11-07-2009, 02:19 PM
Member #7491
there is a puller tool you can get from the dealership. I have seen some tools someone had made with a solid push rod and a bolt.
'09 Renegade X 800R
Mud Industries Snorkels
Engine Ice
Comet Clutch
Twin-Air
Full Muzzy
PC V (Custom Tuned by John Cannon)
14" SS212s
30" Silverbacks
Warn RT30
2" RD Lift
( more mods soon!)
'06 Grizzly 660
Dynatech CDI
Dyno-jet
Penland Pro Series
UNI Filter
Engine Ice
Pro Taper Bars
14" SS108s
28" Zillas
Custom Graphx
11-07-2009, 02:34 PM
First Name: Kjartan Gušmundur.
Member #6126
Quote: Originally Posted by f419sr1
I need to pull the motor and I have the secondary off and the primary outer off Im not sure on how to get the inner off. I dont want to hurt any thing.
PT# 529035746 CLUTCH PULLER
It is the gold colored one
Ice Can-Am
Can-Am Outlander Max Xt 2008 - Mayerosch 15" wheels with 215/75/15 Road Tires - BRP Windshield - BRP Box - Trailer Connector Mod - Reverse Light Mod.
11-07-2009, 02:36 PM
get an M14x1.5 bolt, 80 mm long, with 35 mm of threads, and a 10 mm rod, 90 mm long. drop the rod in the hole, tighten the bolt.
or you can tip the bike on its right side a bit, take an M14x1.5 bolt and wrap it with thread tape, fill the inner primary hole with water, tighten the bolt. you can also use grease instead of water, but it takes more work to clean it out.
11-07-2009, 02:51 PM
Member #4904
\'06 Outlander 800 Camo,Snorkeled,Crutchfield 1&2 Extreme's,27" 589's
\'07 Renegade 800,Snorkeled,27" Executioners
11-07-2009, 03:08 PM
Member #7842
If you can get hold of this stuff:
3M? Wire Pulling Lubricant Communications
You don't need to tip the machine on the side. The 3M cable pulling lubricant(used by electrician) is a water based gel that is firm enough so it won't drip out before you stick the M14 bolt in(as stated above) and the beauty of it is that it's very easy to remove after you are done. Used it a lot on snowmobiles when I needed to remove the drive clutch. I guess you could use cornstarch to just make some gel stuff for this purpose also.
11-07-2009, 03:14 PM
Member #3045
Thanks for the quick responce. I called the dealer They told me they couldnt answer any questions until Tue. Nice way to do business.
06 outty 800 snorkled full skids Aluma Tech CV Guards ITP 212 26" terra cross Piaa HIDs secondary radiator digital engine temp heated hand and thumb dalton clutch BRP fender extensions Fasst Flexx 14deg bars Rox Anti Vibe Risers Cycra Hand Guards and bark busters Moto Comm Camera stage two Crutchfields front and rear
07 Renegade 800 Rox anti vibe risers Aluma Tech external oil filter and cooler
11-07-2009, 03:27 PM
Member #6126
Lol so it takes them 2 days to find the info. 1 for finding the book and another one to search in it.
Anyway just glad to help. that what this site is for.
Ice Can-Am
11-07-2009, 05:30 PM
Member #2217
Guys, this is all great info. I would have never thought of using either water or a viscous fluid to pop that primary off of the engine output shaft. Talk about thinking outside the box! If I ever have to do that again, I am gonna try that method. Reminds me of when I had to remove the lower pulley bolt on a ford ranger I had. Somebody online said to put a breaker bar on there and turn it over..worked like a champ! Just had to make sure the breaker bar was already against the lower cross member. Don't want a breaker bar flying around in the engine bay...its bad, bad..
PRP Steering Stabilizer
