 07:03 PM
Torque specs. lope Can-Am / BRP 14 01-17-2009 04:22 PM
Clutch specs Atver Can-Am / BRP 4 12-28-2008 06:22 PM
Can Am specs. ATV Rock climber This Just Pisses Me Off 7 12-19-2006 05:01 PM
