DS650 pumping out oil - Can-Am ATV Forum
This is a discussion on DS650 pumping out oil within the Can-Am DS forums, part of the Can-Am ATV Discussion category; My 650 is pumping out oil from the hose that runs from the crankcase to the airbox intake tube. Even while cranking over, it moves ...
Go Back   Can-Am ATV Forum > Can-Am ATV Discussion > Can-Am DS
Old 04-05-2010, 03:23 PM
Member #9760
View Javelin_SST's Photo Gallery(0)
My 650 is pumping out oil from the hose that runs from the crankcase to the airbox intake tube. Even while cranking over, it moves oil. The oil is then running out and down all over my engine. What I'm suspecting is that the hose
from the oil resevoir is slightly kinked and *possilby pressurizing the case and pushing the oil out. Anyone ever heard of anything like this or ideas to what might be causing it? It's in the shop now but I'm about to go get it because they've had it for two weeks and hadn't even looked at it.
Old 04-07-2010, 09:25 AM
Member #2258
View THEBOM's Photo Gallery(0)
It could be a few things, like a broken piston, over fill oil tank, oil return pump not sucking and pushing the crank case oil back to the tank.
I've had the ring break and do this.
THEBOM Racing
How fast do you want to go?? Just ask!!!!!
Old 04-07-2010, 10:51 AM
Member #5109
View joseph9936's Photo Gallery(0)
you could have bought the "James Bond" addition, if that is the case run the line right above your muffler. That will activate the "Smoke Screen" option. The good thing it will ONLY affect the non Canam people because all the others will be behind you.
my humer just kills me!
Old 07-05-2010, 11:26 PM
Member #10886
View tnhotrod's Photo Gallery(0)
Did you ever find out why it was blowing oil back up home into airbox?? Just got one with the same problem..
Old 08-02-2010, 08:53 PM
Member #11235
View ds720rider1's Photo Gallery(0)
you chewed a ring just had same problem get it fixed now!!!
Old 10-09-2010, 12:08 PM
Member #9760
I know this post is old, but I finially got able to tear into it. The piston and rings are fine, actually, hardly any wear. The inside of the cases look great as well. So I'm still at a loss: it's not over filled with oil and there's no blow-by.
I'm replacing the rings and timing chain anyways since I have her apart. Any other stuff I need to check before bolting her back up?
Old 10-09-2010, 08:57 PM
akguppy's Avatar
Member #11603
View akguppy's Photo Gallery(0)
Dude, how have you survived for 6-months w/o riding your quad? Hope you get it fixed soon.
Old 10-11-2010, 01:01 AM
Member #9760
If it wasn't for my raptor, I probably would have gone insane. I do like reverse and fuel injection, but I'm so ready to get the Bomb back together.
Old 10-15-2010, 10:32 AM
schambo's Avatar
Member #9166
View schambo's Photo Gallery(4)
I think that's part of the reason most of us have more than one bike. My DS was out of commission for a few weeks after I rolled it and if it weren't for my KX I would have gone nuts. Hope you get it fixed soon.
Old 12-16-2010, 03:51 PM
Member #12771
View NICK2's Photo Gallery(1)
Did you ever find out why your ds is blowing oil? I pulled mine apart cause oil is dripping on the top of my motor. After further looking it's coming out of a oil line from the right side of the motor by the brake peddle. Looks like a over flow line. Let me know. Thanks
01 ds650 blowing oil out of breather
04 bombardier ds650 engine breather
2000 can am ds 650 blowing oil out the breather
blowing oil from crankcase vent on my bombardier baja
bombadier 650 hose on top of engine
bombardier 650 atv oil pump inlet/outlet hose
bombardier 650 oil pipes
can am ds650 air box
ds 650 crank case vent
milky oil coming from crankcase breather line on bombardier ds 650
my 2004 bombardier ds650 motor keeps blowing oil out of breather side
oil blow by on ds650
oil coming up vent hose on ds650
raptor 650 blowing oil out bottom end hose
what makes oil come out of the crankcase breather tube on a bombardier ds 650
DS650 End Cap for exhaust basicbajax Can-Am DS 3 02-21-2012 11:32 PM
New, with a DS650 Javelin_SST Please Introduce Yourself 9 04-09-2010 08:02 PM
DS650 or 700 Raptor jsilver919 Can-Am DS 24 02-16-2010 12:54 PM
DS650 jumper mike20grandi Can-Am DS 6 11-29-2009 01:22 PM
DS650 X Decals El Tinaco Can-Am DS 2 06-04-2009 10:47 AM
