2014 Can-Am Commander 800R Family - Can-Am ATV Forum
This is a discussion on 2014 Can-Am Commander 800R Family within the Can-Am Commander forums, part of the Can-Am ATV Discussion category;  2014 CAN-AM COMMANDER 800R FAMILY Incorporating valuable feedback from Can-Am customers, the Commander 800R family of side-by-side vehicles feature a few updates for the ...
Go Back   Can-Am ATV Forum > Can-Am ATV Discussion > Can-Am Commander
Old 06-03-2013, 10:53 AM
4Nines's Avatar
Member #6930
View 4Nines's Photo Gallery(30)
Incorporating valuable feedback from Can-Am customers, the Commander 800R family of side-by-side vehicles feature a few updates for the 2014 model year. On DPS and XT models, the Commander 800R receives the new Tri-Mode Dynamic Power Steering, ECO mode, improved heat resistance in the cockpit area, a new rear differential and updated 3-D digital
gauge package (XT). Each Commander 800 also meets current EPA / CARB and ROHVA compliancy.
COMMANDER 800R FAMILY HIGHLIGHTS
PERFORMANCE
  • Rotax 800 EFI V-Twin engine
  • EPA / CARB compliant design
  • Intelligent Throttle Control (iTCTM)
  • New ECO mode
  • CVT transmission
HANDLING
  • Double A-arm front suspension with dive-control geometry
  • TTI rear suspension
  • 11-inch (27.9 cm) ground clearance
  • Visco-Lok front differential
  • 214mm disc brakes with twin-piston calipers
  • 27-inch (68.6cm) Carlisle Black Rock radial tires
  • 12-inch (30.5cm) painted steel wheels
DRIVER-FOCUSED DESIGN
  • Reduced heat in cockpit
  • Dual-levelTM cargo box
  • 1,928 cubic inches (31.6 liters) cockpit storage
  • 1,500 lbs towing capacity
  • 2-inch rear hitch receiver
  • Comfort seats with sit-in fore / aft driver adjustment
  • Removable, freestanding seats
  • Adjustable-tilt steering
  • Passenger handhold and grab bar
  • Dual, off-road cup holders
  • 240-watt lighting
  • 10-gallon (38 litres) fuel tank
  • 625-watt magneto
  • Easy-to-use maintenance center
  • 2-inch diameter, high-strength steel, ROPS-approved cage
  • Quick-attach side nets
  • 3-point seatbelts with anti-cinch
  • Standard & Performance D.E.S.S. Keys
  • Red plastic (base model)
CAN-AM COMMANDER 800R DPS INCLUDES:
  • Tri-Mode Dynamic Power Steering
  • Visco-Lok QE
  • 27-inch (68.6cm) Maxxis Bighorn 2.0 tires
  • 14-inch (35cm) cast aluminum wheels
  • Yellow plastic
CAN-AM COMMANDER 800R XT PACKAGE INCLUDES:
  • Updated 3-D analog / digital gauge package
  • Tri-Mode DPS
  • Visco-Lok QE
  • 4,000-pound winch
  • 14-inch (35cm) cast-aluminum wheels
  • Heavy-duty front bumper
  • Rugged bed rails
  • Mud guards
  • Custom steering wheel
  • Available in yellow, Pure Magnesium and an optional industry-exclusive NEXT G-1 Vista camouflage.
CAN-AM COMMANDER 800R FAMILY FEATURES AND BENEFITS
PERFORMANCE
ROTAX 800 V-TWIN ENGINE
The liquid-cooled, single overhead cam powerplant is powerful and efficient. It has four valves per cylinder and is fed by a 54mm throttle body and two VDO Siemens fuel injectors. The sophisticated electronic fuel injection system automatically keeps the engine’s performance at its peak, regardless of temperature or altitude. The progressive throttle ensures power is manageable whether in precise rock crawling or opening it up on the straights.
EPA / CARB COMPLIANT DESIGN
Located within the side-by-side vehicle’s muffler, a new catalyst and lambda sensor is EPA and CARB compliant.
INTELLIGENT THROTTLE CONTROL (ITC)
The throttle-by-wire system teams with the 54mm Bosch throttle body to produce smooth throttle delivery even if the driver’s foot is bouncing due to the terrain. The iTC system can detect unwanted bounces and then filter the input, resulting in more throttle accuracy, especially at low speed. This system also reduces the number of moving parts in the vehicle; requires no maintenance; has no cables to adjust, lubricate, or replace; and the system has an increased life span.
ECO MODE
The Commander side-by-side offers selectable Sport mode, which offers a more linear throttle control for performance driv- ing, and the new ECO mode for driving under normal use situations.
CVT TRANSMISSION
Continuously Variable Transmission featuring high, low, park, neutral & reverse. Standard engine braking.
HANDLING
NEW REAR DIFFERENTIAL
A new spiral bevel gear rear differential was added to the Commander side-by-side to reduce noise.
DOUBLE A-ARM FRONT SUSPENSION WITH DIVE-CONTROL GEOMETRY
The Double A-arm suspension uses front dive-control geometry, which works to eliminate diving under heavy braking and rough terrain. By controlling vehicle dive, the Can-Am Commander handling is more precise in all situations and terrain types. The front end, which features 10 inches of travel (25cm), has the largest diameter front, five-way preload-adjustable gas shocks in the industry (36mm or 1.4 inches) for overall durability and better fade resistance.
TRAILING TORSIONAL INDEPENDENT (TTI) REAR SUSPENSION
Inspired from the world of top-level, off-road trophy trucks, this trailing arm design provides excellent control and stability, especially in rough terrain by eliminating scrub. Wheels move rearward as they move up and down producing a smoother ride than the competition, and the side-by-side does not waver down the trail. TTI reduces tire wear and has 75 percent fewer parts than competitive designs. The durable rear end features 10 inches of travel (25 cm) and the largest diameter rear, five-way preload-adjustable gas shocks in the industry for reduced fading.
11-INCH (27.9CM) GROUND CLEARANCE
Offers a whopping 11 inches (27.9 cm) of total ground clearance for maximum performance for conquering challenging ter- rain. We built sag right in to the suspension, which lets the system work in its travel “sweet spot.”
VISCO-LOK FRONT DIFFERENTIAL
Progressively and automatically transfers power from a slipping front wheel to the one with traction. Visco-Lok has no but- tons to push or levers to pull. Plus, there’s no wheel hop or driveline wind-up so the system is totally transparent to the driver and extremely easy to steer. Up to 100 percent lock up with no rev or speed limiter.
214MM DISC BRAKES WITH TWIN-PISTON CALIPERS
Front and rear outboard disc brakes with 214mm discs and twin-piston calipers.
27-INCH (68.6CM) CARLISLE BLACK ROCK RADIAL TIRES
Purpose-built, six-ply Carlisle Black Rock radial tires provide a versatile tread pattern and proven durability.
12-INCH (30.5CM) PAINTED STEEL WHEELS
The base model wears 12-inch carbon-colored, painted steel wheels.
RIDER-FOCUSED DESIGN
REDUCED COCKPIT HEAT
Can-Am engineers added more heat shield foil to four areas of the Commander to reduce the amount of heat reaching the cockpit.
DUAL-LEVEL CARGO BOX
The Commander 800R features the industry’s first cargo box with two levels separated by a removable, watertight panel. It offers the possibility to have an upper and a lower bed with and independent tailgate. Carrying capacity of the box is 600 lbs. total capacity. (400 lbs. upper, 200 lbs. lower) and has the most volume capacity in the market. The tilt-assist dump- box can be easily activated from both sides. The heavy-duty, high-strength cargo box is resistant to rust and dents. Easily removable tail gates (upper and lower), no-tools needed with single latch, truck-like, upper and lower tail gate with four tie down hooks located in corners. Integrated vertical grooves for plywood dividers and the Can-Am An optional trunk lock is available to secure the lower level.
1,928 CUBIC INCHES (31.6 LITERS) COCKPIT STORAGE
The Can-Am Commander 800R family features the same cockpit storage as the larger Commander 1000 models. That means it also leads the industry with almost 2,000 cubic inches of storage in three separate compartments. There are more than 1,050 cubic inches of storage in the glove box and another 799 cubic inches of storage under the fully adjustable driver’s seat. And, in the center console, there’s another 79 cubic inches if space that can be accessed by either occupant. .
1,500 LBS (680KG) TOWING CAPACITY
An impressive 1,500 lbs. of towing capacity lets the Commander 800R family tow heavy loads.
2-INCH REAR HITCH RECEIVER
A standard two-inch hitch receiver allows a standard vehicle towing bar and ball to be used with the Commander 800R family.
COMFORT SEATS WITH SIT-IN FORE / AFT DRIVER ADJUSTMENT
Our full bolster seats offer unmatched comfort levels and refine the side-by-side experience with lumbar and shoulder sup- port. Both seats are designed to allow easy entry and exit of the machine. Adjustable fore and aft without the need of tools, the automotive-like driver’s seat offers 6.3 inches (16 cm) of total adjustment.
REMOVABLE, FREESTANDING SEATS
Freestanding, removable seats mean you’ll enjoy remain comfortable whether it’s inside the cab or sitting in our seats around the campfire at the end of a long day.
ADJUSTABLE TILT STEERING
The steering wheel adjusts (a total range of 30.5 degrees) without the need of tools. Can-Am engineers and designers de- signed the gauge to pivot with the steering wheel for enhanced visibility.
PASSENGER HANDHOLD AND GRAB BAR
The Commander line of side-by-side machines feature two passenger handhold locations for supreme comfort and convenience. Located immediately in front of the passenger, the grab bar is designed with ergonomic bends for mul- tiple and comfortable hand positions. The additional left-hand grip bar on the center console provides the passenger and additional handhold.
DUAL, OFF-ROAD CUP HOLDERS
Twin cup holders, located in the center console, have rubber flaps for off-road use.
240-WATT LIGHTING SYSTEM
The Can-Am Commander 800R family of side-by-side vehicles features the industry’s best lighting system at 240 watts. Automotive-style projectors, on each side, run at 120 watts in low beam and 240 watts in high-beam mode.
10-GALLON (38 LITERS) FUEL TANK
The largest fuel tank (10 gallons; 38 liters) in the side-by-side industry provides maximum range out on the trail and at the work site. That’s also 11 percent more capacity than the nearest competitor.
625-WATT MAGNETO
The Commander 800R electrical system can dedicate up to 300 free watts to power accessories thanks to the industry’s largest magneto.
EASY-TO-USE MAINTENANCE CENTER
Easily accessible and out of the elements under the hood, a centralized maintenance area allows access to the air box, radiator and coolant overflow. Fuses and relays are also easily accessible.
2-INCH DIAMETER, HIGH STRENGTH STEEL, ROPS AND ROHVA-APPROVED CAGE
Our engineers used the Roll-over Protective Structures (ROPS) industry standard when designing the Can-Am Commander family of side-by-side’s two-inch-diameter, high-strength steel cage. The 2014 Commander side-by-side is also compli- ant with the Recreational Off-Highway Vehicle Association (ROHVA) standards with side nets, side shoulder bars and cage modifications.
QUICK-ATTACH SIDE NETS
Easy to open and close using one-hand, one-click, the side nets are standard on both side of the Commander 800R. Specifi- cally designed to keep a clear field of vision for driver and passenger.
THREE-POINT SEATBELTS WITH ANTI-CINCH
Occupants have peace of mind and comfort with the Commander side-by-side’s three-point seatbelt with anti-cinch a warn- ing alert if the driver’s belt is not fastened properly.
STANDARD & PERFORMANCE D.E.S.S. KEYS
D.E.S.S. is the industry’s first standard anti-theft device. Electronic code in key must match code in ECU to start. The Com- mander 1000 family comes with two different keys. One is standard key, which limits top speed to 43.5 mph (70 km/h). The second key is the performance key that has no limitation on speed or power.
BASE COLOR OPTION
The Commander 800R base color is red for 2014.
COMMANDER 800R WITH DPS PACKAGE
The Commander 800R DPS features power steering and BRP’s exclusive Visco-Lok QE front differential. This model will be available in Can-Am yellow and also wear 14-inch tires and wheels.
TRI-MODE DYNAMIC POWER STEERING (DPS)
Calibrated specifically for use in the Commander line of side-by-side vehicles, BRP’s Tri-Mode DPS system offers variable steering assistance and is designed to offer less assist at high speed and more assist at low speed. It also allows the driver to dial in his or her preference with three modes (Hi, Med, Lo).
VISCO-LOK QE
All DPS-equipped models come with the Visco-Lok QE calibration giving an even quicker engagement of the front differential. It progressively transfers power from a slipping front wheel to the gripping one – automatically with no buttons to push or levers to pull. Plus, there’s no wheel hop or driveline wind-up so the system is totally transparent to the driver and extremely easy to steer. Can lock up to 100 percent with no rev or speed limiter. This differential, unlike some competitor’s differentials, does not have a speed or rev limiter. DPS and Visco-Lok QE, when, combined, improve handling and performance in slow- speed technical terrain
27-INCH (68.6CM) MAXXIS BIGHORN 2.0 TIRES
Maxxis Bighorn 2.0 tires feature a rugged six-ply radial construction, yet are lightweight to cut down on unsprung weight. The non-directional tires absorb the terrain for a smooth ride and provide predictable cornering. They’re also very capable climbing and clawing across roots, rocks and other tough terrain.
14-INCH (35CM) CAST-ALUMINUM WHEELS
Strong-yet-lightweight and fashionable larger 14-inch, cast-aluminum wheels give the Commander 800R with DPS a unique look over stock.
COLOR OPTION
The Commander DPS wears yellow plastic.
The Can-Am Commander 800R XT features factory-installed parts that enhance both its look and functionality over stock. For 2014, the XT package also includes an updated analog / digital gauge package and new Tri-Mode Dynamic Power Steering.
UPDATED 3-D ANALOG / DIGITAL GAUGE PACKAGE
TThe updated 3-D analog / digital gauge package has been upgraded over the base model to include state-of-the-art instrumentation and more visual clarity. This includes an analog tachometer and speedometer combined with an advanced digital information center.
Calibrated specifically for use in the Commander line of side-by-side vehicles, BRP’s Tri-Mode DPS system offers variable steering assistance and is designed to offer less assist at high speed and more assist at low speed. It also allows the driver to dial in his or her preference with three modes (Hi, Med, Lo),
VISCO-LOK QE
All DPS-equipped models come with the Visco-Lok QE calibration giving an even quicker engagement of the front differ- ential. It progressively transfers power from a slipping front wheel to the gripping one – automatically with no buttons to push or levers to pull. Plus, there’s no wheel hop or driveline wind-up so the system is totally transparent to the driver and extremely easy to steer. Can lock up to 100 percent with no rev or speed limiter. This differential, unlike some competitor’s differentials, does not have a speed or rev limiter. DPS and Visco-Lok QE, when, combined, improve handling and perfor- mance in slow-speed technical terrain.
4,000-POUND (1,814KG) WINCH
A 4,000-pound WARN winch kit includes a roller fairlead, wired remote control and integrated remote storage. The winch is designed to compliment the Commander 800R XT and handle heavy-duty loads when at the work site and on the trail.
14-INCH (35CM) CAST ALUMINUM WHEELS
Attractive, sturdy and lightweight, 14-inch, XT-specific cast-aluminum wheels give the Commander 800R XT its own look. The camouflage model’s cast aluminum wheels feature a unique painted black finish.
HEAVY-DUTY FRONT BUMPER
The Can-Am Commander 800R XT features a front bumper that is installed at the factory and is completely covered by the factory warranty. The added protection gives peace of mind in rugged conditions.
RUGGED BED RAILS
Bed rails installed on the Dual-Level cargo box give the XT a rugged look and add more tie-down points for cargo carrying.
MUDGUARDS
Mudguards run on the wheel wells to complete the premium look of the Can-Am Commander 800R XT and give the driver and passenger further protection from the mud.
CUSTOM STEERING WHEEL
A premium custom steering wheel is standard on the Commander 800R XT.
XT COLOR OPTIONS
All XT models come in yellow, painted Pure Magnesium, or industry-exclusive NEXT G-1 Vista camouflage.
2014 can am 800 r side by side
2014 can am commander
2014 can am commander 800
2014 can am commander 800 reviews
2014 can am commander 800 xt reviews
2014 can am commander 800r reviews
2014 can am commander review
2014 can am commander reviews
2014 commander can am
can am 800 commander review
can am commander 800r top speed
can-am commander 800 reviews
can-am commander 800r top speed
2014 Can-Am Commander 1000 Family 4Nines Can-Am ATV & Forum News 1 06-28-2013 11:59 PM
2014 Can-Am Maverick MAX Family 4Nines Can-Am ATV & Forum News 0 06-03-2013 10:12 AM
2011 Renegade 800R Family OSOKILL Can-Am 2011 Models 14 12-13-2011 07:54 PM
2012 Can-am Commander 800 Family dascrow Can-Am ATV & Forum News 1 07-11-2011 11:22 AM
2012 Can-Am Commander 1000 Family dascrow Can-Am ATV & Forum News 1 07-11-2011 11:10 AM
» Sponsored Links
