Ds 650 rpair manual - Can-Am ATV Forum
post #1 of 12 Old 07-18-2010, 02:23 PM Thread Starter
Ds 650 rpair manual
Hello,
New to the forum and to the Ds world. Do any of you know where to find a manual for a 2000 Ds 650 in cd form? Damn dogs destroyed mine
Thanks,
Mark
ohiods650 is offline
post #2 of 12 Old 07-18-2010, 03:59 PM
OSOKILL's Avatar
welcome aboard .... Im sure one of the many DS owners will pass on where you can get one very soon =]]]
www.commanderforums.org
www.atvblog.net
OSOKILL is offline
post #3 of 12 Old 07-18-2010, 05:55 PM Thread Starter
Thanks... How hard is it to adjust the valves?
Thanks,
Mark
post #4 of 12 Old 07-23-2010, 06:17 PM
you should have a manual for reference . but first find tdc. under your clutch cover there is a m8 bolt remove it find a longer bolt grind it to a rounded point (bullet shape) pull the valve cover off, also one plug. make sure the timing marks on the cam gears are lined up. (pointing at each other). if you need to rotate the motor pull the plastic plug out of the stator cover, insert a allen wrench and rotate the motor to align the marks. once they are aligned, screw in your longer screw you made, it will lock into a hole in the crank. then slide a feelers gauge in between the cam and the valve cap. i beleave it should be between 4-8 thousands. i like to run mine at 5-6.
measure what you got. if its off pull the cams and pull the shim(a magnet works well)
under the shim should be a size, figure what you need to end up at 5-6 thousands clearance. if your not comfortable with that just mark on the cap what size space you have. with a sharpy, and take it to the shop. they should be able to do the math and hook you up. also mark which one went where. btw to remove the cams you have to remove the chain tensioner on the cylinder. but to answer your question its harder than a single overhead cam design. but if you have worked on motors ,its not that bad , but as i said you will need a manual. hope this helps
brian68 is offline
post #5 of 12 Old 04-26-2011, 12:02 PM
Hey all! I am new on here too!! and I am also hoping to find a manual for the ds 650. I bought it quad last summer and am doing some maintenance and replacing parts on it before atv season starts. I took off the facia and gas tank cover. On the top of the gas tank there is a little tube. It isn't connected to anything so I'm not sure what it's for. Does anyone know?
Marilyn
ds650racer is offline
post #6 of 12 Old 04-26-2011, 02:34 PM
schambo's Avatar
That is the fuel tank vent line. Instead of it coming out of your cap they decided to hide it. Repair Pro has a good manual on CD in pdf format for around $15. They used to sell them on ebay.
schambo is offline
The Following User Says Thank You to schambo For This Useful Post:
ds650racer (04-27-2011)
post #7 of 12 Old 04-27-2011, 06:44 PM
thanks schambo. there is a really long tube coming out of it. What should I do with it? Just leave it? or is it supposed to attach to something?
Marilyn
post #8 of 12 Old 04-28-2011, 07:34 AM
schambo's Avatar
Marilyn
Just leave it. The tank needs it to vent.
schambo is offline
post #9 of 12 Old 04-28-2011, 10:22 AM
I have the 2003 "dealer only" version on CD. Covers all models. I can make a copy $15 shipped.
justme23005 is offline
post #10 of 12 Old 08-01-2011, 02:21 PM
ebay has them for 10 bucks shipped to your door in cd form so you can add it to your desktop and as far as the guy who has the fuel tank hose thing you can plug it but make shure you add a different cap onto your tank that would be able to create air flow like a billet cap or what not I herd you can use a outlaw cap with a air plug on top and it will fit same threads and everything that way there you can add more gass without it leaking lol well happy huntin
650conqueror is offline
Go Back   Can-Am ATV Forum > Can-Am ATV Discussion > Can-Am DS
repair manual travis87 Can-Am / BRP 4 07-29-2011 01:58 PM
850 XP Service Manual HIGHOCTANE Polaris 1 04-21-2009 06:52 PM
shop manual lunatic Can-Am / BRP 4 04-14-2009 12:40 PM
Service Manual? mm58 Can-Am / BRP 2 12-26-2006 09:34 PM
Got the tools and the manual.... Offcamber Can-Am / BRP 1 10-20-2006 01:51 PM
